Main > Software Forum
CPWizard v2.63 Released
Pages: << < (75/145) > >>
headkaze:
--- Quote from: Popcorrin on January 07, 2009, 09:19:06 am ---Headkaze,
   Would support for animated gifs be a possibility?
Not for now, as I made a bad design decision in the begging of coding CPWizard to support DirectDraw overlays. This meant I had to redraw the entire screen every time the display updated which means it's slow. If I had of designed it not to support them (which I've removed now anyway) I could have had faster rendering by drawing only the graphics that need updating. Maybe one day I'll fix all that.
TAG:
Is CPWizard case sensitive when it comes to the rom names?  For example, if the commandline sends it "MSH" instead of "msh," will that affect whether CPWizard can pull anything up?  Thanks!
urbecrisch:
I recently installed Hyperspin v0.8.  Now when I turn on my cab (cpu), CPWiz opens a new window maximized and I cannot use the mouse to exit CP Wiz.  The previous version of Hyperspin did not cause this problem with CPWiz so when I would turn on my cab, CPWiz was running in the background so I'm wondering what can be done so I can use both programs.
TAG:
--- Quote from: TAG on January 12, 2009, 03:51:43 pm ---Is CPWizard case sensitive when it comes to the rom names?  For example, if the commandline sends it "MSH" instead of "msh," will that affect whether CPWizard can pull anything up?  Thanks!
Repeated testing seems to indicate that CPWizard is indeed case sensitive in that respect.  Any way to work around that, as my only other option is to regenerate my Mamewah lists (or change them all by hand...ugh)?  Thanks!
Oh, and the program works great for me otherwise!  Really a quality piece of work!!
headkaze:
urbecrisch: Have you reported this to BadBoyBill?
TAG: Thanks for the kind words. Yes I believe the ROM name is case sensitive. I believe I can fix that for next version.
Go to full version
