Author Topic: Best Place / Material for Printing? Aluminum?  (Read 1928 times)
yo1dog
  • Last login:November 12, 2024, 04:38:47 pm
    • MikeArcade
« on: February 22, 2010, 02:21:25 pm »
I was wondering what the best material to print on is. Also if there is a good place to get it printed from. I found this site that will let you print on an aluminum sign. Think that would work well?
Here is the site:
http://www.javasigns.com/dt-design/268225-5582
Thanks,
 - Mike
garnerb350
    • Hyperspin
Re: Best Place / Material for Printing? Aluminum?
« Reply #1 on: February 22, 2010, 09:06:25 pm »
Ive seen that material before...its basiclly thin sheet of aluminum glued to foamcore...(in a sense)....only problem with that is that you wont have any light to shine through if your marquee ( is that what u want to be printed?) has a light source...The aluminum types are best for exterior signs...
For marquees, ask for a blacklight vinyl type...( ive seen them printed on regular paper)...your sideart and or control panels can use vinyl with adhesive backing....CP depend on also if you want a pexiglass overlay...
check out mamemarquees.com and check your local print shop ...they can give you ideas on what is best for ya...
