Author Topic: Sega Saturn (SSF) and Mala?  (Read 4708 times)
iAtoria
  • Last login:August 06, 2019, 10:02:33 am
  • 01101110011001010111011101100010
    • iAtoria
« on: February 25, 2010, 06:00:56 pm »
I was just wondering if this was even possible?  I know that there are command line prompts for ePSXe and such, but I can't seem to get this emulator up and running in the "Other Emu" section.  Any help would be greatly appreciated . . . Panzer Dragoon Saga FTW!
qlunch
  • Last login:June 15, 2023, 08:55:09 am
Re: Sega Saturn (SSF) and Mala?
« Reply #1 on: February 27, 2010, 12:15:17 pm »
This isn't super clean but it works...
Here's the AHK script I use
Code: [Select]
blockinput on
rom := %0%
run, cmd.exe
winwait, C:\WINDOWS\system32\cmd.exe
send cd \Program Files\DAEMON Tools Lite\{enter}
send daemon.exe -mount 0, "C:\Documents and Settings\Owner\Desktop\Arcade\SSF_010_beta_Type2\roms\%rom%"{enter}
winwait, DAEMON
winwaitclose, DAEMON
run, c:\documents and settings\owner\desktop\arcade\ssf_010_beta_type2\ssf.exe
winkill, C:\WINDOWS\system32\cmd.exe
blockinput off
winwaitclose, SSF
Obviously you'll have to change your directories in the code above. Also launch SSF make fullscreen then close, it will remember to launch fullscreen next time and as long as the game is mounted before launch it will autoplay.
Compile as launch.exe (or whatever you want) and use: launch.exe "rom name.extension"
The only thing that I'm still having trouble with is that some games when mounted pop up with an windows autoplay menu that will take focus away from ssf. Anyone know how to disable these?
Hope this helps
iAtoria
    • iAtoria
« Reply #2 on: March 01, 2010, 05:59:21 pm »
wheeeewwwwweeeee!
That's a lotta configurationoni and cheese.  Hmmm, let me digest your code there for a little bit and see if I can get it to configure with the Mala presets (ie go into Mala and change settings then poof it works).  Thanks for the input!
