Author Topic: My cab  (Read 11696 times)
shmokes
  • Don't tread on me.
    • Jake Moses
My cab
« on: August 14, 2008, 04:07:31 am »
Well . . . it's been a LONG time.  I started this cab years ago, but then I got ---my bottom--- into school.  I was working full time and going to school full time and just never seemed to find the time.  Then my wife got prego (planned) and that ate up even more.  But I buckled down a few weeks ago and have been hitting it hard and the end is finally in sight.  I was hoping to have it finished before school started again on Monday.  It'll be close, but I don't think I'll manage it.
At any rate, here's my project announcement.  7000 posts in and I'm finally going to have my very own arcade controls.  I'm not nearly as good as I should be about documenting everything as I go, but pictures are forthcoming.  There are a few experiments that I'm still working on and hoping they turn out.  I have no woodworking skills, so I rarely do things correctly.  I do them carefully instead and for the most part things tend to take a REALLY long time, but usually turn out reasonably well.  Sometimes it takes a try or two.  That's all for now.  Pictures soon.  I promise.
I don't know if he's still around, but I owe a big thanks to 1up.  I couldn't have done it without him.   ;)
Best Kid iPad Apps
ark_ader
  • I glow in the dark.
Re: My cab
« Reply #1 on: August 14, 2008, 08:31:40 am »
It doesn't matter when you build your cab.  You do it when you are ready, when you feel the need to get it off paper and onto the workbench.
If time is against you you could go modular.  Build your pieces in Ikea style, so if you make a mistake you don't have to start all over again.
I was real crap at woodworking when I first started, and my early creations were truly hideous, but you get better with experience.  If you are working with MDF, I suggest getting your local DIY store to cut the big pieces.  MDF is a messy product to work with.
So is it going to be a big cabinet, or a cool bartop?
Keep us posted!    :cheers:
shmokes
    • Jake Moses
Re: My cab
« Reply #2 on: August 14, 2008, 10:51:54 am »
It's a full sizer.  In spite of my inexperience, I'm quite proud of the way it's turning out.  It won't have the fit and finish of one of Mountain's creations, but I wouldn't describe it as hideous by any stretch of the imagination  ;D.  And what, besides Mountain's creations, have the fit and finish of Mountain's creations?   :cheers:
I believe that it will have a couple of noteworthy features, though.  I'm still ironing out the wrinkles, but I'm pretty optimistic that everything is going to come out.
Best Kid iPad Apps
Hemi
  • Banned
  • Last login:September 21, 2008, 08:41:21 pm
Re: My cab
« Reply #3 on: August 18, 2008, 07:51:00 pm »
You say you have no wood-working skills but yet you are starting a project made mostly of wood? Okay, good luck with that and I hope it works out for you.  ;D  :cheers:
Banned
mountain
  • Trade Count: (+9)
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
Re: My cab
« Reply #4 on: August 18, 2008, 08:52:07 pm »
I am sure you have picked up many good tips considering the amount of time you have logged here. I am looking forward seeing your "creation"  :cheers:
shmokes
    • Jake Moses
Re: My cab
« Reply #5 on: August 18, 2008, 09:56:19 pm »
Oh yes.  I've picked up many good tips.  Most importantly, I have been introduced to the router and pattern bits.  I've actually never used anything but straight bits in it so far (including flush trim and pattern/template bits), but it makes me swoon.  The router is the greatest tool on the planet.  Any time I need anything the slightest bit odd done I always seem to think of a way I can accomplish it with the router.  It's just so versatile.
Speaking of tips for the router, how did you get that perfect bevel around your subwoofer holes in the bottom of your cab?  Did you just use a circle jig and a big chamfer bit?  It's just so perfect that there's simply no way that you could have free-handed it or used a saw of some kind.
It's working out quite well, actually.  Like I say, I just read how to do something and then I'm very careful.  I don't get the ease and speed that only come with experience, but so long as I am very meticulous and measure 10 times, cut once, things have been turning out quite well.  I have a helluva time making squares.  My panels always seem to be slightly off, and then I shave it down a little and it ends up being off on the other side, so I shave that down and it ends up being off on the first side.  I'm terrible at it, but i just keep it up until it's good.  At this point things are coming together and if you didn't know any better you'd think that I do have woodworking skills.
Seriously, the project I undertook is far more ambitious than anything someone with no previous woodworking experience has any business getting involved in.  But you just keep at it and go slowly and figure things out and ask questions and think a lot.  If you don't know how to do something with math, you just eyeball it and then spend a couple hours sanding until it works.   ;D  No reason to let ignorance stop you from getting what you want.   :cheers:
Best Kid iPad Apps
mountain
  • Trade Count: (+9)
Re: My cab
« Reply #6 on: August 18, 2008, 10:30:37 pm »
You guessed it. The only freehand cutting was where I joined the two holes. I used a 3/4" 45 degree champfer bit after it was sanded smooth.
Now, post some pictures already.  :)
shmokes
    • Jake Moses
Re: My cab
« Reply #7 on: August 19, 2008, 12:34:53 am »
Okay . . . there's still quite a bit left to do, and I want to get the monitor mounted before I get a shot of the whole cab in its current state.  So I'll begin with the base.  The base is actually complete, but the mechanism it was designed for is not.  I'm still trying to locate the perfect machine screws for the project, which is proving to be tricky.  Anyway, I wanted to have a brake/gas pedal from a 270 degree wheel hidden inside the base of the cabinet, with a door on a barrister hinge that would swivel open along the top edge and then slide back into the cabinet.  You most commonly see barrister hinges on bookshelves with glass doors covering each shelf.  Here's a drawing of what I wanted to accomplish.
Best Kid iPad Apps
shmokes
    • Jake Moses
Re: My cab
« Reply #8 on: August 19, 2008, 01:01:37 am »
I found this barrister hinge at Rockler.com which looks like it will do the trick.  I used an existing set of plans for my cabinet, but I had to modify the base extensively to make it accommodate the racing pedals.  Not only did it have to be taller, but I actually want the pedals to be mounted inside the base and slide out on drawer rails, so I had to build something to attach the rails to.  Here's what I came up with.
Best Kid iPad Apps
shmokes
    • Jake Moses
Re: My cab
« Reply #9 on: August 19, 2008, 01:09:17 am »
I made a platform that the gas/brake pedal unit will mount to.  As you can see in the picture, the unit will sit right between the front, swivel casters in the base of the arcade cabinet.  The curved part of the platform is where the pedal unit will be mounted.  Behind that will be two 2x4s running the length of the platform on either side, on which the drawer slides will be affixed.  The platform you see there is made of 1/8" masonite, but I took it into a machine shop and had a duplicate made out of 1/8" diamond plate, so it's very sturdy.  In addition to being mounted on a heavy duty drawer slide, the whole platform will ride on magic sliders similar to these.  When a person is standing on the pedals, I don't intend for the drawer slides to bear much load.  The unit will sit on the floor, but just use the drawer slide to guide it smoothly in and out of its hiding place under the cab.
Best Kid iPad Apps
shmokes
    • Jake Moses
Re: My cab
« Reply #10 on: August 19, 2008, 01:18:50 am »
Built up some legs for the front casters to mount to, and mounted some non-swiveling cabinet wheels in the back.  Voila.  There's my base.  Like I said, I have all the pieces, but haven't mounted the pedals or drawer slides, so if anyone has ideas to make it better, or if you see something that might be a problem let me know.
Oh yeah . . . the cable that connects the pedals to the steering wheel is too short and must be cut.  I've never spliced wires before like this.  It's a pain in the ass.  For various reasons that I will get into later, I want a very clean splice; I don't want to use wire nuts.  So I'm trying to individually work each pair of wires together, solder it, then cover it with liquid electrical tape.  It is a long, messy, tedious process.  Surely there is an easier way.  FWIW, I'm splicing it with an ethernet patch cable.
That's it for tonight.  It's after 1 in the morning and I hardly got any sleep last night.  I'll try and give you a side-panel update soon.
Best Kid iPad Apps
jban4us
  • Last login:July 08, 2013, 12:06:49 pm
Re: My cab
« Reply #11 on: August 20, 2008, 12:01:47 am »
Are you not able to get some heat shrink tubing on there for some reason? It is about 2 or 3 dollars for a 3 foot piece, you can shrink it with a hairdryer if you don't have a heat gun, and it will probably be a lot faster and cleaner looking than the liquid stuff. Or if you have a nice crimping tool you could use butt connectors, although it would make the joint bigger.
shmokes
    • Jake Moses
Re: My cab
« Reply #12 on: August 20, 2008, 12:20:36 am »
I was going to use heat shrink over the whole cable, but I don't have any small enough for the 24 gauge wires inside the cable.  Maybe I should pick some up.  That would probably make my life a lot easier.  I wonder if Ace would have it, or if I'd have to find it at an electronics store.  I suppose there's Home Depot, too, but that's not very conveniently located.
Best Kid iPad Apps
mountain
  • Trade Count: (+9)
Re: My cab
« Reply #13 on: August 20, 2008, 06:14:52 am »
Lowes has a variety pack in the electrical tools section which includes 1/16" heat shrink.
Hemi
  • Banned
Re: My cab
« Reply #14 on: August 20, 2008, 08:17:13 pm »
If you seem to have a problem making straight cuts, at least measure it (if you're confident in your measuring) and take the measurements to Lowes or Home Depot and have them cut it all for you. I would imagine they would be able to get it straight for you.
Banned
shmokes
    • Jake Moses
Re: My cab
« Reply #15 on: August 20, 2008, 10:29:41 pm »
What, I can just take a sheet of MDF to Home Depot (or buy one) and say, "I need the following rectangles cut out of this:  26 1/2"x18", 26 1/2"x13", 26 1/2"x21" . . .," and they'll cut it out for me???
Best Kid iPad Apps
mountain
  • Trade Count: (+9)
Re: My cab
« Reply #16 on: August 20, 2008, 10:45:47 pm »
Sometimes, for a phenomenal fee.  ;D
I think the service is mainly for cutting down 4x8 sheets to a more manageable size.
« Last Edit: August 21, 2008, 06:51:30 am by mountain »
patrickl
  • Yo momma llama
    • PocketGalaga
Re: My cab
« Reply #17 on: August 21, 2008, 06:38:55 am »
I tried to have plywood sheets cut down to size, but indeed only to make it more manageable. The cuts were horrible and not really accurate enough to be used straight  away.
Maybe Home Depot does it more precise though (and with less splintering).
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
Re: My cab
« Reply #18 on: August 21, 2008, 08:32:56 am »
I've always got very "approximate" measuring when I have wood cut at Lowes or HD. I don't really think they're in the business of providing accurate cuts. Perhaps if you hand the guy a few bucks and let him know that you need precise measurements?
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
Hemi
  • Banned
Re: My cab
« Reply #19 on: August 21, 2008, 10:22:57 pm »
If you know how to talk to people properly and they have a saw and something to measure with, then yes.
Banned
shmokes
    • Jake Moses
Re: My cab
« Reply #20 on: August 21, 2008, 10:41:34 pm »
I don't mean to be rude, but I think that you're full of ---steaming pile of meadow muffin--- and have never done this.  I mean, I'm sure it's possible if you're at a Home Depot in a small town and happen to be talking to someone who actually knows what he's doing (I suspect that the average Home Depot employee is no better at cutting squares than I am), you might be able to talk your way into something like this.  But I think 99% of the time, no matter how smooth or sweet you are, you are not going to get someone to cut out all your panels for you all perfectly square-like.
Maybe I'm just cynical . . .
Best Kid iPad Apps
ivwshane
    • My first mame cab! (WIP)
Re: My cab
« Reply #21 on: August 21, 2008, 11:52:18 pm »
I don't mean to be rude, but I think that you're full of ---Cleveland steamer--- and have never done this.  I mean, I'm sure it's possible if you're at a Home Depot in a small town and happen to be talking to someone who actually knows what he's doing (I suspect that the average Home Depot employee is no better at cutting squares than I am), you might be able to talk your way into something like this.  But I think 99% of the time, no matter how smooth or sweet you are, you are not going to get someone to cut out all your panels for you all perfectly square-like.
I remember one time I went to home depot and had them cut a panel for me, I was never so scared in my life that the guy cutting the panel was going to hurt himself! With the first cut the board kicked back and flew off the jig!
bishmasterb
    • Bishopzone
Re: My cab
« Reply #22 on: August 22, 2008, 12:05:32 am »
I think all HDs and Lowes will do this, and cut pieces to spec. The problem is that the upright saw they use requires them to measure each cut individually (someone correct me if I'm wrong) because it doesn't have a fence (or they don't use it).
So even if they make careful measurements, each cut is going to be slightly off. Add to this the fact that the employee is typically making rough cuts, not finish cuts (so people can get stuff in their car, or tack up wallboard or something similar which doesn't require precision).
I bought from a specialty sheet-board shop when I lived in CA and they had a large tablesaw and fence setup, and would carefully measure and then cut all the like-sized cuts with the same fence setting.
I just don't think you'll get that precision from HD or Lowes.
BTW, for cutting sheet wood this is the most useful tool ever:
« Last Edit: August 22, 2008, 12:08:23 am by bishmasterb »
Hemi
  • Banned
Re: My cab
« Reply #23 on: August 22, 2008, 12:41:26 am »
That seems like a comment I would have gotten banned for, but I guess you've been here too long for the rules to apply to you. I actually don't mind this sort of talk since we are all adults, but I have to expect that when I say something somewhat questionable for it to be overlooked as well.
Banned
shmokes
    • Jake Moses
Re: My cab
« Reply #24 on: August 22, 2008, 09:05:23 am »
The moderators have been searching for a graceful solution to me for years.   :cheers:
Best Kid iPad Apps
Zakk
  • Last login:December 03, 2025, 03:14:35 pm
Re: My cab
« Reply #25 on: August 22, 2008, 09:17:14 am »
The HD here has "wall saws" which will make pretty accurate, straight cuts.  They will do one or 2 cuts for free, and the rest for $2  cut (actually I've never been charged for extra cuts).
I did a couple of cocktail cabinets and they did the ply perfectly.  Pretty neat setup actually, I wish I had one.
shmokes
    • Jake Moses
Re: My cab
« Reply #26 on: August 22, 2008, 09:51:02 am »
Hmmm . . . I'd have gone for $2 per cut in a heartbeat.  It would have saved me a ton of money.  And considering how much less scrap wood I would have produced it probably wouldn't have cost me anything either.
It looks like maybe I was being too cynical.  Sorry Hemi.   ;D
Edit:  Heh . . . that doesn't even make sense.  I meant to say that "it would have saved me a ton of time."
« Last Edit: August 22, 2008, 10:37:40 am by shmokes »
Best Kid iPad Apps
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re: My cab
« Reply #27 on: August 22, 2008, 10:14:06 am »
Shmokes was tactful albeit strong languaged. This is not a democracy. I will moderate this forum as I see fit.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
whammoed
  • Last login:Yesterday at 12:20:55 pm
  • Crack don't smoke itself
    • NiceMite
Re: My cab
« Reply #28 on: August 22, 2008, 10:38:10 am »
For plywood cuts: The panel saws HomeDepot and Lowes use are great for rips, but on crosscuts, it tends to chip out because they are using a general use blade.   It's better to do the cross cuts with a router or fine tooth blade.
massive88
Re: My cab
« Reply #29 on: August 22, 2008, 10:41:36 am »
I have brought a list of cuts to make out of big sheets at HD before, and they accomodated.
The accuracy is as good as the man making the cuts.  If you get involved with him, and hes a nice enough guy, you can get very accurate cuts.  They have measurements down the bottom of the board.  One guy that helped me, I told him how to rotate the boards to make my cuts all be on one side etc, and was very helpful.
I have also never been charged full price for my cuts.  I once did get charged some extra, but I had like 10 cuts done, and got charged for like 4 I think.
So far Ive only done MDF there though, dunno how well they work on ply.
Hemi
  • Banned
Re: My cab
« Reply #30 on: August 22, 2008, 10:48:30 am »
Look at you, arrogant, cocky, knowing you can get away with pretty much anything you like without having to deal with anyone telling you to calm down. Hell, the site owner just came in and let us know what you did was okay with him, but me calling a guy an SOB spelled out (SOB, not even the full effect of spelling out the words) in another thread took the owner exactly 20 seconds to come rushing in to tell me I may not be here long enough if I do not act better. Pfft!
Good luck with your project, man.
Banned
shmokes
    • Jake Moses
Re: My cab
« Reply #31 on: August 22, 2008, 11:23:57 am »
Look at you, arrogant, cocky . . .
I know . . . it's something else, isn't it?  The world is a crazy place.
p.s. Subtlety is your friend.  There is a difference between calling someone a ---steaming pile of meadow muffin---, and suggesting that someone is full of ---steaming pile of meadow muffin---.  Additionally, there's more to language than words.  For example, I might see someone's cab that I really like and say, "Where did you develop such incredible woodworking skills you son of a ---smurfette---?"  That would not even get a second glance from a moderator.  There are things like tone and context that are at least as important as the words themselves.
Plus, I've been here too long for the rules to apply to me.  I can get away with pretty much anything I like without having to deal with anyone telling me to calm down.  What can I say? ;D
Best Kid iPad Apps
Hemi
  • Banned
Re: My cab
« Reply #32 on: August 22, 2008, 11:32:03 am »
p.s. Subtlety is your friend.  There is a difference between calling someone a ---Cleveland steamer---, and suggesting that someone is full of ---Cleveland steamer---.  Additionally, there's more to language than words.  For example, I might see someone's cab that I really like and say, "Where did you develop such incredible woodworking skills you son of a ---smurf---?"  That would not even get a second glance from a moderator.  There are things like tone and context that are at least as important as the words themselves.
Thanks for that lesson. I will try to work around the rules in the future and find as many loopholes as I can to make it seem like my attitude is a good one when it's really not. Thanks!  :laugh2:
« Last Edit: August 22, 2008, 11:34:17 am by Hemi »
Banned
shmokes
    • Jake Moses
Re: My cab
« Reply #33 on: August 22, 2008, 11:43:51 am »
[sarcasm]
You're off to a good start.
[/sarcasm]
Best Kid iPad Apps
ark_ader
Re: My cab
« Reply #34 on: August 22, 2008, 12:22:39 pm »
Gee Shmokes should I enter this thread with all this muck flying?
Hemi:  Shmokes is BYOC institutionalized, you cannot change a person who has been in here for so long.  ;D
Shmokes:  Home Depot is pretty much cut and run, and like the others said, the cutting machine is vertical and basic.  I would use them to just cut straight slightly outside the marked areas so you can sand it later.
Is there no woodworking experts close to you that can make the necessary cuts, like cabinet makers or joiners, for a price make the cuts as a package?
My local DIY mom and pop store offers this type of work, so I do not get any breathing problems from the MDF.
I like what I see so far.
Keep going Shmokes I want to see a finished project from you sometime soon.  :cheers:
shmokes
    • Jake Moses
Re: My cab
« Reply #35 on: August 22, 2008, 07:00:23 pm »
An update is coming soon.  Maybe Sunday.  The project is really quite close to completion.  Unfortunately, school just started, so I'm back to having limited time.  But I just finished my last control panel, so I'll try to put that together tomorrow and have something big to show.
Best Kid iPad Apps
patrickl
  • Yo momma llama
    • PocketGalaga
Re: My cab
« Reply #36 on: August 22, 2008, 07:10:01 pm »
Are you using the pen?
shmokes
    • Jake Moses
Re: My cab
« Reply #37 on: August 23, 2008, 12:08:23 am »
Using it so far to take notes.  Nothing more yet.  I haven't reviewed anything yet, or anything like that.
Best Kid iPad Apps
pointdablame
Re: My cab
« Reply #38 on: August 24, 2008, 01:17:24 pm »
FWIW, the Home Depot near me says they will do cuts to spec, but I've yet to find someone there competent enough to do so.  I've tried twice with horrible results, but I will still have them cut very rough cuts to get the stuff in my car.  They can definitely make it more manageable, but it seems like my HD is not the place to go to for cuts to spec.
first off your and idiot
Hemi
  • Banned
Re: My cab
« Reply #39 on: August 29, 2008, 04:32:01 am »
Going to any place where they are idiots is generally not the place to go to no matter what you're looking to do. I generally would not say that one name brand of store is not worth going to because you found one idiot at one of the stores who was not smart enough to do what you needed.
Banned
