Author Topic: Portable Mortal Kombat machine/Mame cp (WIP)  (Read 4424 times)
Hunk_4TH
  • Last login:August 11, 2025, 07:03:04 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« on: December 25, 2008, 09:54:45 pm »
Hey guys this may sound and look corny (I'm no good at wood working etc..) so I took an old shelf piece to a computer desktop and created this. Though it's still a work in process. But I thought I'd show it off here as I'm working on it. Also I bought this CP top off of a fellow user here and plan on buying his MK board,jamma harness and psu soon to include in this project! The artwork is in bad shape but that's coming off and being replaced with MK 3
Hunk_4TH
Re: Portable Mortal Kombat machine/Mame cp (WIP Updated 1-07-2009)
« Reply #1 on: January 07, 2009, 11:32:26 pm »
Just got the rest of my buttons today and got all of the decals on. Now I just need an encoder. I'm leaning towards an X-arcade PCB because it comes with a wiring kit! Unless I can find an I-pac cheap which I really want.
Re: Portable Mortal Kombat machine/Mame cp (WIP)
« Reply #2 on: January 08, 2009, 09:13:46 am »
looks good, but I'd lose the start, MK3, and midway stickers. The start buttons are obvious, and the other kinda make it look  bad IMO. cut some grooves for red Tmolding and that'd be super Uber hot
Hunk_4TH
« Reply #3 on: January 08, 2009, 06:48:50 pm »
Hey thanks for the kind words! you're right about the Start,Midway and MK3 decals. I was just trying to get it as close as possible to the original MK3 cp. Though the P1 start and Midway sticker sort of got a little ruined while applying it. I do plan on getting some t-molding for it in the future once I get an encoder and get all of that wired up. Any more suggestions are welcomed!  :cheers:
beastathon
  • Last login:October 22, 2019, 02:55:53 pm
« Reply #4 on: January 08, 2009, 08:30:27 pm »
You really cleaned it up nicely, it's looking much better now. I also agree about the stickers, I think simpler is better.
Another suggestion if you're going to apply t-molding, cut an identical length of wood for the remaining side and it would look pretty damn close to an MK CP.
Hunk_4TH
« Reply #5 on: January 08, 2009, 08:46:51 pm »
Thanks for the suggestion beastathon! I do planning cutting a piece of wood identical to the other side. The t-molding slots will be pretty tricky as I don't own/have access to a router. Though luckly there is a slot in the middle of the CP top where the original t-molding went. I think it's turning out a lot better than I thought it would.
Jack Burton
« Reply #6 on: January 10, 2009, 11:02:10 pm »
Looking nice.  Do you plan on putting both a MK board and a PC in there?  I think you could squeeze the both in if you tried.  If you do then you will need to use a J-pac encoder.
Hunk_4TH
« Reply #7 on: January 11, 2009, 08:17:33 pm »
Thanks! Oh I do plan on putting the MK board in there and maybe a PC later? I want to get some sort of encoder like an I-pac or X-arcade PCB first to test everything out  :)
