Arcade Collecting > Miscellaneous Arcade Talk
A N00B To JAMMA Needs Assistance
DJ Infinity:
So lemme get this str8 (you know I'm a lil slow) the on off switch can be wired to the same spot as the ac lines? Do I need 3 wires for it aswell or just two? Thank you for helping me :cheers:
Bleagh:
Something like this will work.
http://www.bleagh.com/switch-ac.gif
DJ Infinity:
Thank you!
so that other block that Bob Roberts had I guess acts as a splitter? so you could split off ac to the marquee correct? One more question and I think I have it. What gauge wire does one use for this? The guy at radio shack looked at me all goofy when I asked what gauge wire do you use for AC wiring.
TheDriver:
18 gauge wire should be fine, that's what I used. :)
