Author Topic: Trackball questions  (Read 2636 times)
lhallmark
  • Last login:January 13, 2010, 04:55:18 am
Trackball questions
« on: July 27, 2003, 10:26:11 pm »
I am sure that this topic has probably been beaten to death but I am a newbie in need...
I have a SF2 cab that I am converting to a MAME cabinet. It has the flip down metal CP. I would like to mount either a 3" trackball or a 2 1/4" if I have to, depending on how much space it needs.
Questions:
1) How would I mount the trackball to the metal CP? Do I have to cut out a hole for just the ball or the mounting plate?
2) If I have to use a mounting plate what are the dimensions of it?
3)Any reccomendations on what trackball to use?
Thanks,
Lance
Safety Harbor, FL
BobA
  • What Me Worry?
Re:Trackball questions
« Reply #1 on: July 27, 2003, 10:28:17 pm »
You just have to cut the round hole for the ball and the four mounting screws.   Mounting plates are only required on wood or mdf control panels.
BobA
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #2 on: July 27, 2003, 11:10:06 pm »
I have wood panel with no mounting plate!
American Laser Games Wrapper
O2em Rom Utility
OSCAR
    • Oscar Controls
« Reply #3 on: July 27, 2003, 11:26:50 pm »
Questions:
For a 3" trackball, figure on about a 6" x 6" area for it.  You need to make a 3" hole for the boss around the ball to fit through your metal control panel.  Once you have the hole cut for the trackball to fit through, you can then drill the four 3/16" holes for the mounting bolts using the trackball housing as a guide.
No, I wouldn't use a mounting plate with a metal control panel.  It isn't necessary unless you don't have a good way to make a 3" diameter hole for the trackball.  Sometimes it can be easier to use the mounting plate because you only need to rough in a hole to mount the trackball, and the mounting plate will do well to cover up the 6" x 6" rectangular hole you make for it, if it turns out sloppy.
You can't go wrong with a 3" Happ trackball.  Other options are the Imperial or Wico 3", but the Happ is a good one that most people are familiar with that you shouldn't have any trouble with interfacing with optical encoders.
ErikRuud
« Reply #4 on: July 28, 2003, 09:12:17 am »
I forget the ecxact measurement, but the boss on the Betson/Imperial trackball is slightly less than three inches.
O2em Rom Utility
lhallmark
« Reply #5 on: July 29, 2003, 10:25:39 pm »
Thanks guys. I think I'm going to get one ordered soon.
Which 3" trackball is the best?
Do they make a kit for the translucent ones?
Thanks,
Lance
Safety Harbor, FL
ErikRuud
« Reply #6 on: July 29, 2003, 11:08:43 pm »
The one in the picture above is a Betson/Imperial 3" red translucent with a ps/2 interface.  I have not had it very long, but it seems to work well.  It is 79.00 from Betson.
O2em Rom Utility
pointdablame
  • Last login:May 19, 2025, 06:36:30 pm
« Reply #7 on: July 30, 2003, 11:25:13 am »
I left you a private message lhallmark. take a look
first off your and idiot
