Main > Software Forum
CPWizard v2.63 Released
TheManuel:
Hello.
I've finally gotten to the CPWizard phase of my project.
However, I can't get CPWizard to pause MAME when I press the "show" key.
I have everything configures per Method #1, but it just won't pause.
Here is my log file:
--- Code: ---[2592] 9/24/2011 9:38:59 PM: OnMameStart (MameManager) -> OnMameStart
[2592] 9/24/2011 9:38:59 PM: OnMameStart (MameManager) -> GameName: frogger
[2592] 9/24/2011 9:38:59 PM: OnMameOutput (MameManager) -> OnMameOutput: Orientation(\\.\DISPLAY1),0
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Show
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Mame Running
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Searching for Mame
[2592] 9/24/2011 9:39:02 PM: FindMame (MameManager) -> Mame Running hWnd: 0x11600006
[2592] 9/24/2011 9:39:02 PM: FindMame (MameManager) -> Window Rect: {X=0,Y=0,Width=1024,Height=768}
[2592] 9/24/2011 9:39:02 PM: FindMame (MameManager) -> Command Line: mame frogger
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Game Found: frogger
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Getting Game Details
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Sending Pause Key
[2592] 9/24/2011 9:39:02 PM: PauseMame (MameManager) -> Sending Pause Message to Mame
[2592] 9/24/2011 9:39:02 PM: TakeScreenshot (ProgramManager) -> Taking Screenshot
[2592] 9/24/2011 9:39:02 PM: Show (ProgramManager) -> Minimizing Mame
[2592] 9/24/2011 9:39:02 PM: MinimizeMame (MameManager) -> Minimizing Mame hWnd: 0x11600006
[2592] 9/24/2011 9:39:02 PM: MinimizeMame (MameManager) -> Minimizing Mame Console hWnd: 0x655444
[2592] 9/24/2011 9:39:03 PM: Show (ProgramManager) -> Showing Layout Form
[2592] 9/24/2011 9:39:03 PM: Show (frmLayout) -> frmLayout hWnd: 0x3604972
[2592] 9/24/2011 9:39:03 PM: ForceForegroundWindow (HideDesktop) -> Already Foreground hWnd: 0x3604972
[2592] 9/24/2011 9:39:03 PM: Show (frmLayout) -> Success! Foreground hWnd: 0x3604972 (Preview)
[2592] 9/24/2011 9:39:03 PM: Show (ProgramManager) -> Show CP Only is False
[2592] 9/24/2011 9:39:03 PM: Show (ProgramManager) -> Exit To Menu is True
[2592] 9/24/2011 9:39:03 PM: Show (ProgramManager) -> Display Mode is MainMenu
[2592] 9/24/2011 9:39:03 PM: ShowScreen (ProgramManager) -> Hiding Main Menu
[2592] 9/24/2011 9:39:03 PM: ShowScreen (ProgramManager) -> Resetting Menu
[2592] 9/24/2011 9:39:03 PM: ShowScreen (ProgramManager) -> Setting Exit To Menu True
[2592] 9/24/2011 9:39:03 PM: ShowScreen (ProgramManager) -> Showing MainMenu
[2592] 9/24/2011 9:39:05 PM: CPForm_FormClosing (frmLayout) -> Closing
[2592] 9/24/2011 9:39:05 PM: RestoreMame (MameManager) -> Restoring Mame Console hWnd: 0x655444
[2592] 9/24/2011 9:39:06 PM: RestoreMame (MameManager) -> Restoring Mame hWnd: 0x11600006
[2592] 9/24/2011 9:39:06 PM: UnPauseMame (MameManager) -> Sending UnPause Message to Mame
[2592] 9/24/2011 9:39:06 PM: SendMessage (InterComm) -> IPC_Server Failed To Send Message Id:Exit Str:
[2592] 9/24/2011 9:39:07 PM: OnMameStop (MameManager) -> OnMameStop
[2592] 9/24/2011 9:39:07 PM: OnMameStop (MameManager) -> Success
--- End code ---
Thanks for CPWizard.
headkaze:
Did you check what version of MAME you're using? Only certain methods work for different versions.
TheManuel:
Yes. It is MAME 0.142.
I compiled it with your tool and added the hiscore diff patch.
headkaze:
Do your settings look like this?
TheManuel:
Absolutely. I read the instructions in the website first and had to ask because I can't figure it out.
Also, I don't know if this is related but CPWizard does not read the controller settings from my ctrlr file (I specified the ctrlr directory under Options).
Does it have to be named a certain way?
