Main > Software Forum
CPWizard v2.63 Released
Pages: << < (95/145) > >>
headkaze:
Versions 2.20 Released
- Bug fixes to input control mapping system
For those that were having problems with input mapping in CPWizard there were some serious bugs related to it fixed in this release. Especially if you are using a ctrlr file. There were also fixes to the HideDesktop settings.
NelsonPJ:
  I installed CPWizard 2.20 and got it working with my control panel layout.  I've got U360 joysticks, and I'm running Mala with the U360 plugin that programs the joysticks when a game is selected.  Unfortunately when I selected a 2-way "horizontal" joystick game, I was unable to navigate the CPWizard list since I didn't have "up" and "down" available on my U360!  I was also unable to quit CPWizard and un-pause the game, so I had to kill MAME with Ctrl-Alt-Delete.
  What's the workaround for this?  I've done some searches here in the forum, but can't find anything.
headkaze:
--- Quote from: NelsonPJ on May 23, 2009, 06:59:45 pm ---  I installed CPWizard 2.20 and got it working with my control panel layout.  I've got U360 joysticks, and I'm running Mala with the U360 plugin that programs the joysticks when a game is selected.  Unfortunately when I selected a 2-way "horizontal" joystick game, I was unable to navigate the CPWizard list since I didn't have "up" and "down" available on my U360!  I was also unable to quit CPWizard and un-pause the game, so I had to kill MAME with Ctrl-Alt-Delete.
Both the GameEx U360 plugin and LEDBlinky have an option to put the joystick into 8-way mode when Mame is paused. If your using Fatfingers plugin unfortunately there is no option to do that AFAIK. You can either use LEDBlinky or try to contact Fatfingers to implement this feature. If he needs help with code to detect Mame pausing then get him to contact me.
garnerb350:
Headkaze....I'm still having the same issues as before...( buttons not matching up, controls all different)...Also I tried to use the hide desktop options and they didnt work either...( do you still have the files ( my cfg files) i sent ya, or do i need to send them again?)
headkaze:
--- Quote from: garnerb350 on May 26, 2009, 07:59:07 am ---Headkaze....I'm still having the same issues as before...( buttons not matching up, controls all different)...Also I tried to use the hide desktop options and they didnt work either...( do you still have the files ( my cfg files) i sent ya, or do i need to send them again?)
Did you download the latest version and try the included X-Arcade layout? Your ctrlr file along with it worked fine for me. I suggest you go into your Mame folder and delete all the files in the cfg folder.
Go to full version
