Author Topic: Problem generating custom list in Mamewah  (Read 2502 times)
jginiso
  • Last login:January 23, 2009, 01:41:17 pm
« on: July 27, 2003, 10:11:54 am »
I have MAME071 setup correctly in mamewah0954b but cannot generate a custom list. Here is the sequence:
Generate List Options --> Select Custom List --> Choose Custom List 1 --> Generate Custom List Using Filters --> change Display Clones to Only if Parent is Broken -->  press 2 to exit the menu --> get a dialog saying Generating Filtered Game List --> no games found. Ive tried all of the different list generation options (ROM Folder, ROM Folder vs DAT File) but I dont think that is the problem since my main games list displays all games... Any help would be appreciated.
Re:Problem generating custom list in Mamewah
« Reply #1 on: July 27, 2003, 11:32:17 am »
Sounds like you did everything right...
Try setting the List Generation Method back to the Listinfo one, and then refresh the main list.
Then try generating the custom list again.
It should work - I just did the same sequence...
Impostor
  • Last login:September 27, 2005, 03:18:35 pm
« Reply #2 on: July 27, 2003, 01:32:12 pm »
I was setting up MameWah yesterday and got the same problem as jginiso.  I also tried filtering from certain bios, manufacturer, etc...  Same problem.
I'm running XP Pro SP1.  Windows cmdline Mame.
Impostor
« Reply #3 on: July 27, 2003, 03:18:20 pm »
I figured it out:  This doesn't happen if you use a CatVer.ini - this is why I didn't notice...
For now, download+use CatVer and the problem shouldn't occur.
I'll fix for next release - thanks for finding the bug  :)
jginiso
« Reply #4 on: July 28, 2003, 09:53:07 am »
cool, glad I could help.
I searched the boards for catver.ini and many posts say to use triggerfan's catver file. Are either of these links to that file:
http://www.mameworld.net/catlist/
http://www.catver.com/
or can I use any one? Also, what do I do with it? Thanks
« Reply #5 on: July 28, 2003, 01:26:49 pm »
I'd recommend TriggerFins too: http://www.mameworld.net/catlist/ is the one :)  (Either will work tho).
Just put the CatVer.ini file somewhere suitable (I put mine in my MAME path), and refer to the 'CatVer Filename' in MAMEWAH under 'Emulator Settings' > 'List Generation Settings'.
Refresh the list and you should be able to view/use the categories :)
Impostor
« Reply #6 on: July 29, 2003, 02:49:54 pm »
Thanks Minwah!  I tried and it worked as described.
Impostor
volcomtwin
  • Last login:August 10, 2004, 11:10:59 am
  • Life Ruined My Skateboarding
« Reply #7 on: July 30, 2003, 10:48:36 am »
hi there... not meaning to hijack this or anything, but i am doing the same process here.  i have pointed MW to my catver and it generates fine, however Minwah said "Refresh the list and you should be able to view/use the categories" , now I seem to have all my roms listed under custom list1.  I'm not seeing where these categories are.... any help would be great..thanks!
« Reply #8 on: July 30, 2003, 11:20:34 am »
You should be able to see the category of the currently selected game in the bottom right of the screen (using a standard 'Classic' layout except 640x288).
Go into 'Games List Options' > 'Generate Custom List using Filters' and you should see 'Category Filters'.  Go into this submenu and you will see a whole load of categories to turn on/off...
Hope that helps :)
volcomtwin
« Reply #9 on: July 30, 2003, 11:39:48 am »
thanks but when I go to 'Games List Options' > 'Generate Custom List using Filters'  all i see is the option to 'Display Clones'...could this be a prob w/ my catver file??  I am using the one as metioned above.
Impostor
« Reply #10 on: July 30, 2003, 11:40:42 am »
sort of a related question, how do I cycle the lists without bringing up the menu to change the list?  I read the readme.txt and it talks about the coinA, coinB buttons.  Doesnt' do anything for me even though I have the lists set to TRUE in the cycling menu.
Impostor
« Reply #11 on: July 30, 2003, 06:32:08 pm »
Um, what 'List Generation Method' are you using?  (Check in 'Emulator Settings' > 'List Generation Settings')
The CatVer file should make no difference to those filters being shown (even if you do not have a CatVer).
« Reply #12 on: July 30, 2003, 06:35:07 pm »
Impostor
By default, Coin 1 is cycle custom list...BUT this is the HotRod style Coin 1 - ie '3'.  Older versions would work with either, but now you must use the 'Control Options' > 'Customise Controls' menu...
Of course I'm assuming you didn't realise that already - let me know if you've tried that...
Impostor
« Reply #13 on: July 31, 2003, 10:31:52 am »
Thanks Minwah!  I remapped the buttons to cycle lists.  All is well!
THanks again for all your help!
Impostor
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« Reply #14 on: July 31, 2003, 12:03:48 pm »
im having a similar issue still, i got the catver and pointed mamewah to it and all,
im trying to get it to just list NeoGeo games so i seleceted neogeo bios only, but it
says generating and then show no games availible?
i'v read over this and im either stupid or blind. i cant get it working...
anyone wanna spoon feed me the steps so i can see if im missing something here?
« Reply #15 on: July 31, 2003, 03:31:39 pm »
Did you refresh your (main) list since you pointed to CatVer?
