Author Topic: Sega Lindbergh Restoration - HD-goodness!  (Read 12311 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: March 03, 2010, 01:38:04 pm »
Posted over at Arcade Otaku as well but I thought I'd post it over here as it's more of a DIY project than most I've done recently and I know a lot of you guys are full of good ideas and solutions! ;)
So I collected 'Linda' the Lindy over the weekend and as there is a lot to do on her I thought I may as well open a 'project' thread!
Here she is in the form I collected her...
Excellent nick but missing some crucials!
First thing is a monitor - can't play games if you can't see 'em!  Bought a lovely Ultra Slim Hitachi UT32MH70 from Andy for a nice price. Compatible with most/if not all HD gaming platforms - HDMI and VGA connection and importantly only 35mm thick. :applaud:
I didn't want to mod anything on the cabinet - at first I thought I'd go for a sitdown model but I soon realised I actually like this cab upright as well - so why make the extra work for myself and start bastardizing the thing! It's funny, reading previous threads about the Lindy, everyone agrees, it looks like a dog in photos but see it in the flesh and it's actually nice! I'm a convert anyway - even if you guys aren't!   ;D
Anyway, to prevent modding it/drilling holes through it, etc... I decided to go for the idea of mounting the LCD mount to a strong piece of wood which then would mount to the original monitor mount on the cabinet without the need to drill holes, etc. I had a nice chunky bit of wood in the garage - 1.5cm thick, so I used that. I drew out the holes to match up with the holes on the cabinet mount and got some nice big nuts and bolts to go through... they are quite a bit smaller but big enough to grip thankfully -
This will be spray painted black to make it more inconspicuous! ;)
Next will be mounting the TV mount I've got to the monitor and then the piece of wood. This has a 15 degree tilt on it which will add a bit of flexibility. As a consequence it is 8cm deep. When you do the maths - 3.5 for the LCD, 1.5 for the wood and 8 for mount it equals 13cm - measuring the 'step' on the midsection of the cabinet, that is 12cm deep, however, the LCD has curved edges so hopefully the monitor should be pretty much flush with the mid section. Looking at reference pictures, the monitor is generally slightly in but I kind of think it will look slightly better being flush.
Here are pictures of the mounting on the back of the monitor -
I'm hoping to have the cabinet up and running with consoles and MAME by the weekend - this will just be for the meanwhile to get some use and enjoyment out of it while planning the next steps! Thank goodness I have some spare ipac bits and pieces/adaptors and a XRGB-2 already at my disposal!    ;D
Here is a sneak peak... I do NOT recommend doing this but to measure up the mounts on the wood I had to lift the monitor with the mount on the back on to the 'step' of the midsection to mark up where to drill the holes... I thought this was going to be mission impossible with one man but it was actually relatively easy! With it sat on the step I couldn't help but take a risk to step back and take a photo with my camera - risky business but to be fair it didn't budge at all - wouldn't have said it was the most sensible thing to do though!  :P Here are the pics...
Surprisingly, the monitor wasn't quite flush with the midsection... it was about a cm in but it looked good so I'm happy. Please note the monitor ISN'T mounted so if you don't think it's centralised - don't worry - it was just propped there and wasn't positioned!  So far so good I feel but still A LOT to do!  Hopefully it'll be mounted by the end of tomorrow - HOPEFULLY!   ;)
The next step may or may not be this...
Need to get on to Happ with replacing the coin door... shouldn't be exceptionally expensive and thanks to AndyGeezer I now have the part number - once I have the funds I'll grab one!  UPDATE - A kind chap over at Arcade Otaku named Adam has just offered me a black Sega door for free! Just need to find a frame not! He seems to be my saviour on modern Sega cabs - second time he's done me a massive favour! :)
Then I'd like to deal with the midsection as that is the bit that is most obviously missing... I'll be investigating all the options to get the best result!
I can't tell you exactly how I'm going to achieve each step just yet - I'm hoping to use a combination of finding original parts and those parts I can't find, having them CNC'd (hopefully). Anyway, that's the first post, of hopefully a few... I really want this done for my birthday so I'm aiming for a 2 month timeframe... might be a bit optimistic but we'll see...
slapaham
Re: Sega Lindbergh Restoration - HD-goodness!
« Reply #1 on: March 04, 2010, 08:45:01 am »
Mount complete and sprayed - nice and strong but I had a sudden brainstorm and drilled some extra holes in - a little untidy but you'd never see them... a moment of madness!  :shock: It isn't quite flush with the Lindy's mounting board either - I swear it was yesterday - again, doesn't matter - it's incredibly strong and it's straight. The monitor 'rests' on the midsection anyway (which I guess is one of the midsection's purposes!) so it's all lovely and straight...
Anyway... here's the monitor now mounted...
As you can see, I cleared a bit of space in front of the cabinet so it's playable. Out went the speakers (and hopefully into the loft!) - but I did put the cubes and PCs back in place, so around the sides it is very enclosed - not a problem for when it's in use and easy to move when I need to work on it! ;)
I'm now enquiring about getting some Sega stickers printed for monitor bezel... Also, sent an email to Happ asking whether they could sell me just the frame for Adam's freebie door... should have a response hopefully tomorrow. :)
  • Last login:Yesterday at 11:21:11 am
« Reply #2 on: March 04, 2010, 01:22:15 pm »
So next is the rotary mech then?  :laugh:
slapaham
« Reply #3 on: March 05, 2010, 04:31:32 am »
I've been thinking about that and I don't think it would be a particularly good idea. The good thing is with the way I've constructed what I've done so far, it would be extremely easy to incorporate one in future so I'll see how I feel once the projects (hopefully) starts winding down later! ;)
It's a nice idea in theory but I'm not so sure in practice!  :-\
SirPeale
  • Green Mountain Man
« Reply #4 on: March 05, 2010, 01:33:03 pm »
I'm curious - what will this be running?
slapaham
« Reply #5 on: March 05, 2010, 05:05:22 pm »
Well, I'd eventually like it to be running original Lindbergh hardware if funds allow me to do a good enough restoration. Games like Virtua Tennis 3 and Virtua Fighter 5 were games that featured on this hardware.
Some more details - http://www.system16.com/hardware.php?id=731
Until then, I'll be using it as a games console cabinet and for MAME.
Power cable for the monitor arrived today so here's an example of MAME and PS3 on the cabinet. I'm awaiting a harness from Ultimarc and then I can hopefully get the controls wired up for an actual play! ;)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« Reply #6 on: March 09, 2010, 07:25:37 am »
should post some gameplay vids !!!!!
slapaham
« Reply #7 on: March 09, 2010, 04:03:32 pm »
I will do eventually. Still lots to do before I'm happy - lovely cab as it is but I'm a perfectionist!  ;D
« Reply #8 on: March 09, 2010, 06:46:21 pm »
Thread needs more DeathSmiles.  :cheers:
slapaham
« Reply #9 on: March 10, 2010, 07:10:32 am »
Well, got no excuse since the Jap 360 arrived yesterday - just awaiting the relevant adaptors to wire it up fully! ;)
Bit disappointed by I can't get Ikaruga to sync with the screen properly when using my Wii - I can get it with the colours distorted through the XRGB2 but that's the best I can do. I reckon it's because it's a PAL console playing a NTSC-J game and the syncing all gets a bit confused... looks like I might just have to track it down on either Xbox Live or DC to interface it! :(
slapaham
« Reply #10 on: March 10, 2010, 07:22:58 am »
On a plus note, I have now got the Wii interfaced and Tatsunoko vs. Capcom playing! Looks and plays beautifully! ;D
