Main > Software Forum
CPWizard v2.63 Released
Flake:
--- Quote from: headkaze on May 19, 2009, 12:25:18 pm ---
The only way around it is to set Mame's pause to be a key you will never use, and then set CPW to use the 'p' key. Then CPW will pause Mame anyway when you press pause, and unpause it again when you exit.
Well this sounds excellent. As long as CPW will take care of pausing Mame then my problem will be solved. This way all I have to do is Map the mame pause as a button I will never use and thats it. I will try this tonight.
Thanks.
garnerb350:
Headkaze....need your help....
I installed 2.19 last night and when i brought up the preview button on my games....the button layout was totally different...
I have MameUI32 ver 129...My Control Panel is the X-arcade Tankstick.
I used the x-arcade background and layout you supplied as my layout for viewing.
When I previewed Marvel vs SF...This is what i had...
Marvel vs SF
1. Player 1 Side: Buttons were correct, nothing listed for the joystick.
2. Player 2 side: Joystick had u,d,l,r / 4 of the six buttons listed controls...
Samurai Showdown 2
1. Player 1 side: Joystick doesnt list, CPwiz lists the top buttons, but I use the bottom buttons
2. Player 2 side: Joystick lists...but buttons same as above...
I made sure that my paths were correct...and I made sure that all my labels had the correct key code...but everytime i did a preview...the button config was different than what i have always had...
Am i missing something here?
Flake:
I also having a issue where all my buttons and joysticks are alphafaded out? I have - or at least think I have proper label links assigned. Also, I went in and made sure all the labels were properly mapped to my control settings. Any thoughts?
headkaze:
garnerb350 & Flake: Post your CPWizard layout xml file along with Mame's default.cfg and [rom].cfg of the game your testing and your mame.ini file. I will have a quick look and see if I can work out what's wrong. It's usually a config issue.
I think attachments are still not working on the forums so zip up those files and e-mail them to headkaze [zatt] gmail.com. Obviously I can't go through everyone's configs. But I will demonstrate what people are doing wrong on the occation so hopefully it can help others. So I don't want people randomly sending me config files please! :)
garnerb350:
Bear with me HK....I'll try to have it tommorow morning....( away from cab)
