Arcade Collecting > Miscellaneous Arcade Talk
A N00B To JAMMA Needs Assistance
Bleagh:
Just leave the isolation transformer out and the rest stays the same.
What kind of power supply do you have?
DJ Infinity:
The Black Happs one. I was told also the inline fuse is not needed. Can someone put it in dummy terms. Step 1 do this etc. and give me a pic I could zoom in on or at least one I can see clearly. Thanx :cheers:
Bleagh:
If you want you can just put the field ground from the plug straight to fg on the power supply, and the other two on the ac/l and ac/n it doesnt matter which one goes on l or n as just make sure the ground (the big round pin on the bottom of the plug) goes to FG. and it will work.
http://www.bleagh.com/basic-ac.gif
not the best way to do it, but it will work.
DJ Infinity:
That much I gathered looking at my Blitz cab. Ok can you show me where the on off switch get wired to please? thank you :cheers:
Bleagh:
you can put a switch on either ac line, or both.
