Author Topic: MUGEN/MKP cant run full screen on an Arcade VGA? (SOLVED)  (Read 10298 times)
Candiman
  • Last login:July 12, 2013, 09:31:05 am
    • My MAME / MUGEN project
« on: March 12, 2010, 04:11:47 pm »
I have been trying all different kinds of configurations in the MUGEN.CFG file to try to get it to run fullscreen in my arcade cabinet.
I am running an ARCADE VGA and a JPAC. I can get the game to run in WINDOWED mode at 640x460 but wont run at 320x240 or 640x480.
At 640x480  and fullscreen via HADWARE or SOFTWARE for DX mode the game runs and I can hear game sounds however the screen is just black.
I have pasted the MUGEN.CFG bellow.
Any tips?
;       Configuration file for mugen.exe
; Game options configurable in M.U.G.E.N's options screen go here.
; Does not include key config.
[Options]
; Basic options
Difficulty =2
Life =100
Time =99
GameSpeed =0
WavVolume =50
MidiVolume =50
; Team-only config
Team.1VS2Life =100
Team.LoseOnKO =-1
; Not accessible in options screen
motif =data/system.def
;MP3Volume = 50 ;Not yet implemented
[Rules]
 ;Keep this set at VS. It's the only option supported for now.
GameType = VS
 ;This is the amount of power the attacker gets when an attack successfully
 ;hits the opponent. It's a multiplier of the damage done. For example,
 ;for a value of 3, a hit that does 10 damage will give 30 power.
Default.Attack.LifeToPowerMul =.0
 ;This is like the above, but it's for the person getting hit.
 ;These two multipliers can be overridden in the Hitdef controller in the
 ;CNS by using the "getpower" and "givepower" options.
Default.GetHit.LifeToPowerMul =.0
 ;This controls how much damage a super does when you combo into it.
 ;It's actually a multiplier for the defensive power of the opponent.
 ;A large number means the opponent takes less damage. Leave it at
 ;1 if you want supers to do the normal amount of damage when comboed
 ;into.
 ;Note 1: this increase in defence stays effective until the opponent
 ;        gets up from the ground.
 ;Note 2: the program knows you've done a super when the "superpause"
 ;        controller is executed. That's the instance when this change
 ;        becomes effective.
Super.TargetDefenceMul =.0
[Config]
 ;Set the game speed here. The default is 60 frames per second. The
 ;larger the number, the faster it goes. Don't use a value less than 10.
GameSpeed =53;62
 ;Set to 1 to draw shadows (default). Set to 0 if you have a slow
 ;machine, and want to improve speed by not drawing shadows.
DrawShadows =1
 ;Number of simultaneous afterimage effects allowed.
 ;Set to a lower number to save memory (minimum 1).
AfterImageMax =5
 ;Maximum number of layered sprites that can be drawn.
 ;Set to a lower number to save memory (minimum 32).
LayeredSpriteMax =128
 ;Maximum number of explods allowed in total. Note that hitsparks
 ;also count as explods.
 ;Set to a lower number to save memory (minimum 8).
ExplodMax =200;100;50
 ;Maximum number of system explods allowed.
SysExplodMax =50
 ;Maximum number of helpers allowed in total.
 ;Set to a lower number to save memory (minimum 4, maximum 56).
HelperMax =200;100;50
 ;Maximum number of projectiles allowed per player.
 ;Set to a lower number to save memory (minimum 5).
PlayerProjectileMax =50
 ;This is 1 the first time you run MUGEN.
FirstRun =0
HelperFrameEffects=0
[Debug]
 ;Set to 0 to disable starting in debug mode by default.
Debug =0
 ;Set to 0 to disallow switching to debug mode by pressing Ctrl-D.
 ;If Debug = 1, this will be ignored.
AllowDebugMode =0
 ;Set to 1 to allow debug keys at all times. Otherwise debug keys
 ;allowed only in debug mode.
AllowDebugKeys = 0
 ;Set to 1 to run at maximum speed by default.
Speedup = 1
 ;Default starting stage for quick versus.
StartStage =stages/pit3.def
[Video Win]
 ;Enter the width and height of the resolution you want to set here.
 ;The optimal resolution is 320x240, but if your video card has problems
 ;You may want to try 640x480.
Width  =640
Height =460
 ;This is the color depth at which to run MUGEN. You should set it to
 ;16 bit color unless your video card has problems with it.
 ;16-fastest, 24,32-slower, 8-slowest/worst
Depth =16
 ;Set this parameter to 0 to disable screen stretching, and set it to 1 if
 ;you want to scale it up to fit the current resolution.
Stretch =1
 ;Set this parameter to use a resolution-doubling filter. You will
 ;need a fast machine to use these filters. You will need to increase
 ;the screen resolution to at least 640x480 for these modes.
 ;0 - off
 ;1 - diagonal edge detection
 ;2 - bilinear filtering
 ;3 - horizontal scanlines
DoubleRes =0
 ;DirectX mode
 ;Hardware and Software run in full-screen. Windowed and Overlay
 ;run in a window. The windowed modes require you to set Depth to
 ;whatever color depth you are using for you desktop. The best results
 ;are when you run in 16-bit color. There is no advantage to running
 ;in 32-bit color. If Hardware, Software and Windowed fail, try Safe.
 ;None uses GDI to draw, so it's very slow. Use None only if
 ;you cannot get anything else to work.
 ;Overlay is not supported by all video cards, but can be faster than
 ;Windowed if it works.
DXmode = Windowed
;safe
 ;Set to 1 to enable vertical retrace synchronization. Do not enable
 ;if BlitMode = PageFlip.
VRetrace =0
 ;Drawing mode
 ;Choose from Normal and PageFlip
BlitMode =normal
[Video Linux]
Width  = 640
Height = 480
Depth = 16
Stretch = 1
 ;0 - off
DoubleRes = 3
VRetrace = 0
 ;Set to 1 to enable fullscreen mode, 0 for windowed.
FullScreen = 0
 ;Drawing mode
BlitMode = PageFlip
; Sound configuration (Windows)
; Note: WavVolume and MidiVolume here are not the same
; as the ones in [Options], but they all affect the volume.
[Sound Win]
  ;Set the following to 1 to enable sound effects and music.
  ;Set to 0 to disable.
Sound =1
  ;Set the following to 1 to enable stereo effects in-game
StereoEffects =1
  ;This is the width of the sound panning field. If you
  ;Increase this number, the stereo effects will sound
  ;closer to the middle. Set to a smaller number to get
  ;more stereo separation on sound effects.
  ;Only valid if StereoEffects is set to 1.
PanningWidth =240
  ;Set the following to 1 to reverse left and right channels
  ;on your sound card.
ReverseStereo =0
  ;Wave device to use. Choose from:
  ; NONE    - No wave device
  ; AUTO    - Autodetect
  ; DX?     - DirectSound: replace ? with a the device number (from 0 to 9)
  ; DXA?    - DirectSound with Allegro mixer: replace ? with a the device number (from 0 to 9)
  ; WAVEOUTA- High-quality wave-out
  ; WAVEOUTB- Low-quality wave-out
WavDevice =AUTO
  ;Voice Channels to use. Values are from 1 to 16.
  ;If sound quality is poor, try setting a smaller number, such as 8 or 4.
WavChannels =14
  ;Maximum number of voices used for MODs.  This number reduces the
  ;number of available WavChannels.  ModVoices must be less than
  ;WavChannels.  If equal, then MODs will get all the available
  ;channels and therefore no sound effects will play.
ModVoices =6
  ;Midi device to use. Choose from:
  ; NONE    - No midi device
  ; AUTO    - Autodetect
  ; MAPPER  - MIDI Mapper
  ; MID?    - MIDI Device: replace ? with a the device number (from 0 to 9)
  ; DIGMID  - Allegro's Digimid driver
MidiDevice =AUTO
  ;This is the master volume for all wav sounds (affects mp3 volume).
  ;Valid values are from from 0 to 255.
MasterWavVolume =100
  ;Set the volume of wav, midi, mods and CD audio.
  ;Note: WavVolume does not affect mp3 or mod volume.
  ;For CDAVolume only, using -1 will leave the volume unchanged.
WavVolume =100
MidiVolume =192
MP3Volume =255;This affects all Winamp-compatible plugins as well
ModVolume =80
CDAVolume =-1
  ;Set the following to 1 to enable and 0 to disable MIDI, MP3, MOD and CD
  ;playback.
PlayMIDI =1
PlayMP3 =1;This affects all Winamp-compatible plugins as well
PlayMOD =1
PlayCDA =1
  ;Set the drive letter of your CD-ROM (if you have more than one
  ;drive). eg, To use drive E, put the following:
  ;  CDADevice = E:\
  ;Leave blank to use your default CD-ROM drive.
CDADevice =
  ;Set the following to 1 to pause BGM playback when switching
  ;away from the MUGEN window.
PauseBGMOnDefocus =1
  ;List Winamp-compatible plugins here.
  ;Specify the filename of the plugin and the list of file types to
  ;use the plugin for. One plugin per line.
  ;Example: plugin = plugins/my_plugin.dll, mp3, mp2, mpg
  ;If music is not looping with a particular plugin, you can try an
  ;optional first argument looptype=1 (seek to zero; may stutter)
  ;or looptype=2 (reload plugin; slow).
  ;Example: plugin = looptype=1, plugins/my_plugin.dll, mp3, mp2, mpg
plugin =looptype=1, plugins/in_mp3.dll, mp3, mp2, mpg
;plugin = looptype=1, plugins/in_mp3PRO.dll, mp3, mp2, mpg
plugin = looptype=1, plugins/in_wm.dll, wma
plugin = looptype=1, plugins/in_bass.dll,s3m,xm,mod,it,669,psm
plugin = looptype=1, plugins/in_vorbis.dll, ogg
plugin = looptype=1, plugins/in_adx.dll, adx
plugin = looptype=1, plugins/in_ape.dll, ape
plugin = looptype=1, plugins/in_snes.dll, spc,sp1,sp2,sp3,sp4,sp5,sp6,sp7,sp8,sp9,sp0
plugin = looptype=1, plugins/in_psf.dll, psf, minipsf, psf2, minipsf2, psflib, psf2lib
plugin = looptype=1, plugins/in_qsf.dll, qsf, miniqsf, qsflib
plugin = looptype=1, plugins/in_ym.dll, gym, cym
[Sound Linux]
Sound = 1
StereoEffects = 1
PanningWidth = 240
ReverseStereo = 0
  ; AUTO    - Autodetect
  ; OSS     - Open Sound System
  ; ESD     - Enlightened Sound Daemon
  ; ALSA    - ALSA sound driver
WavDevice = Auto
WavChannels = 12
ModVoices = 6
  ; AUTO    - Autodetect
MidiDevice = Auto
MasterWavVolume = 255
WavVolume = 128
MidiVolume = 128
MP3Volume = 135
ModVolume = 80
CDAVolume = -1
  ;playback.
PlayMIDI = 1
PlayMP3 = 1
PlayMOD = 1
PlayCDA = 1
  ;  CDADevice = E:\
CDADevice =
[Misc]
  ;Number of extra players to cache in memory.
  ;Set to a lower number to decrease memory usage, at cost of
  ;more frequent loading.
PlayerCache =-1
  ;Set to 1 to allow precaching. Precaching attempts to start loading
  ;player data as early as possible, to reduce apparent loading times
  ;between matches. To get the best performance, set PlayerCache to at
  ;least 1. The optimal number for PlayerCache is 4 when precaching is
  ;enabled. Precaching is not available in DOS.
Precache =1
  ;Set to 1 to enable large-buffer reads of sprite and sound data.
  ;Set to 0 (off) to decrease memory usage, at cost of slower
  ;loading.
BufferedRead =0
  ;Set to 1 to free system.def data from memory whenever possible.
  ;This decreases memory usage, in exchange for loading time
  ;before system screens.
UnloadSystem =1
  ;Set to 1 to pause MUGEN when the MUGEN window loses focus (will also
  ;pause BGM regardless of the PauseBGMOnDefocus setting).
  ;Leave at 0 to let MUGEN run in the background.
  ;Regardless of this setting, MUGEN will always pause on defocus if
  ;it is running fullscreen.
PauseOnDefocus =1
[Arcade]
 ;Set to 0 for computer to choose color 1 if possible.
 ;Set to 1 for computer to randomly choose a color.
AI.RandomColor =1
 ;This option allows the AI to input commands without
 ;having to actually press any keys (in effect, cheating)
 ;Set to 1 to enable, 0 to disable. Enabling this option
 ;can give the illusion of a smarter AI.
AI.Cheat =1
arcade.AIramp.start=2, 0
arcade.AIramp.end=4, 2
team.AIramp.start=1, 0
team.AIramp.end=3, 0
survival.AIramp.start=0, -3
survival.AIramp.end=16, 4
 ;Arcade Mode AI ramping. For both parameters below, the first number
 ;corresponds to the number of matches won, and the second number to the
 ;AI difficulty offset. The actual difficulty is the sum of the AI
 ;difficulty level (set in the options menu) and the value of the offset
 ;at a particular match.
 ;  AIramp.start = start_match, start_diff
 ;  AIramp.end   = end_match, end_diff
 ;The difficulty offset function is a constant value of start_diff from
 ;the first match until start_match matches have been won. From then the
 ;offset value increases linearly from start_diff to end_diff. After
 ;end_diff matches have been won, the offset value is end_diff.
 ;  e_d            /----------
 ;  s_d _______/
 ;   1st_m   s_m   e_m     last_m
 ;For example, if you have:
 ;  AIramp.start = 2,0
 ;  AIramp.end   = 4,2
 ;For 6 matches at level 4, the difficulty will be (by match):
 ;  4,4,4,5,6,6
;arcade.AIramp.start = 2, 0
;arcade.AIramp.end   = 4, 2
 ;Team Mode AI ramping
;team.AIramp.start = 1, 0
;team.AIramp.end   = 3, 2
 ;Survival Mode AI ramping
;survival.AIramp.start = 0, -3
;survival.AIramp.end   = 16, 4
[Input]
P1.UseKeyboard =1
P2.UseKeyboard =1
;Joystick type:
;0 - Disable
;1 - Autodetect (not reliable under DOS)
;4 - 4 button
;6 - 6 button
;8 - 8 button
;20 - Sidewinder
;21 - SNESKey
;22 - PSX pad
;23 - N64 pad
P1.Joystick.type =1
P2.Joystick.type =0
ForceFeedback =0;True to enable force feedback (DOS only)
; P1 Key config (configurable from M.U.G.E.N)
[P1 Keys]
Jump   =200
Crouch =208
Left   =203
Right  =205
A      =75
B      =77
C      =76
X      =71
Y      =73
Z      =72
Start  =28
Guard  = 0;50  ;Debug only
Run    = 0;54  ;Debug only
Turn   = 0;157 ;Debug only
; P2 Key config (configurable from M.U.G.E.N)
[P2 Keys]
Jump   =17
Crouch =31
Left   =30
Right  =32
A      =33
B      =35
C      =34
X      =19
Y      =21
Z      =20
Start  =15
Guard  = 0;76 ;Debug only
Run    = 0;73 ;Debug only
Turn   = 0;83 ;Debug only
[P1 Joystick] ;Default config
Jump   = 1
Crouch = 2
Left   = 3
Right  = 4
A      = 5
B      = 6
C      = 7
X      = 8
Y      = 9
Z      = 10
Start  = 11
[P2 Joystick] ;Default config
Jump   = 1
Crouch = 2
Left   = 3
Right  = 4
A      = 7
B      = 5
C      = 6
X      = 8
Y      = 10
Z      = 9
Start  = 11
Thank you so much.
« Last Edit: March 17, 2010, 04:05:59 am by Candiman »
Space Fractal
  • Space Fractal
    • Space Fractal
Re: MUGEN/MKP cant run full screen on an Arcade VGA?
« Reply #1 on: March 12, 2010, 04:29:34 pm »
Width  =640
Height =460
DXmode = Windowed
I guess that should have been:
Width  =321
Height =240
DXmode = Overlay
ArcadeVGA don't support 320x240, but use 321x240. Hope the app can support costume resolutions, but not all can that.
PS. Have not checked the game, but think its somethere there, since the 320x240 issue is a commen problem.
« Last Edit: March 12, 2010, 04:34:19 pm by Space Fractal »
Candiman
« Reply #2 on: March 12, 2010, 04:43:54 pm »
Thanks for the reply.
With those settings it runs however once again with a black screen only.
I am hoping there is a solution as it can run and at a resolution that is my screen size. However the title bar is ugly and I would like to not see it while playing...
Sigh.
Candiman
« Reply #3 on: March 12, 2010, 04:46:46 pm »
Just read this on another forum:
You need VESA drivers to run MUGEN. It's recommended you run in VESA2, since that is usually faster for 16-bit colour. Check readme.txt for more info on tweaking your graphics settings. The default setting for MUGEN is 320x240 in 16-bit color, using VESA2 in linear mode. Older video cards may need to use banked mode, so be sure to check. Some VESA drivers such as Scitech Dislplay Doctor may need linear mode manually enabled.
Is the ArcadeVGA VESA compatible?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: March 12, 2010, 07:49:46 pm »
The ArcadeVGA is VESA compatible and recent versions support 320 x 240 (as opposed to 321 X 240), so not sure why this is not working.
Andy
  • Last login:Yesterday at 01:32:52 pm
« Reply #5 on: March 12, 2010, 11:52:02 pm »
Long answer or short answer?  The short answer is mugen is old and busted so it has issues with windows, various video cards and various resolutions.
Long answer... mugen was originally a DOS program, then ported to win95 (badly)  eventually the project was completely abandoned but somehow people hacked the old exe to run on windows xp/2000 and above anyway.  The problem is they didn't do that great a job.  I believe the engine is back in development now, but not with the original authors, so it isn't as good.  The point of it is, don't go blaming your arcade vga as 9 times out of 10 resolution problems with exotic video cards are the fault of mugen itself.
Work-around.... run the game in windowed mode and use a program or auto-it/ahk script to change the windows properties.  There is such a thing as a title-less borderless window and you can set ANY program's window properties to this.  You'll probably have to stretch the window as well, to make it fill the full screen, but again, this can all be done in code.
You can also use full gdi mode, as suggested in the readme.  It can be slow, but then again mugen is an OOOOOOOOLD program so your pc might be fast enough anyway.
Candiman
« Reply #6 on: March 13, 2010, 12:02:12 am »
Andy
I have the 9250 AGP
Does that mean I am up the creek?
Candiman
« Reply #7 on: March 17, 2010, 04:04:57 am »
On the MUGEN official forums it was suggested that I try putting the MKP characters into the new MUGEN 1.0
It now works full screen.
Now I just have key map issues again so everything works except HK on P1 but while I wait for proper keycodes I have remapped HK to RUN.
Thanks for the help everyone.
