Main > Software Forum
LEDBlinky - Arcade LED Control software and Animation Editor - v8.2
Pages: << < (392/419) > >>
bozowise:
Installed LED Blinky in my cab and am slowly learning the details. I have watched all the videos and done the FAQ but I am still at a bit of a loss.
I attached an image of the lighting for Galaga.
I am not sure why it does not light coin 1 and it has an extra button lit on the controls. From everything I can see in the control file it should light coin 1 and there should only be one button lit for the fire button.
nick7184:
I have set up a default set of mappings in the control editor for "<default>" emulator, however, when I run a game in RetroArch, or any other emu for that matter via BigBox, I don't see buttons light up. The only other emulator config I have is MAME, which works properly.
Anyone have any idea what else I need to do to get default colors working?
arzoo:
--- Quote from: bozowise on December 04, 2022, 03:27:39 pm ---Installed LED Blinky in my cab and am slowly learning the details. I have watched all the videos and done the FAQ but I am still at a bit of a loss.
--- Quote from: nick7184 on December 05, 2022, 09:59:02 pm ---I have set up a default set of mappings in the control editor for "<default>" emulator, however, when I run a game in RetroArch, or any other emu for that matter via BigBox, I don't see buttons light up. The only other emulator config I have is MAME, which works properly.
Please enabled the Debug Log option (Misc Options tab), run your FE and a few games that don't light correctly, then email me the debug.zip and/or debug.log files and I'll take a look.
ToddBMCV:
Complete noob here, having difficult getting LED blinky active animation to keep buttons a solid color as shown in the support videos by using a single frame animation.
Also when I go into a game it doesn't light only the buttons of that game.
My active animation setup-
<a href="https://ibb.co/0YpCyG0"><img src="https://i.ibb.co/tYwqpJ0/active-animation.png" alt="active-animation" border="0"></a>
What actually happens, only player 4 is comletely right.
<a href="https://ibb.co/vLj5N4h"><img src="https://i.ibb.co/XFCBnxD/arcade.jpg" alt="arcade" border="0"></a>
When I check the LED colors in the "General LEDBlinky INput Map they are all correct and when I run the animation it's all correct.    Please HELP!
Also sorry haven't used a forum like this is a long time, didn't know how to get images to show directly.
PL1:
--- Quote from: ToddBMCV on December 11, 2022, 11:53:04 am ---haven't used a forum like this is a long time, didn't know how to get images to show directly.
Putting the image URL inside IMG tags like this code example displays the image like below.   :cheers:
- The icon inserts the IMG tags.
--- Code: ---[img]https://i.ibb.co/tYwqpJ0/active-animation.png[/img]
--- End code ---
--- Quote from: ToddBMCV on December 11, 2022, 11:53:04 am ---My active animation setup-
--- Quote from: ToddBMCV on December 11, 2022, 11:53:04 am ---What actually happens, only player 4 is comletely right.
Go to full version
