Author Topic: New modular panel pics, also could use some help  (Read 6043 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: August 17, 2003, 12:11:53 am »
I'm finally finishing some modules for my modular panel.  It's taken
way longer than I expected to get this done.  I'm hoping it's worth it.
What I need some help with is finding lower profile screws ( more
like carriage bolts ).  Since I'm using standard rack mount parts
they have to be 10/32.
I am also having a hard time with air bubbles and the Happs pica vinyl.
I am not very artistic so this is the stuff I use.  Speaking of artistic ability
I'm also looking for someone ( heck I'd even pay ) who can modify some
Defender artwork for me.  I've had two people offer but they didn't
pan out.
Anyone else have modular panels?  How are they working out for you?
This is the marble madness layout:
This is the Robotron layout ( it's even *very* close to the 10" spacing in the arcade ).
« Last Edit: August 23, 2003, 05:50:00 pm by telengard »
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:New modular panel pics, also could use some help
« Reply #1 on: August 17, 2003, 12:45:54 am »
Sweet, dude!
Here's a pic of mine...  Making it look nice is a way last priority for me...  (I've still got a lot of work to do - I'd like to make a 4 player version and to clean up the wiring before I would bother making it look better).
Mine is mounted onto wood, so as 1UP suggested once, I just used wood screws to screw joysticks into the underside of the module, so I don't need no ugly bolt poking up.
For the trackball, I couldn't see a good way around it, and it turns out to be a good thing because my trackballs aren't mounted perfectly straight...  Even if they were, it would still be nice to have the bolts as a guide to where "up/down/left/right" are aligned.
Can't help you with the artwork...
Perfectly...  I wouldn't go any other way...  The only games that are important to me that I'm missing right now are Karate Champ Vs, 4-Player Warlords (4 spinners), and 3 player rampart (3 trackballs)...  Might as well throw in 4 player soccer/football (4 trackballs) while I'm going modular!
After a visit the the Funspot arcade in New Hampshire last weekend, I think I've got a good idea for compressing a 4 player modular panel into as small a space as humanly possible while remaining comfortable AND still allowing for a perfectly fine Karate Champ Vs. layout.  I'll draw up an ugly picture and post it here.
telengard
    • S T U R C A D E
« Reply #2 on: August 17, 2003, 12:54:40 am »
Sweet, dude!
Very cool indeed.  I live near Funspot too.  I took tons of measurements last time I was there.
I want to do a karate champ layout too, it shouldn't be too hard although I don't have
4 4-way leafs yet.
Yeah looks aren't the biggest deal to me but I am very envious of the folks on here
with exceptional artistic ability.  The only creative thing I've done is made some
patches for advancemenu.   :P
That 720 degrees panel is sweet.  I gotta pick one of those controls up on eBay...
That and a tapper handle.   I've got way too many controls as it is.   :)
My trackballs aren't perfect either.  The modules are 1/8" aluminum blank rack mount
panels.  The thickness means the lip around the trackball isn't totally flush which is
not too bad.  The modules are rock solid though, no slipping or anything.
I'll be curious to see your Karate Champ layout.  Next up for me is a Defender layout.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: August 17, 2003, 02:35:06 am »
Hmmm, I dunno, maybe it'll need more thought...  But this is the idea:
http://jstookey.com/images/cp_panels.jpg
Every joystick has the same alignment...  It would be great for Karate Champ...  For 4 player games, I'll just have to build it and find out what's wrong with it!
The nice thing about a modular panel is that so much work goes into the modules that building and rebuilding the main panel seems pretty easy!
« Last Edit: September 27, 2006, 12:27:42 am by jerryjanis »
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #4 on: August 17, 2003, 03:22:24 am »
Well I just vectorized a defender control panel.  What did you need done while I am in the Defender mode?
Next I'll be on fries, and that's when the big money starts rolling in.
telengard
    • S T U R C A D E
« Reply #5 on: August 17, 2003, 01:08:41 pm »
Well I need vectorized versions of the sideart and marquee ( someone had these
but I can't get in touch with him now ).  I'd like the text on both of them
changed from "DEFENDER" to "STURCADE".  I'm no photoshop guru so that's
pretty hard for me to do.
I'd appreciate any help you could give me.     :)
Nannuu
« Reply #6 on: August 17, 2003, 01:40:09 pm »
If you have a good rasterized version I could copy from that would save me a lot of time looking :)
telengard
    • S T U R C A D E
« Reply #7 on: August 17, 2003, 04:57:21 pm »
Hehe, I believe I do.  I will dig them up and put them up on my web space.  Just curious,
what are you doing w/ the vector'ed cp artwork?
telengard
    • S T U R C A D E
« Reply #8 on: August 17, 2003, 09:47:41 pm »
Ok, I've put up the pdf I have that is a bunch of defender stencils.  The marquee
is up top.  If you can't extract what you need from it let me know.
http://users.adelphia.net/~bsturk/defenderstencil.pdf
thanks a bunch
Apollo
  • Yes You Can Have A Custom Title
  • Last login:May 27, 2021, 10:49:02 pm
    • Eight Bells
« Reply #9 on: August 17, 2003, 10:01:25 pm »
I also need vectorised versions of the Defender front and side art. I have PM'd you can you let me know if you are going to do it?
Thankyou.
Nannuu
« Reply #10 on: August 18, 2003, 12:19:30 am »
I'm making a Defender/Stargate control panel for a friend.  I used Jake Stookey's jpeg as a model
http://link.mywwwserver.com/~jstookey/arcade/defendercp/defendercp.html
then changed it around on the right and left side to more closely match others I've seen.  I kept his button layout so that Stargate can be played as well and coins can be added.  I will come back to it in a few days for more tweaking as I tend to catch more mistakes by giving myself some days off.  And I haven't put the stars on yet either.  When I get it to where I want it I'll post the eps file on my site.  If anyone is interested in a file without the two extra buttons I'll make another file for that as well.
It'll probably take me a week or so to mess around with it.
telengard
    • S T U R C A D E
« Reply #11 on: August 18, 2003, 01:17:37 pm »
Good job on the artwork, looks great.  That font on your site
will come in handy too.
Hehe, I was thinking I would like it with the inviso but without
the 25 cents.  I'm not sure that I can find a 10U blank panel to make a complete defender module though.
Is that pdf file going to work OK for you?  If not I can dig up some other pics.
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
« Reply #12 on: August 18, 2003, 03:29:19 pm »
Modular is a great idea.  I'll have to consider this when buiding my next cab.
SirPoonga
  • Puck'em Up
  • Last login:September 07, 2025, 04:58:47 pm
  • The Bears Still Suck!
« Reply #13 on: August 18, 2003, 07:08:58 pm »
I've been thinking of a modular design for my second CP.  It will be like this.  Each control will be on a standard module.  The modul will be 1,2, or 3 units wide.  I will have 1 unit spacers.  A trackball will end up taking 3 units.  a joystick 1 unit, 6 buttons 2 units.  I plan on holding it down like jelloslug does.
The hole in my CP will probably be 10-12 units wide.
telengard
    • S T U R C A D E
« Reply #14 on: August 19, 2003, 01:09:27 am »
Sounds like a good plan.  I did some work tonight and am getting excited about trying
it out.  What did jelloslug use for holding it down?  Is it sturdy?
Nannuu
« Reply #15 on: August 19, 2003, 01:42:54 am »
That file should work just fine.  Is that the same file everyone uses as their paint stencil?  If so, I'm assuming it is detailed enough?
As simple as the Defender art is (yellow and red).  It would be a lot cheaper to just break that into two eps files, take it to a sign shop and have them cut yellow and red vinyl.  Vinyl is easy to apply and extremely durable.  Printing is much more expensive.  I'll do the sideart, marquee and front art no problem, just a suggestion (but this will look a tad less authentic given the edge of the vinyl).
When I make the eps file I will fill the surrounding  area with black to print as well so when you apply to your cabinet I guess you can either fill the entire side to make it uniform or cut around what you want and risk the black print being shades off of your cab.  Deoh, this now leads to another question:  Do you want just a very large rectangular shape, the shape/size of a standard Defender cab, or create an contour around the artwork that you could cut to?
I'll also do three versions of the cp.  1) What I have done 2) With no 25 cent 3) With no 25 cent or Invisio
What size is a standard marquee?  Or more importantly, your marquee?  I will slightly oversize just in case so you don't have a chance of light showing.
Sorry sorry sorry, highjacking the thread here!
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #16 on: August 19, 2003, 12:54:23 pm »
http://jstookey.com/arcade/defendercp/defendercp.html
Hey, when you are done can I add your cleaned-up version to my web site (with due credit, of course)?  Looks good!
-Jake
« Last Edit: September 27, 2006, 12:43:42 am by jerryjanis »
telengard
    • S T U R C A D E
« Reply #17 on: August 19, 2003, 04:40:19 pm »
Dunno, I got this from someone way back.  It seems
detailed enough to me but just a little smaller.  The
marquee seems big enough too.  I'm no expert on
graphics and stuff so for all I know this might not
be enough.
Either way is OK with me.  Whatever is easier for you.
Being durable is definetly a good thing.  I had my
current artwork printed and then laminated and I
don't like how it looks and it's peeling off.  :(
The rectangle sounds fine.  I don't have exact measurements of my cab ( but I can take some ) the
link below has pics of my cabinet if that will help any.
Cool!  I just order 2 5U panels so I'm going to use them
to make a Defender only panel.  I already have the 2 way and translucent buttons.  Thanks for doing this.
My marquee is  23 5/16" X  6 5/8".  Not sure if this is a standard size of not.  I made my original marquee 2331x662 for 100DPI, not sure if that was correct either.  It's been quite a while.
Nannuu
« Reply #18 on: August 20, 2003, 02:24:11 am »
-Jake
Sure!  I'm sure glad you'd done it before me.  I couldn't find any pics that weren't from some strange angle.
Nannuu
« Reply #19 on: August 20, 2003, 02:31:23 am »
Telengard,
  I'll get to it then!  Lot's'o'files to make.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #20 on: August 20, 2003, 02:55:35 am »
Yeah, I was surprised to only find a very few pictures and they were all poor quality or at a bad angle...  I wasn't looking for much, but even still I had to slap together a lot of different bits and pieces and draw some myself...  Man I hate drawing.
Anyway, I don't know if it would help you, but here are the pictures that I used.
http://link.mywwwserver.com/~jstookey/arcade/defendercp/lotsapix/
telengard
    • S T U R C A D E
« Reply #21 on: August 20, 2003, 06:36:39 pm »
Telengard,
Nannuu you are "da man".  Much appreciated!
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #22 on: August 20, 2003, 11:56:48 pm »
If it helps......
If you build a frankenpanel, chances are I don't care for you as a person.
telengard
    • S T U R C A D E
« Reply #23 on: August 21, 2003, 01:29:58 pm »
If it helps......
Hehe, this makes me now want to also change my
glass bezel.  I doubt the "front" artwork would
fit on my cabinet.  I have a sente cab with a Pac-Man
coin door I believe.
SirPoonga
  • Puck'em Up
« Reply #24 on: August 23, 2003, 12:56:39 am »
Look carefully, he has rails in the big hole.  With an openning in the middle.  Then hooks under each module that is secured when run along the rails.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #25 on: August 23, 2003, 01:51:49 am »
 a Defender layout.
could you also measure the key deminsions of some complete classic cabs. Then we could make the 3dmodels more accurate because for most of them bo exact dimension of the relevant parts was availalbe when we made most of them...i was planning to visit retrokade in the uk and take detailed measuremnts of most classic cabs when i was in the uk last week bit it sadly did not went through... >:( so if you or someone else could make some that would be great  :)
peter
telengard
    • S T U R C A D E
« Reply #26 on: August 23, 2003, 03:04:56 pm »
Ahh, I think he had sent me his pics a long time ago.  I just realized those were from
jelloslug.  I have rails also but I screw the modules down.  I really wanted something
solid.  I didn't seem like the tab would be sturdy enough although I've never tried it.
I tend to be a little too rough on games like Robotron and Time Pilot.    :)
telengard
    • S T U R C A D E
« Reply #27 on: August 23, 2003, 03:07:35 pm »
 a Defender layout.
peter
Definetly!  Just let me know which cabs you'd like me to take measurements of.  Here's
the list of games they have ( not sure if it's 100% up to date though ):
http://www.funspotnh.com/gms-classic.htm
I'm hoping to go in the next few weeks once the weather around here cools down
a little.
SirPoonga
  • Puck'em Up
« Reply #28 on: August 23, 2003, 04:42:43 pm »
Well, you don't pull up on controls too much, jut have joystick controls to really worry about.
telengard
    • S T U R C A D E
« Reply #29 on: August 23, 2003, 04:56:20 pm »
Very true.  Joysticks are the only thing I was worried about too.  I have friends
who are even tougher on joysticks, especially when playing the new "fighter"
type games.  I didn't want to chance it so I went with modules I could lock down
hard.
One advantage I see w/ jelloslug's method is not having to deal w/ screws like I do.
The worst panel I figured is something like Robotron, 2 controls + buttons.  To get the exact spacing I had to use a lot of 1U blank panels.  I finally got around to playing a game of Robotron earlier today and the new modules are just as sturdy and solid as my swappable panels so I'm psyched.
I also didn't notice the screws while playing.  I thought they would bug me but
I didn't even feel them.  As usual I stressed out over nothing.  I think lower profile ones will even be better.  I am **very** happy I did this.  It's easier to store, build, and swap controls now for me.  Plus I get the benefit of being able to play a lot of these games with their original ( or as close to it as I can get ) controls and layout.  Can't wait to build a little Vanguard button module.   :)
Gotta go... need to catch up on some gaming!  I've been working on this new panel
setup for waaaay too long.    ;D
)p(
« Reply #30 on: August 23, 2003, 05:03:13 pm »
a little.
for me personally i would like to see measrements of  the classics until about 1985. only for galaxian, defender and centipede i currently have detailed measurements...
peter
Howard_Casto
  • Idiot Police
  • Last login:Today at 12:42:07 am
    • The Dragon King
« Reply #31 on: August 25, 2003, 12:37:45 am »
I would like highly detailed plans of a stock midway mortal kombat cab.  But I also want a million dollars.
« Last Edit: August 25, 2003, 12:38:13 am by Howard_Casto »
Brax
« Reply #32 on: August 26, 2003, 12:54:51 pm »
