Author Topic: Ultrastick 360 mala plugin  (Read 4319 times)
Sir Headless VII
  • Last login:April 30, 2017, 02:04:52 pm
« on: March 08, 2010, 10:46:20 pm »
Ok, so I downloaded the plugin and I can't figure out how it figures out what map it will apply to a game. So my question is, how does it figure it out?
ubiquityman
  • Last login:May 06, 2016, 10:57:58 pm
Re: Ultrastick 360 mala plugin
« Reply #1 on: March 09, 2010, 01:02:20 am »
you shouldn't need to.  Mame does the mapping for you on an analog joystick.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: March 09, 2010, 08:38:34 am »
It's most likely using the controls.ini and/or mame.xml files.
Robots will kill you.
Arcade Addiction
fatfingers
  • Got UltraStiks?™
« Reply #3 on: March 10, 2010, 03:21:20 pm »
As the author, I can say that MaLa tells the plugin what type of game is being played (4-way, 8-way, 2-way, etc.) and it applies a map file accordingly.  There are default files installed named 4way.ugc, 8way.ugc, etc. (or at least close to that).  If you want a different map for a game than what is being applied by default you create a new UGC file and put the correct maps to be applied.  This new file would be called <romname>.ugc.  But, basically, the plugin usuallly just works and the fact you can't tell if it's working or not is probably good.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
arzoo
    • LEDBlinky
« Reply #4 on: March 11, 2010, 08:53:54 am »
I'm pretty sure mala determines the joystick type from the controls.ini
Arcade Addiction
fatfingers
  • Got UltraStiks?™
« Reply #5 on: March 11, 2010, 06:26:12 pm »
Yep, me too.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ubiquityman
« Reply #6 on: March 12, 2010, 02:00:58 pm »
My point was that MALA is not required for joystick mapping if you are using an analog joystick.
MAME takes care of that internally.
fatfingers
  • Got UltraStiks?™
« Reply #7 on: March 12, 2010, 03:43:14 pm »
That is most certainly true.  However, this plugin and UltraMap allow you to make custom maps for just one game, which I think is not possible in the MAME mapping system?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ubiquityman
« Reply #8 on: March 12, 2010, 03:52:13 pm »
[see newer post below]
« Last Edit: March 13, 2010, 05:38:02 pm by ubiquityman »
I/O
  • Last login:June 06, 2011, 01:33:10 am
« Reply #9 on: March 13, 2010, 03:12:57 pm »
Current MAME handles analog stick mapping, and you can create your own maps for it, even per game/romset by giving the map the rom name. The convenience of the Mala plugin is that it affects all emus (or at least all I am using), with the obvious caveat that the data in the file used may be different between builds of the same emu.
ubiquityman
Re: Ultrastick 360 Mapping in Mame Without MALA
« Reply #10 on: March 13, 2010, 05:36:56 pm »
Thanks for the info.
I just tried this.
I took a previously created INI file and added an additional line for Joystick Mapping.
It does work as you described.  Fantastic!
Sir Headless VII
« Reply #11 on: March 15, 2010, 06:26:41 pm »
Thank you that is exactly what I wanted to know.
