Main > Software Forum
CPWizard v2.63 Released
Necro:
Is there a way to modify the CPWizard menu font, format, size, etc? It's a bit huge and out of place, style wise, on my cab.
Also, the new method for catching pauses - does it require a certain version of mame in addition to CPWizard 2.36+?
headkaze:
Unfortunately there is no way to change the font at this stage. I'll look into adding it when I have some time.
Necro:
Damn, ok...thought maybe I was missing some way the sub-screens or layouts could be configured. I'm sure if I could use a reasonable resolution it wouldn't be as bad, but Maximus Arcade is forcing me to use 1024x768...(long story, the tl;dr version is mirror cab w/win 7. Only frontend to do mirroring is Max Arcade on Win7 unfortunately - and it doesn't support resolutions above that).
headkaze:
What do you mean by "mirroring"? If you mean split screen for cocktails then GameEx can do that too.
Necro:
Literally making it look like it was in a mirror So... ------: looks like :------. Honestly, I'd love to use hyperspin but that requires a solution to the above also. (It's a mirror cab, so what you see is the monitor through a mirror)
And yes, GameEx does work but with how difficult it's themeing system is I abandoned it I believe. I'll need to take a look at it again. It definitely has some features I'd like to use...although the pricing scheme I'm a bit eh on.
