Main > Software Forum
CPWizard v2.63 Released
Pages: << < (115/145) > >>
NelsonPJ:
OK - I uninstalled CPWizard 2.21 and then installed CPWizard 2.37.  First thing I noticed is that 2.21 installs in C:\Program Files\CPWizard, but 2.37 installs in C:\CPWizard.  I'm sure this is nothing - and I could have picked a different install location.
I used the default settings and layout that came with 2.37 - the only thing I changed was set the show key from "L" to "P".  In MAME I've mapped the pause key to "L".  This way I can run CPWizard in the recommended method.  I also enabled verbose logging, and told CPWizard to start with the system.
v2.37 ran OK for a while - I noticed a big delay the first time I ran it, but then it was OK.  It felt slightly slower than 2.21, but not significant.  I did notice, however, that after pressing the "show" key that it shows the DOS box for the MAME executable for a split-second before switching to the CPWizard display.  I don't remember seeing this at all with 2.21.
After a reboot, however, things went bad.  First thing I noticed after the reboot was the task bar showing overtop my Mala layout.  Both Mala and CPWizard are set to start at boot time - but I never saw the task bar after a reboot running v2.21.  So maybe CPWizard is taking the focus?  Or maybe not... this could have been unrelated.
Then I picked a random MAME game (PacLand), and after it started I ran CPWIzard and "HiToText.exe" crashed!  I clicked "send error report" - so maybe that will get to the developer?  After dismissing the crash report, CPWizard ran normally.  Unfortunately after this, every time I ran a MAME game and started CPWizard, "HiToText.exe" crashed!  Even for games that previously worked before I rebooted.  I didn't see any log files for HiToText in the CPWizard directory.
In case it helps, here's my CPWizard log file:
--- Code: ---[336] 9/5/2011 7:34:48 AM: CPWizard v2.37
[336] 9/5/2011 7:34:55 AM: OS: Microsoft Windows XP Professional
[336] 9/5/2011 7:34:55 AM: Version: 5.1.2600
[336] 9/5/2011 7:34:55 AM: Build: 2600
[336] 9/5/2011 7:34:55 AM: RAM Total: 2048 MB
[336] 9/5/2011 7:34:55 AM: RAM Used: 465 MB
[336] 9/5/2011 7:34:57 AM: CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[336] 9/5/2011 7:35:07 AM: Video Card: NVIDIA GeForce 6200
[336] 9/5/2011 7:35:07 AM: Video Driver: 6.14.12.5896
[336] 9/5/2011 7:35:07 AM: Video RAM: 256 MB
[336] 9/5/2011 7:35:07 AM: Sound Card: SoundMAX Integrated Digital Audio
[336] 9/5/2011 7:35:07 AM: .NET: .NET Framework 1.1 Installed
[336] 9/5/2011 7:35:07 AM: .NET: .NET Framework 2.0 Installed
[336] 9/5/2011 7:35:10 AM: Initializing Display Manager
[336] 9/5/2011 7:35:10 AM: Initializing Program Manager
[336] 9/5/2011 7:35:11 AM: Reading Config
[336] 9/5/2011 7:35:11 AM: Initializing Main Menu
[336] 9/5/2011 7:35:11 AM: Initializing Layout Manager
[336] 9/5/2011 7:35:11 AM: Initializing Controls Data
[336] 9/5/2011 7:35:11 AM: Initializing Input Codes
[336] 9/5/2011 7:35:11 AM: Initializing Layout Maps
[336] 9/5/2011 7:35:11 AM: Initializing Game Info
[336] 9/5/2011 7:35:11 AM: Initializing History Dat
[336] 9/5/2011 7:35:11 AM: Initializing MameInfo Dat
[336] 9/5/2011 7:35:11 AM: Initializing Command Dat
[336] 9/5/2011 7:35:15 AM: Initializing Story Dat
[336] 9/5/2011 7:35:15 AM: Initializing HiToText
[336] 9/5/2011 7:35:18 AM: Initializing Artwork Manager
[336] 9/5/2011 7:35:18 AM: Initializing Mame Manuals
[336] 9/5/2011 7:35:21 AM: Initializing Emulator Manuals
[336] 9/5/2011 7:35:21 AM: Initializing Emulator OpCard
[336] 9/5/2011 7:35:21 AM: Initializing NFO Viewer
[336] 9/5/2011 7:35:21 AM: Initializing IRC
[336] 9/5/2011 7:35:21 AM: Initializing SendKeys
[336] 9/5/2011 7:35:21 AM: Initializing Mame Interop
[336] 9/5/2011 7:35:21 AM: Initializing Mame Manager
[336] 9/5/2011 7:35:21 AM: Initializing Emulator Manager
[336] 9/5/2011 7:35:21 AM: Initializing Keyboard Hook
[336] 9/5/2011 7:35:21 AM: Initializing Direct Input
[336] 9/5/2011 7:35:22 AM: Joystick 1: Ultimarc Ultra-Stik Player 1
[336] 9/5/2011 7:35:22 AM: Joystick 2: Ultimarc Ultra-Stik Player 2
[336] 9/5/2011 7:35:22 AM: Initializing MCE Remote
[336] 9/5/2011 7:35:22 AM: Initializing Input Manager
[336] 9/5/2011 7:35:22 AM: Initializing Profiles
[336] 9/5/2011 7:35:22 AM: Initializing Bezel
[336] 9/5/2011 7:35:22 AM: Reading Mame Data
[336] 9/5/2011 7:35:26 AM: Reading MiniInfo Xml
[336] 9/5/2011 7:35:29 AM: Mame Version 0.143
[336] 9/5/2011 7:35:29 AM: Reading Mame Ini
[336] 9/5/2011 7:35:29 AM: Initializing Mame Cfg
[336] 9/5/2011 7:35:29 AM: Initializing Mame Command Line
[336] 9/5/2011 7:35:29 AM: Reading History Dat
[336] 9/5/2011 7:35:31 AM: Reading MameInfo Dat
[336] 9/5/2011 7:35:32 AM: Reading Command Dat
[336] 9/5/2011 7:35:32 AM: Reading Story Dat
[336] 9/5/2011 7:35:33 AM: Reading All Mame Cfg's
[336] 9/5/2011 7:35:35 AM: Creating MainBitmap
[336] 9/5/2011 7:35:35 AM: CmdArg: -minimized Value:
[336] 9/5/2011 7:35:35 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[336] 9/5/2011 7:35:35 AM: Starting Mame Interop
[336] 9/5/2011 7:37:56 AM: OnMameStart (MameManager) -> OnMameStart
[336] 9/5/2011 7:37:56 AM: OnMameStart (MameManager) -> GameName: paclandm
[336] 9/5/2011 7:37:57 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[336] 9/5/2011 7:37:58 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[336] 9/5/2011 7:37:58 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,0
[336] 9/5/2011 7:38:07 AM: Show (ProgramManager) -> Show
[336] 9/5/2011 7:38:07 AM: Show (ProgramManager) -> Mame Running
[336] 9/5/2011 7:38:07 AM: Show (ProgramManager) -> Searching for Mame
[336] 9/5/2011 7:38:07 AM: FindMame (MameManager) -> Mame Running hWnd: 0x590298
[336] 9/5/2011 7:38:07 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[336] 9/5/2011 7:38:08 AM: FindMame (MameManager) -> Command Line: mame.exe paclandm
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Game Found: paclandm
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Getting Game Details
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Sending Pause Key
[336] 9/5/2011 7:38:08 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[336] 9/5/2011 7:38:08 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Minimizing Mame
[336] 9/5/2011 7:38:08 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x590298
[336] 9/5/2011 7:38:08 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65980
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Showing Layout Form
[336] 9/5/2011 7:38:08 AM: Show (frmLayout) -> frmLayout hWnd: 0x197128
[336] 9/5/2011 7:38:08 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x328152
[336] 9/5/2011 7:38:08 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x197128 (Preview)
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Show CP Only is False
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Exit To Menu is True
[336] 9/5/2011 7:38:08 AM: Show (ProgramManager) -> Display Mode is MainMenu
[336] 9/5/2011 7:38:09 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[336] 9/5/2011 7:38:09 AM: ShowScreen (ProgramManager) -> Resetting Menu
[336] 9/5/2011 7:38:56 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[336] 9/5/2011 7:38:56 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[336] 9/5/2011 7:39:14 AM: CPForm_FormClosing (frmLayout) -> Closing
[336] 9/5/2011 7:39:14 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65980
[336] 9/5/2011 7:39:15 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x590298
[336] 9/5/2011 7:39:15 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[336] 9/5/2011 7:39:15 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Show
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Mame Running
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Searching for Mame
[336] 9/5/2011 7:39:18 AM: FindMame (MameManager) -> Mame Running hWnd: 0x590298
[336] 9/5/2011 7:39:18 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[336] 9/5/2011 7:39:18 AM: FindMame (MameManager) -> Command Line: mame.exe paclandm
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Game Found: paclandm
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Getting Game Details
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Sending Pause Key
[336] 9/5/2011 7:39:18 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[336] 9/5/2011 7:39:18 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[336] 9/5/2011 7:39:18 AM: Show (ProgramManager) -> Minimizing Mame
[336] 9/5/2011 7:39:18 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x590298
[336] 9/5/2011 7:39:18 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65980
[336] 9/5/2011 7:39:28 AM: Show (ProgramManager) -> Showing Layout Form
[336] 9/5/2011 7:39:28 AM: Show (frmLayout) -> frmLayout hWnd: 0x262352
[336] 9/5/2011 7:39:28 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x328152
[336] 9/5/2011 7:39:28 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x262352 (Preview)
[336] 9/5/2011 7:39:28 AM: Show (ProgramManager) -> Show CP Only is False
[336] 9/5/2011 7:39:28 AM: Show (ProgramManager) -> Exit To Menu is True
[336] 9/5/2011 7:39:28 AM: Show (ProgramManager) -> Display Mode is MainMenu
[336] 9/5/2011 7:39:28 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[336] 9/5/2011 7:39:28 AM: ShowScreen (ProgramManager) -> Resetting Menu
[336] 9/5/2011 7:39:32 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[336] 9/5/2011 7:39:32 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[336] 9/5/2011 7:39:35 AM: CPForm_FormClosing (frmLayout) -> Closing
[336] 9/5/2011 7:39:35 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65980
[336] 9/5/2011 7:39:42 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x590298
[336] 9/5/2011 7:39:42 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[336] 9/5/2011 7:39:42 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[336] 9/5/2011 7:39:44 AM: OnMameStop (MameManager) -> OnMameStop
[336] 9/5/2011 7:39:44 AM: OnMameStop (MameManager) -> Success
[336] 9/5/2011 7:39:54 AM: OnMameStart (MameManager) -> OnMameStart
[336] 9/5/2011 7:39:54 AM: OnMameStart (MameManager) -> GameName: pacman
[336] 9/5/2011 7:39:54 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Show
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Mame Running
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Searching for Mame
[336] 9/5/2011 7:40:05 AM: FindMame (MameManager) -> Mame Running hWnd: 0x590036
[336] 9/5/2011 7:40:05 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[336] 9/5/2011 7:40:05 AM: FindMame (MameManager) -> Command Line: mame.exe pacman
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Game Found: pacman
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Getting Game Details
[336] 9/5/2011 7:40:05 AM: Show (ProgramManager) -> Sending Pause Key
[336] 9/5/2011 7:40:05 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[336] 9/5/2011 7:40:05 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[336] 9/5/2011 7:40:06 AM: Show (ProgramManager) -> Minimizing Mame
[336] 9/5/2011 7:40:06 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x590036
[336] 9/5/2011 7:40:06 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65980
[336] 9/5/2011 7:40:06 AM: Show (ProgramManager) -> Showing Layout Form
[336] 9/5/2011 7:40:06 AM: Show (frmLayout) -> frmLayout hWnd: 0x655880
[336] 9/5/2011 7:40:06 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x590034
[336] 9/5/2011 7:40:06 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x655880 (Preview)
[336] 9/5/2011 7:40:06 AM: Show (ProgramManager) -> Show CP Only is False
[336] 9/5/2011 7:40:06 AM: Show (ProgramManager) -> Exit To Menu is True
[336] 9/5/2011 7:40:06 AM: Show (ProgramManager) -> Display Mode is MainMenu
[336] 9/5/2011 7:40:06 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[336] 9/5/2011 7:40:06 AM: ShowScreen (ProgramManager) -> Resetting Menu
[336] 9/5/2011 7:40:10 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[336] 9/5/2011 7:40:10 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[336] 9/5/2011 7:40:14 AM: CPForm_FormClosing (frmLayout) -> Closing
[336] 9/5/2011 7:40:14 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65980
[336] 9/5/2011 7:40:15 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x590036
[336] 9/5/2011 7:40:15 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[336] 9/5/2011 7:40:15 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[336] 9/5/2011 7:40:17 AM: OnMameStop (MameManager) -> OnMameStop
[336] 9/5/2011 7:40:17 AM: OnMameStop (MameManager) -> Success
[336] 9/5/2011 7:40:30 AM: OnMameStart (MameManager) -> OnMameStart
[336] 9/5/2011 7:40:30 AM: OnMameStart (MameManager) -> GameName: xmvsfu
[336] 9/5/2011 7:40:30 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[336] 9/5/2011 7:40:54 AM: Show (ProgramManager) -> Show
[336] 9/5/2011 7:40:54 AM: Show (ProgramManager) -> Mame Running
[336] 9/5/2011 7:40:55 AM: Show (ProgramManager) -> Searching for Mame
[336] 9/5/2011 7:40:55 AM: FindMame (MameManager) -> Mame Running hWnd: 0x1310928
[336] 9/5/2011 7:40:55 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[336] 9/5/2011 7:40:55 AM: FindMame (MameManager) -> Command Line: mame.exe xmvsfu
[336] 9/5/2011 7:40:55 AM: Show (ProgramManager) -> Game Found: xmvsfu
[336] 9/5/2011 7:40:55 AM: Show (ProgramManager) -> Getting Game Details
[336] 9/5/2011 7:40:55 AM: Show (ProgramManager) -> Sending Pause Key
[336] 9/5/2011 7:40:55 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[336] 9/5/2011 7:40:55 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[336] 9/5/2011 7:40:55 AM: Show (ProgramManager) -> Minimizing Mame
[336] 9/5/2011 7:40:55 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x1310928
[336] 9/5/2011 7:40:55 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65980
[336] 9/5/2011 7:40:56 AM: Show (ProgramManager) -> Showing Layout Form
[336] 9/5/2011 7:40:56 AM: Show (frmLayout) -> frmLayout hWnd: 0x655924
[336] 9/5/2011 7:40:56 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x983250
[336] 9/5/2011 7:40:56 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x655924 (Preview)
[336] 9/5/2011 7:40:56 AM: Show (ProgramManager) -> Show CP Only is False
[336] 9/5/2011 7:40:56 AM: Show (ProgramManager) -> Exit To Menu is True
[336] 9/5/2011 7:40:56 AM: Show (ProgramManager) -> Display Mode is MainMenu
[336] 9/5/2011 7:40:56 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[336] 9/5/2011 7:40:56 AM: ShowScreen (ProgramManager) -> Resetting Menu
[336] 9/5/2011 7:41:00 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[336] 9/5/2011 7:41:00 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[336] 9/5/2011 7:41:08 AM: CPForm_FormClosing (frmLayout) -> Closing
[336] 9/5/2011 7:41:08 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65980
[336] 9/5/2011 7:41:09 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x1310928
[336] 9/5/2011 7:41:09 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[336] 9/5/2011 7:41:09 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[336] 9/5/2011 7:41:10 AM: OnMameStop (MameManager) -> OnMameStop
[336] 9/5/2011 7:41:10 AM: OnMameStop (MameManager) -> Success
--- End code ---
NelsonPJ:
I've decided to uncheck "High Scores" and "My High Scores" to hopefully not get another HiToText crash.
I also noticed from the log file that CPWizard was trying to contact the default IRC client - maybe that would cause a delay? I unchecked that box, and also deleted all the IRC info from the IRC tab.
I then spent the morning recreating my layout in v2.37, and I'll try to stick with it.  I'll let you know if I get more crashes or excessive delays.
I did notice a delay when I called up CPWizard for the 2nd time in a row on PacLand.  I think this is shown in the log as a 10 second delay between 10:04:04 [MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65982] and 10:04:14 AM [Show (ProgramManager) -> Showing Layout Form]
[I'll post the code in the next window - too many characters for this message!]
PS: By the way, I love CPWizard!
NelsonPJ:
Here's that log window:
--- Code: ---[1088] 9/5/2011 9:53:12 AM: CPWizard v2.37
[1088] 9/5/2011 9:53:18 AM: OS: Microsoft Windows XP Professional
[1088] 9/5/2011 9:53:18 AM: Version: 5.1.2600
[1088] 9/5/2011 9:53:18 AM: Build: 2600
[1088] 9/5/2011 9:53:18 AM: RAM Total: 2048 MB
[1088] 9/5/2011 9:53:18 AM: RAM Used: 442 MB
[1088] 9/5/2011 9:53:21 AM: CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[1088] 9/5/2011 9:53:23 AM: Video Card: NVIDIA GeForce 6200
[1088] 9/5/2011 9:53:23 AM: Video Driver: 6.14.12.5896
[1088] 9/5/2011 9:53:23 AM: Video RAM: 256 MB
[1088] 9/5/2011 9:53:23 AM: Sound Card: SoundMAX Integrated Digital Audio
[1088] 9/5/2011 9:53:25 AM: .NET: .NET Framework 1.1 Installed
[1088] 9/5/2011 9:53:25 AM: .NET: .NET Framework 2.0 Installed
[1088] 9/5/2011 9:53:30 AM: Initializing Display Manager
[1088] 9/5/2011 9:53:31 AM: Initializing Program Manager
[1088] 9/5/2011 9:53:31 AM: Reading Config
[1088] 9/5/2011 9:53:31 AM: Initializing Main Menu
[1088] 9/5/2011 9:53:31 AM: Initializing Layout Manager
[1088] 9/5/2011 9:53:31 AM: Initializing Controls Data
[1088] 9/5/2011 9:53:32 AM: Initializing Input Codes
[1088] 9/5/2011 9:53:32 AM: Initializing Layout Maps
[1088] 9/5/2011 9:53:34 AM: Initializing Game Info
[1088] 9/5/2011 9:53:34 AM: Initializing History Dat
[1088] 9/5/2011 9:53:34 AM: Initializing MameInfo Dat
[1088] 9/5/2011 9:53:34 AM: Initializing Command Dat
[1088] 9/5/2011 9:53:38 AM: Initializing Story Dat
[1088] 9/5/2011 9:53:38 AM: Initializing HiToText
[1088] 9/5/2011 9:53:39 AM: Initializing Artwork Manager
[1088] 9/5/2011 9:53:39 AM: Initializing Mame Manuals
[1088] 9/5/2011 9:53:40 AM: Initializing Emulator Manuals
[1088] 9/5/2011 9:53:40 AM: Initializing Emulator OpCard
[1088] 9/5/2011 9:53:40 AM: Initializing NFO Viewer
[1088] 9/5/2011 9:53:40 AM: Initializing IRC
[1088] 9/5/2011 9:53:40 AM: Initializing SendKeys
[1088] 9/5/2011 9:53:40 AM: Initializing Mame Interop
[1088] 9/5/2011 9:53:40 AM: Initializing Mame Manager
[1088] 9/5/2011 9:53:40 AM: Initializing Emulator Manager
[1088] 9/5/2011 9:53:40 AM: Initializing Keyboard Hook
[1088] 9/5/2011 9:53:40 AM: Initializing Direct Input
[1088] 9/5/2011 9:53:41 AM: Joystick 1: Ultimarc Ultra-Stik Player 1
[1088] 9/5/2011 9:53:41 AM: Joystick 2: Ultimarc Ultra-Stik Player 2
[1088] 9/5/2011 9:53:41 AM: Initializing MCE Remote
[1088] 9/5/2011 9:53:41 AM: Initializing Input Manager
[1088] 9/5/2011 9:53:41 AM: Initializing Profiles
[1088] 9/5/2011 9:53:41 AM: Initializing Bezel
[1088] 9/5/2011 9:53:41 AM: Reading Mame Data
[1088] 9/5/2011 9:53:46 AM: Reading MiniInfo Xml
[1088] 9/5/2011 9:53:51 AM: Mame Version 0.143
[1088] 9/5/2011 9:53:51 AM: Reading Mame Ini
[1088] 9/5/2011 9:53:52 AM: Initializing Mame Cfg
[1088] 9/5/2011 9:53:52 AM: Initializing Mame Command Line
[1088] 9/5/2011 9:53:52 AM: Reading History Dat
[1088] 9/5/2011 9:53:53 AM: Reading MameInfo Dat
[1088] 9/5/2011 9:53:54 AM: Reading Command Dat
[1088] 9/5/2011 9:53:55 AM: Reading All Mame Cfg's
[1088] 9/5/2011 9:53:56 AM: Creating MainBitmap
[1088] 9/5/2011 9:53:56 AM: CmdArg: -minimized Value:
[1088] 9/5/2011 9:53:56 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 9:53:56 AM: Starting Mame Interop
[1088] 9/5/2011 10:01:50 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:01:51 AM: OnMameStart (MameManager) -> GameName: wacko
[1088] 9/5/2011 10:01:53 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:02:12 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:02:12 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:02:12 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:02:12 AM: FindMame (MameManager) -> Mame Running hWnd: 0x524484
[1088] 9/5/2011 10:02:12 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:02:12 AM: FindMame (MameManager) -> Command Line: mame.exe wacko
[1088] 9/5/2011 10:02:12 AM: Show (ProgramManager) -> Game Found: wacko
[1088] 9/5/2011 10:02:12 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:02:13 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:02:13 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:02:13 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x524484
[1088] 9/5/2011 10:02:13 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:02:13 AM: Show (frmLayout) -> frmLayout hWnd: 0x197122
[1088] 9/5/2011 10:02:13 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x262362
[1088] 9/5/2011 10:02:13 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x197122 (Preview)
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:02:13 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:02:13 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:02:13 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:02:14 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:02:14 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:02:42 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:02:42 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:02:42 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x524484
[1088] 9/5/2011 10:02:43 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:02:43 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:02:44 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:02:44 AM: OnMameStop (MameManager) -> Success
[1088] 9/5/2011 10:02:51 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:02:51 AM: OnMameStart (MameManager) -> GameName: wcbowl12
[1088] 9/5/2011 10:02:51 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:02:55 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:02:55 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:02:55 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:02:55 AM: FindMame (MameManager) -> Mame Running hWnd: 0x786628
[1088] 9/5/2011 10:02:55 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:02:55 AM: FindMame (MameManager) -> Command Line: mame.exe wcbowl12
[1088] 9/5/2011 10:02:55 AM: Show (ProgramManager) -> Game Found: wcbowl12
[1088] 9/5/2011 10:02:55 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:02:56 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:02:56 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:02:56 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x786628
[1088] 9/5/2011 10:02:56 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:02:56 AM: Show (frmLayout) -> frmLayout hWnd: 0x262652
[1088] 9/5/2011 10:02:56 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x524506
[1088] 9/5/2011 10:02:56 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x262652 (Preview)
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:02:56 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:02:56 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:02:56 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:02:56 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:02:56 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:03:18 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:03:18 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:03:19 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x786628
[1088] 9/5/2011 10:03:19 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:03:19 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:03:21 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:03:21 AM: OnMameStop (MameManager) -> Success
[1088] 9/5/2011 10:03:33 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:03:33 AM: OnMameStart (MameManager) -> GameName: paclandm
[1088] 9/5/2011 10:03:33 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:03:35 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[1088] 9/5/2011 10:03:35 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,0
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:03:40 AM: FindMame (MameManager) -> Mame Running hWnd: 0x1048772
[1088] 9/5/2011 10:03:40 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:03:40 AM: FindMame (MameManager) -> Command Line: mame.exe paclandm
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Game Found: paclandm
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:03:40 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:03:40 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:03:40 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:03:40 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x1048772
[1088] 9/5/2011 10:03:40 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:03:41 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:03:41 AM: Show (frmLayout) -> frmLayout hWnd: 0x524798
[1088] 9/5/2011 10:03:41 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x1048794
[1088] 9/5/2011 10:03:41 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x524798 (Preview)
[1088] 9/5/2011 10:03:41 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:03:41 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:03:41 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:03:41 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:03:41 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:03:41 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:03:41 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:04:01 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:04:01 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:04:02 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x1048772
[1088] 9/5/2011 10:04:02 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:04:02 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:04:04 AM: FindMame (MameManager) -> Mame Running hWnd: 0x1048772
[1088] 9/5/2011 10:04:04 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:04:04 AM: FindMame (MameManager) -> Command Line: mame.exe paclandm
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Game Found: paclandm
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:04:04 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:04:04 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:04:04 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:04:04 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x1048772
[1088] 9/5/2011 10:04:04 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:04:14 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:04:14 AM: Show (frmLayout) -> frmLayout hWnd: 0x786604
[1088] 9/5/2011 10:04:14 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x1048794
[1088] 9/5/2011 10:04:14 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x786604 (Preview)
[1088] 9/5/2011 10:04:14 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:04:14 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:04:14 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:04:14 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:04:14 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:04:14 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:04:14 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:04:25 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:04:25 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x65982
[1088] 9/5/2011 10:04:29 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x1048772
[1088] 9/5/2011 10:04:29 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:04:29 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:04:42 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:04:42 AM: OnMameStop (MameManager) -> Success
[1088] 9/5/2011 10:09:24 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:09:24 AM: OnMameStart (MameManager) -> GameName: tempest
[1088] 9/5/2011 10:09:24 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:09:24 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,1
[1088] 9/5/2011 10:09:24 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,1
[1088] 9/5/2011 10:09:25 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[1088] 9/5/2011 10:09:25 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,0
[1088] 9/5/2011 10:09:27 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:09:27 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:09:27 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:09:27 AM: FindMame (MameManager) -> Mame Running hWnd: 0x655914
[1088] 9/5/2011 10:09:27 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:09:27 AM: FindMame (MameManager) -> Command Line: mame.exe tempest
[1088] 9/5/2011 10:09:27 AM: Show (ProgramManager) -> Game Found: tempest
[1088] 9/5/2011 10:09:27 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:09:28 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:09:28 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:09:28 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:09:28 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:09:28 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x655914
[1088] 9/5/2011 10:09:28 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:09:29 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:09:29 AM: Show (frmLayout) -> frmLayout hWnd: 0x197252
[1088] 9/5/2011 10:09:29 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x524676
[1088] 9/5/2011 10:09:29 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x197252 (Preview)
[1088] 9/5/2011 10:09:29 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:09:29 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:09:29 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:09:29 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:09:29 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:09:29 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:09:29 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:09:48 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:09:49 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:09:49 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x655914
[1088] 9/5/2011 10:09:50 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:09:50 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:09:59 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:09:59 AM: OnMameStart (MameManager) -> GameName: tempest
[1088] 9/5/2011 10:09:59 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:09:59 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,1
[1088] 9/5/2011 10:09:59 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,1
--- End code ---
NelsonPJ:
And here's the 2nd half (too many characters for the last post)
--- Code: ---[1088] 9/5/2011 10:10:00 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[1088] 9/5/2011 10:10:00 AM: OnMameOutput (MameManager) -> OnMameOutput: led1,0
[1088] 9/5/2011 10:10:04 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,1
[1088] 9/5/2011 10:10:04 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[1088] 9/5/2011 10:11:03 AM: OnMameOutput (MameManager) -> OnMameOutput: led0,0
[1088] 9/5/2011 10:11:17 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:11:17 AM: OnMameStop (MameManager) -> Success
[1088] 9/5/2011 10:11:25 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:11:25 AM: OnMameStart (MameManager) -> GameName: irrmaze
[1088] 9/5/2011 10:11:25 AM: OnMameOutput (MameManager) -> OnMameOutput: digit4,10
[1088] 9/5/2011 10:11:25 AM: OnMameOutput (MameManager) -> OnMameOutput: digit2,10
[1088] 9/5/2011 10:11:25 AM: OnMameOutput (MameManager) -> OnMameOutput: blank,-1
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit1,10
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit3,10
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit0,10
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit0,63
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit1,63
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit2,63
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit3,63
[1088] 9/5/2011 10:11:26 AM: OnMameOutput (MameManager) -> OnMameOutput: digit4,63
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:11:44 AM: FindMame (MameManager) -> Mame Running hWnd: 0x787084
[1088] 9/5/2011 10:11:44 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:11:44 AM: FindMame (MameManager) -> Command Line: mame.exe irrmaze
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Game Found: irrmaze
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:11:44 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:11:44 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:11:44 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:11:44 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x787084
[1088] 9/5/2011 10:11:44 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:11:45 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:11:45 AM: Show (frmLayout) -> frmLayout hWnd: 0x459400
[1088] 9/5/2011 10:11:45 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x1180036
[1088] 9/5/2011 10:11:45 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x459400 (Preview)
[1088] 9/5/2011 10:11:45 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:11:45 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:11:45 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:11:45 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:11:45 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:11:45 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:11:45 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:12:01 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:12:01 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:12:02 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x787084
[1088] 9/5/2011 10:12:02 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:12:02 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:12:06 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:12:06 AM: OnMameStop (MameManager) -> Success
[1088] 9/5/2011 10:12:13 AM: OnMameStart (MameManager) -> OnMameStart
[1088] 9/5/2011 10:12:13 AM: OnMameStart (MameManager) -> GameName: tmnt2pj
[1088] 9/5/2011 10:12:13 AM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Show
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Mame Running
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Searching for Mame
[1088] 9/5/2011 10:12:29 AM: FindMame (MameManager) -> Mame Running hWnd: 0x918056
[1088] 9/5/2011 10:12:29 AM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=800,Height=600}
[1088] 9/5/2011 10:12:29 AM: FindMame (MameManager) -> Command Line: mame.exe tmnt2pj
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Game Found: tmnt2pj
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Getting Game Details
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Sending Pause Key
[1088] 9/5/2011 10:12:29 AM: PauseMame (MameManager) -> Sending Pause Message to Mame
[1088] 9/5/2011 10:12:29 AM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[1088] 9/5/2011 10:12:29 AM: Show (ProgramManager) -> Minimizing Mame
[1088] 9/5/2011 10:12:29 AM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x918056
[1088] 9/5/2011 10:12:29 AM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:12:30 AM: Show (ProgramManager) -> Showing Layout Form
[1088] 9/5/2011 10:12:30 AM: Show (frmLayout) -> frmLayout hWnd: 0x590360
[1088] 9/5/2011 10:12:30 AM: ForceForegroundWindow (HideDesktop) -> Foreground hWnd: 0x1442180
[1088] 9/5/2011 10:12:30 AM: Show (frmLayout) -> Success! Foreground hWnd: 0x590360 (Preview)
[1088] 9/5/2011 10:12:30 AM: Show (ProgramManager) -> Show CP Only is False
[1088] 9/5/2011 10:12:30 AM: Show (ProgramManager) -> Exit To Menu is True
[1088] 9/5/2011 10:12:30 AM: Show (ProgramManager) -> Display Mode is MainMenu
[1088] 9/5/2011 10:12:30 AM: ShowScreen (ProgramManager) -> Hiding Main Menu
[1088] 9/5/2011 10:12:30 AM: ShowScreen (ProgramManager) -> Resetting Menu
[1088] 9/5/2011 10:12:30 AM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[1088] 9/5/2011 10:12:30 AM: ShowScreen (ProgramManager) -> Showing MainMenu
[1088] 9/5/2011 10:12:47 AM: CPForm_FormClosing (frmLayout) -> Closing
[1088] 9/5/2011 10:12:47 AM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x197280
[1088] 9/5/2011 10:12:48 AM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x918056
[1088] 9/5/2011 10:12:48 AM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[1088] 9/5/2011 10:12:48 AM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[1088] 9/5/2011 10:12:50 AM: OnMameStop (MameManager) -> OnMameStop
[1088] 9/5/2011 10:12:50 AM: OnMameStop (MameManager) -> Success
--- End code ---
h0gg1e:
Has anyone ever bound multiple keys to one of the cpwizard commands? The default key to show cpwizard is "L" ... I'd like to make it SHIFT+Z ... in the program options is lets me set both keys but that makes it so that SHIFT OR Z shows cpwizard.
This is the line in the .ini
ShowKey=KEYCODE_LSHIFT|KEYCODE_Z
Thanks for any help
Go to full version
