February 11, 2026, 07:31:30 pm
1) Drill the locks2) There should be a volume control, either a POT or a menu3) With a PC yes, with JAMMA standard PCBs, no4) new panel5) a lot of vertical shooters could but I'd prefer it if yuo didnt rape that cab.6) No, its a 2 in 1 PCB by NAMCO7) Doesnt work that way, you'd have to buy a converter(upscaler) and even then it doesnt work the way you think it does. The picture would be sideways9) Turn the monitor10) JAMMA switcher, or moving the edge connector manually.Sounds like the machine is nothing what you wanted.Where are you located, Im sure one of use could trade you a cab or something, to get you something we want and you want.
arcade monitors dont run at the same refresh or resolution as LCDs. so you'd have to get a upscaler and in all honesty the picture wont look as good as the arcade monitor. For what you want , your best bet is to just start building a MAME cab and go from there. Then you can run a PC to the LCD and the Wii if you want. Then you can switch between the 2 using a simple remote control. If you wanna MAME it up I have a KI1 machine that I'd trade you with a JPAC for that mspacman/galaga =)
I wish I had a decent manual for this so I could verify if that is a Std Res or VGA monitor (I think it is Std Res, but can't seem to confirm it), but dropping in a widescreen LCD would be fraught with problems and is, sorry to say it, a really bad idea. In any event you need to figure out what kind of monitor you have in there before even considering doing anything, so we can save the technical discussion until then. Same thing with hooking up your Wii -- no point in having a discussion until we know what you actually have.You can rotate a the monitor, but it depends heavily on the cabinet and I don't know if you have the room in that cabinet for it.According to the schematics, it has a volume pot.http://www.namco.co.uk/PDF-manuals/namco-manuals/Ms_Pacman_Galaga_Cocktail_manual.pdfDrill the locks.You should also have PacMan in there, but need to know some sort of code to activate it.
Up, Up, Up, Down, Down, Down, Left, Right, Left, Right, Left on the game select screen for PacManLeft, Right, Left, Right, Up, Up, Up, Fire to turn on/off Fast Pac/Fast Shot
