Author Topic: Unable to get videos to play in Mala beta!  (Read 3090 times)
JustMichael
  • Mmmmm!! Cheesecake!!
« on: March 07, 2010, 09:53:42 pm »
I am trying to run MaLa on a Win98se machine.  I am using 1.62g.  I tried ffdshow first and still no videos only a black square where the video should play.  I tried Xvid and black square again.  I installed the k-lite codec 3.4.5 and still the same black square.  Now here is the kicker, the videos played just fine each time in windows media player.  I currently have only the k-lite codecs installed and I accidentally ran the 1.05 executable of MaLa and the video plays but won't play in the beta version.  Is there a solution to get it to play in the beta?
Re: Unable to get videos to play in Mala beta!
« Reply #1 on: March 07, 2010, 10:53:26 pm »
You might try avicodec or gspot to make sure you know which codec is required for the vids your using, then grab the right codec.
That's the problem I had way back when.
JustMichael
« Reply #2 on: March 08, 2010, 12:04:48 am »
If I understand codecs right, if I don't have the right codec the videos won't play in anything.  The videos play in MaLa 1.05 but not the 1.62g beta.
wikee
  • Last login:August 18, 2021, 05:31:34 am
« Reply #3 on: March 08, 2010, 07:40:42 am »
i had similar problems,  download the codec pack on emumovies website and not any ---smurfy--- codecs pack around (sld, klite etc):)
JustMichael
« Reply #4 on: March 08, 2010, 03:02:01 pm »
You do realize that CCCP (from Emumovies) requires NT 5.0 (Windows 2000) or later right?  I am trying to run the MaLa beta on win98SE.  This computer is about 7 years old and instead of throwing it out, it got recycled into running an arcade cabinet.
