Author Topic: What's the preferred method for attatching the top panel to the box?  (Read 3298 times)
The cranky hermit
  • Last login:June 03, 2006, 01:35:04 am
  • CP #1: Completed
Naturally, a method that does not require a router  ;)
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
Re:What's the preferred method for attatching the top panel to the box?
« Reply #1 on: July 27, 2003, 01:00:19 am »
I've found gravity works pretty well. That and the sides of my box are so tight its not sliding out on its own.
I used piano hinges on my previous one.
Mucal invader, is there no end to your oozing?!
Hoe
  • Last login:September 05, 2004, 01:17:09 pm
« Reply #2 on: July 27, 2003, 08:06:29 am »
I've yet to make one involving hinges, but they sound like a lot more fuss for a lot more inconvinence. Making it so the box is slightly larger, and so you need to force the cover on top of it gives a very good result.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: July 27, 2003, 09:31:55 am »
Ugh - you guys aren't physically attaching the top somehow? That's just begging for disaster.
On my first cab I used 2 small cabinet hinges in the back, and a latch in the front.  Very sturdy.
Some can get by with just a few hinges in the back and a bunch of velco in the front.
CanStick
  • Last login:May 02, 2004, 12:39:58 pm
    • CanStick Controls
« Reply #4 on: July 27, 2003, 11:21:42 am »
I have used velcro for that, and it holds quite well.
Or, another thing you could do, is fasten the top to the sides, and make the bottom removable.  I have done this as well, and I just use four screws to hold the bottom on, so when I need to get inside, it is quite easy & quick to do.
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #5 on: July 27, 2003, 07:22:20 pm »
Velcro along all 4 edges, no hinge.  Never budges!
I do have 2 locating blocks on the underside of the top for side loads.
TalkingOctopus
    • My Arcade
« Reply #6 on: July 27, 2003, 08:45:52 pm »
4 edges of industrial strength velcro.  Good times!!
SeanFu
  • Last login:May 22, 2004, 09:56:37 pm
  • I learn everything the hard way.
« Reply #7 on: July 27, 2003, 11:37:23 pm »
I used two small hinges in the front so it would flip forward.  Unfortunately it's got some annoying play in it...
I'm going to try and suppliment it with some velcro I think.  Or maybe some well placed guide blocks.  Just one of the many details I find that I haven't thought out too well.
Frostillicus
  • Arcade Artist
« Reply #8 on: July 28, 2003, 10:51:25 am »
The reason most of us use hinges and a latch is to stop curious hands from messing with the innards...especially if you have kids (I don't, but have nephews).  With a latch you can lock it...
Aceldamor
« Reply #9 on: July 28, 2003, 11:43:26 am »
Another alternative is to use T-nuts:
Just put theese into the top of the walls of your cp box, then you can screw in the carridge bolts to keep the cp on. Looks kinda nice.
Fuzzy Wuzzy was a woman!
king88mob
  • Last login:November 10, 2003, 10:14:10 am
« Reply #10 on: July 28, 2003, 12:30:38 pm »
I use a combination of the two solutions seen here. Piano hinge along the back, and velcro along the other three sides. Guiding blocks are a good idea as well.
SeanFu
« Reply #11 on: July 28, 2003, 01:41:36 pm »
How did you find piano hinges that were the right length?  The ones I saw at Home Depot were like 3 feet long.  Also - is there any play in the piano hinge?
AlanS17
    • AlanS17
« Reply #12 on: July 28, 2003, 02:42:54 pm »
I recommend chewing gum - preferably not sugar-free. That stuff doesn't stick too well.
hyiu
    • www
« Reply #13 on: July 28, 2003, 05:21:36 pm »
I used panel clamps before... I find it very nice... (although not a cheap solution...)
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #14 on: July 28, 2003, 10:28:49 pm »
ACE Hardware sells 12" hinges. I used two of them for a 24" run and then worked great. No need for a hack-saw and it only cost me maybe $2 more.
TheTick
  • I.P. Daley
« Reply #15 on: July 28, 2003, 11:26:55 pm »
I guess I didn't use a piano hinge... it was those little 2" or 3" hinges from Home Depot. I used two on the back, so it flips up. Held pretty well on its own.... No ones lifts the joysticks up, just down.
SeanFu
« Reply #16 on: July 29, 2003, 05:25:45 pm »
pmc,
When you used those 2 12" hinges, did you use anything additional to secure the CP?  Is there any lateral "play" in those hinges?
