Author Topic: Arcade monitor horiz. to vert. for jamma..  (Read 1696 times)
Twizted
  • Last login:September 20, 2003, 01:15:31 am
« on: July 25, 2003, 06:22:54 pm »
I have an old WG4901 that is in my Stargate machine (not at the moment, waiting on cap kit) and I would like to test out and play some of my Jamma and other  games but some are vertical.
Is there a specific way to wire this up to play arcade pcb's vertically? Like Ring King and Capcom Bowling.
I read a post that said if you just mount it vertically it will display vertically.
Can this be right?
How could it tell the difference?
Any help is appreciated!
I would like to use the monitor for a while with incoming games while I restore the Stargate cabinet.
Too bad it didn't come with the boards in it! >:(
I have to wait it out and but them on ebay for an insane (over $100 so far) amount of money for the boards.
Thanks :P
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Arcade monitor horiz. to vert. for jamma..
« Reply #1 on: July 25, 2003, 07:35:14 pm »
There's NOTHING you'd need to do electronically...
You could either rotate your head, or rotate your monitor =P
The only diff between a vert monitor and a horizontal monitor is the mounting...  so prop that bad boy up and play some galaga or something =P
Good luck!
Rampy
OSCAR
    • Oscar Controls
« Reply #2 on: July 26, 2003, 12:13:30 am »
I concur with rampy.  Nothing at all needs to be done to your monitor to display vertical games, other than placing your monitor into a vertical orientation.  There is a bit of overlap in terminology between horizontal games and horizontal monitors.  A horizontal game expects the long dimension of the monitor to be horizontal, where a vertical game expects the long dimension of the monitor to be installed vertically.
When most people make mention to a "horizontal monitor", that only refers to the frame style of the monitor.  Horizontal monitors typically have a wedge-shaped frame with handles, and then there are "universal" mount monitors that have a flat bar cage around the back of the tube.
Actually, horizontal mount monitors seem to be more common and easier to install because all they need is a shelf to bolt them to, regardless if they are mounted in a horizontal or vertical orientation.
Horizontal mount:
Universal mount:
original Tempest vertical monitor (horizontal mounted sideways):
Twizted
« Reply #3 on: July 28, 2003, 04:45:06 pm »
Okay I guess I wasn't thinking! :P
The pcb actually dictates the orientation of the game play. I understood that the monitor could be turned but couldn't figure out how to make game turn too!!
Kinda thinking along the lines of mame! ::)
As soon as I get the cap kit and transformer I'll be playing many original games at full speed!!
