Author Topic: Polo 2/25 Wont sync 24kz  (Read 1725 times)
akastaff
  • Last login:May 09, 2014, 03:53:55 am
« on: February 22, 2010, 06:19:04 am »
Got a Sega Rally which is medium res but when I use a this Polo 2/25 I have it is way out of sync and I presume it is only running in 15kz, I thought the Polo 2/25 chassis auto switched..
Can see picture no problem but the scan rate is all wrong..
Any help, surgestions welcomed.
Thx
grantspain
Re: Polo 2/25 Wont sync 24kz
« Reply #1 on: February 22, 2010, 01:23:09 pm »
some polo 2 are manual switch using a jumper plug near the psu cage
akastaff
« Reply #2 on: February 23, 2010, 09:29:29 am »
Cannot see anything on it, the labeling does not mention Auto or anything to indicate dual res which makes me think it is 15kz only but didnt know the POLO 2 range had only 15kz.
grantspain
« Reply #3 on: February 23, 2010, 01:08:17 pm »
if its an auto switching chassis then there is an extra board standing vertical in the psu cage-if its manual switching there is a 4 pin jumper plug(green)'
i am not aware of any polo 2 15khz only
