Author Topic: PS/2 to USB adapter  (Read 3320 times)
Dartful Dodger
  • Newer isn't always better.
PS/2 to USB adapter
« on: December 02, 2009, 08:32:41 pm »
I bought a Hagstrom KE72 years ago and it's a PS/2.
I'm going to buy a new(er) computer to put in a cabinet and the computers I'm looking at don't support PS/2. So I have a few questions:
How well do the PS/2 to USB converters work with keyboard encoders in MAME?
What issues if any will there be?
If you like your adapter, which one are you using?
Thanks,
DD
jasonbar
  • Dr. Inferno
    • The Infernolab
Re: PS/2 to USB adapter
« Reply #1 on: December 02, 2009, 09:22:26 pm »
I'm using a USB->PS/2 adapter for my setup kbd in my cab, going through the IPAC-4.
Just some generic cheap one that came w/ a mouse or keyboard or something--works fine.
-Jason
PS--I have a feeling that I'm missing the point of this question... :dizzy:
Dartful Dodger
« Reply #2 on: December 03, 2009, 01:01:00 pm »
No that's the point.  I'm worried there might be a delay, dropped/wrong keypresses or some other kind of issue if I was running it through an adaptor.
I haven't bought the computer yet, so if it would be a problem I'd narrow my options to a computer with a PS/2 input.
bkenobi
« Reply #3 on: December 03, 2009, 01:24:50 pm »
Or you could look at a new encoder.  I'd compare the cost of getting a legacy MB/CPU/etc with a current model + USB encoder.
Hoopz
  • Last login:April 26, 2026, 09:04:18 pm
  • Intellivision Rocks!
« Reply #4 on: December 03, 2009, 01:25:52 pm »
Andy has specifically said to not use an adapter with his I-Pacs.  FYI
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: December 03, 2009, 01:54:59 pm »
There are two types of ps/2 -> USB adapters.  One type works fine, the other sucks, but which type you can use depends on your encoder.
The type that works fine is "passive"; all it does is a simple pin/shape rewire, and relies on the encoder to be able to tell it's hooked to a USB vs a ps/2 and be able to send the matching protocol.
The type that sucks is for encoders that can't tell the difference, and thus has to translate the ps/2 protocol to the USB protocol.  Since the adapter is actively doing the translation and are designed for normal keyboard use, there are (usually) many limitations: number of buttons pressed at a time is very low, duration a button can be held down is short, etc.  The hotrod encoder is an example of encoders that only talk ps/2, so they suck at usb even with an adapter.
I don't know if the hagstrom KE72 can speek usb or not.  If it can't, then you're out of luck. :(
Robin
Knowledge is Power
Dartful Dodger
« Reply #6 on: December 03, 2009, 04:37:09 pm »
I bought it years ago when I first got the arcade building bug.  I bought a ton of odds and ends, but then when I started cutting the pieces for the cab I lost interest in finishing it.
I got the bug again now that a light gun is doable but I promised myself I wouldn't buy any more parts until I actually use what I got.
I paid over $100 for this encoder, back when I didn't have $100 to spend.  When I'm done there's going to be a pile of unused parts, but this encoder isn't going to be one of them.
This weekend I'll try and get a passive adaptor and test the encoder with my office computer.
(I guess I should have done that in the first place, but the voices in my head wanted me to buy an arcade computer this week)
