Author Topic: Another possible "silly" question!  (Read 1207 times)
Si the Sigh
  • Last login:May 27, 2010, 07:20:16 am
« on: February 26, 2010, 05:13:07 am »
Another possible "silly" question coming up. I'm starting building this weekend (finally!), but I still have a few questions about choice of encoder. I'm planning on running the following on the control panel:
2 x 8 way joysticks, with 7 buttons per player,
1 x 4 way joystick, with 2 buttons,
1 x trackball
Plus coin, start & other admin buttons.
Pretty much a copy of this one without the spinner & an extra button for each player:
Got an IPac2 on order (the one with 32 inputs), but I assume it doesn't take the trackball? What's the best encoder to run a trackball? Can I put 2 encoders under the hood and into my PC?
Thanks in advance!
« Last Edit: February 26, 2010, 05:20:15 am by Si the Sigh »
TOK
  • The Game Always Wins
Re: Another possible "silly" question!
« Reply #1 on: February 26, 2010, 05:25:39 am »
Yes, you will need either a separate encoder or a USB trackball. It will be standalone from your IPAC.
I used a Happ USB trackball and its been flawless, though some people have had problems with the optical sensors on them.
Si the Sigh
« Reply #2 on: February 26, 2010, 05:49:18 am »
Ok thanks for the info. If I was to use a seperate encoder, what's a good one to use (just for a track ball?)
ubiquityman
  • Last login:May 06, 2016, 10:57:58 pm
« Reply #3 on: February 26, 2010, 07:39:46 am »
The lowest cost encoder that I've seen is the Optiwiz.
If you are ordering and IPAC, you might ask Ultimarc if they will ship you a trackball encoder for $14.
I originally looked at having separate 4way and 8way joysticks, but the Ultrastik360 will do all that, and IMHO is more convenient.
Plus being analog, it'll provide a more accurate signal for games that can take advantage of analog inputs.
You should really have a look at that.  For the difference in $ and the amount of time you're getting yourself into, it's well worth it.
