Main > Software Forum
CPWizard v2.63 Released
garnerb350:
Downloaded 2.20....put in the mame exe.path...Did New, used the x-arcade background...imported X-arcade layout...
Still had the same problems as before...
Did I do something wrong?
If I delete the cfgs in the cfg folder....wont i have to redo my button configurations for al the games? :scared
headkaze:
--- Quote from: garnerb350 on May 26, 2009, 12:18:30 pm ---If I delete the cfgs in the cfg folder....wont i have to redo my button configurations for al the games? :scared
Back them up first incase you might need them. Since your using a ctrlr file it will cover Neo Geo games, so unless your configuring some games manually you shouldn't need cfg files in most cases. You definately should not have a default.cfg in there since your using a ctrlr file, but as I said, back them up first and then try it again.
Flake:
How do you assign keycodes to the spinner and left/right mouse click buttons? I was trying to assign these but when I select "new" and the program prompts me to select a button I nothing happens in CP Wizard when I do?
Also, why are joysticks showing up as large buttons rather than joysticks in Mame when paused? I have proper label links attached to these .jpgs but then are showing up in Mame as just larger black buttons rather than the joystick picture I selected.
garnerb350:
Ok, last night i was working on a keyboard hack...and when i finished I couldnt rememeber if you said cfg or ctlr...so I am going to try this when i get home later today...
Ok , so guide me on this...make sure this noob doesnt screw this up...
1) delete cfg files in my mame folder and then install Cp Wiz...
2) set my mame path up...
3) create a new layout using the x-arcade background and x-arcade layout.
4) make sure all keys controls are correct, save and then hit preview...
If buttons are still off, what can i do to correct them?
headkaze:
1) Back up Mame's cfg folder somewhere
2) Delete the cfg folder
3) Make sure mame.ini is in the root of Mame's folder with the correct ctrlr file entry
4) Install & Run CPWizard
5) Set Mame paths correctly in Edit->Options->Mame Paths
6) Go to Edit->Options->Mame and set the "Mame Layout" to be "XArcade"
7) Select View->Preview
If the buttons are still off I don't know what you can do to correct them, because I have it displaying correctly here using the files you sent me. So it would mean your still doing something wrong.
