Author Topic: act labs trigger  (Read 1280 times)
pinballwizard79
act labs trigger
« on: February 21, 2010, 12:41:56 am »
Any help would be appreciated in regards to this.
Yeah so I calibrated this act labs gun right...& it works great except for the trigger  ;D
I go into MAME to map all controls & tell the thing that the trigger is button one (after button one works to shoot) but then the trigger does nothing.
Has anyone else run into this?
How do I map the trigger as the fire button?
thanks in advance  :cheers:
Drews Arcade
  • Last login:July 28, 2018, 01:15:02 am
Re: act labs trigger
« Reply #1 on: February 21, 2010, 08:36:22 am »
Yup, got the same thing, this is what I did that fixed mine.
http://www.act-labs.com/LightGunSetUp/LightGunSetUp.htm
  • Last login:Today at 08:14:47 am
« Reply #2 on: February 21, 2010, 09:04:08 am »
Are you pointing it at the screen when you map it?
On mine, the trigger shows up as Gun Button 0 if pointed at the screen (this is what you want).
If you have it pointed offscreen, it shows up as Gun Button 1 and doesn't work to fire.
