Author Topic: MDF for Control Panel  (Read 1792 times)
Wolfman5750
  • Last login:November 08, 2012, 09:27:20 am
« on: March 15, 2010, 04:27:30 pm »
Hi, I'm just about to start my first control panel.  I'm gathering up all the pieces now, but I can't seem to find 5/8 inch MDF anywhere.  I did find 1/2, 1/8, and 3/4 MDF. I also found 5/8in particle board.  Should I use the particle board or should I glue and screw a piece of 1/8 and 1/2 inch MDF together?
mwong168
  • Last login:May 28, 2019, 11:38:54 am
Re: MDF for Control Panel
« Reply #1 on: March 15, 2010, 04:36:19 pm »
Well if you plan on covering your control panel with artwork then I would say go for the particle board only because with MDF you will get a smooth finish after very little sanding and painting where as that is harder to achieve that smooth finish with particle board.  Both are a mess to work with especially MDF since it is made of a finer particles.
Also if you plan on making a slot for T-molding you might have problems if you glue two pieces together as well.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
Wolfman5750
« Reply #2 on: March 15, 2010, 04:39:31 pm »
Thanks for the reply.  Yeah, I'm planning on adding artwork so particle board it is. I was worried about having enough room for the T-Moulding too.
mwong168
« Reply #3 on: March 15, 2010, 05:16:23 pm »
Well I would be worried where the slot if located and happen to fall near the line where the two pieces join.  I was debating on using particle board in my wireless HAPP fight sticks but glad I didn't because the finish would have been horrible and I probably would have had to cover it with laminate to get the desired finish.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #4 on: March 15, 2010, 05:33:59 pm »
Wouldn't 3/4" inch MDF work the best?  3/4" T-molding is usually what people use to put on thier cabs.  Any reason why you want another size?
Wolfman5750
« Reply #5 on: March 15, 2010, 06:09:29 pm »
Well, I'm going to sandwich artwork between the CP and 1/8in plexi.
Wolfman5750
« Reply #6 on: March 15, 2010, 06:11:59 pm »
I've actually got 3/4in Chrome T-Molding on the way   ;D
