Author Topic: GameLists: Multiple emuls in same list work-around solution  (Read 325434 times)
  • Last login:Yesterday at 11:50:38 am
Re: GameLists: Multiple emuls in same list work-around solution
« Reply #320 on: December 01, 2014, 03:04:37 pm »
Do you have the NES games flagged as horizontal in mame.xml ?
This should work.  I have an automatically rotating monitor with a half dozen emulators launched using SGT's workaround.
As long as the xml is correct, Mala should rotate.
Keep in mind that the rotation info Mala uses on the fly is stored in the mala gamelist.
If just using the all games list, you'll have to refresh the main gamelist to get the changes to take effect.
If using a gamelist other than the all games list, refreshing doesn't work.  You'll have to delete the game from the list, refresh the all games list, then add it back to the smaller list.
Ah, that would be the problem, I didn't see anything in this posting about orientation (but may have easily missed it) so I will have to figure out how to add that to the mame.xml.  And yes, just using the all games list, so thanks also for the reminder to refresh the list.
OK, I've done some searching and can't find for sure how to tag the NES games as horizontal.  Is it done with a line like this: <display tag="screen" type="raster" rotate="90"  />
Or is there an easier method?
I didn't post an example because I didn't remember it exactly.
It's the rotate="90" part
IIRC, "0" is horizontal, 90 is rotated right, 180 is upside down 270 is rotated left
Look at a horizontal game in MAME as an example.
mala will put up the vertical orientation for either the 90 or the 270.
BorgDog
« Reply #321 on: December 01, 2014, 09:31:52 pm »
That worked great thanks.  I just added in a <display rotate="0"> into the Mario game section, refreshed the main list and everything worked.
My Projects:
Blueic5
  • Last login:December 16, 2018, 05:31:20 pm
« Reply #322 on: March 13, 2015, 10:00:17 am »
im struggling with this and wanted to check a couple of things before I continue troubleshooting.  Im trying to get mess to work with a .nes file is this even possible I can get it to work from a command line ie mess64.exe nes -cart test.nes  .  Trying to get the mame,cmd to work is driving me mad but it may just be a limitation of mala or I need to tell it some how to use a .nes extension any suggestions?
Code: [Select]
echo %1 > test.txt
echo %2 >> test.txt
if "%2" == "d:\Emulators\mess\" goto mess
mame.exe %1
exit
:mess
SET MESS=d:\Emulators\mess\mess64.exe
cd ..\Emulators\mess
exit
ive managed to get the game added to mame.xml and showing in the mala game list but I think im missing something obvious
Edit I going to play around again but I assume now I need it to say
mess64.exe nes -cart %1.nes
Is that right?
Oh mame and mess folders are on the same tree level
« Last Edit: March 13, 2015, 06:01:27 pm by Blueic5 »
BorgDog
« Reply #323 on: March 13, 2015, 06:15:29 pm »
That looks right as long as you are passing the right %1 and %2
I only wanted to add the Super Mario Bros so just did each direct like:
mess64.exe nes -cart "c:\mess\games\smario.nes" -skip_gameinfo
« Last Edit: March 13, 2015, 06:23:56 pm by BorgDog »
My Projects:
Blueic5
« Reply #324 on: March 14, 2015, 03:00:29 am »
Do you need the quotes?
Blueic5
« Reply #325 on: March 14, 2015, 05:40:28 am »
A question will mala only see .Zip files as roms in games list is that why you may need a dummy zip file? Also on some of the examples it shows
emulator.exe zip %1 rar
But I don't get why it has a zip before the rom name and then rar?
BorgDog
« Reply #326 on: March 14, 2015, 12:12:01 pm »
good question, they may be not necessary, but it worked so I left them... let me try it out without them...
2 minutes later
seems to work fine without them, at least for that case, as long as there are no spaces in folder or file names it should work.  In fact I shortened all my file names just to not have to deal with that, so "Super Mario Bros. (Japan, USA).nes" became smario.nes
« Last Edit: March 14, 2015, 12:29:34 pm by BorgDog »
My Projects:
Blueic5
« Reply #327 on: March 16, 2015, 05:54:23 am »
Im struggling from what I can see in the test.txt the right rom name and rom path are being sent, but I think its just running mess rome name rather that mess64 nes -cart path\romname.nes
Code: [Select]
echo %1 > test.txt
echo %2 >> test.txt
if "%2" == "d:\Emulators\other_roms\nes\" goto mess
mame.exe %1
exit
:mess
mess64.exe nes -cart %2\%1.nes
exit
is there a way to stop the dos prompt vanishing so quickly?
BorgDog
« Reply #328 on: March 16, 2015, 08:54:12 am »
put a line that contains "pause" without the quotes after your mess64 line, should stop the dos window and let you see what is going on.
Are you sure you are getting to the right directory with the "cd ..\Emulators\mess"?  that would definitely cause issues. what directory are you running the cmd file from.
« Last Edit: March 16, 2015, 08:57:44 am by BorgDog »
My Projects:
Blueic5
« Reply #329 on: March 16, 2015, 12:30:07 pm »
right im getting somewhere I can get it working finally if I # out the mame lines otherwise it just trys to run mame instead of mess for some reason.  Not sure why its not calling mess when it can see the directory the rom is located in.  I changed my batch file to read
Code: [Select]
d:
cd \Emulators\mess
which seems to be working .
So now I just cant work out why its trying to run the other_roms\nes under mame rather than mess.
edit It would seem after using that pause command its ot going to the :mess section of the script and I can t see why
Code: [Select]
mame.exe %1
pause
exit
:mess
cd \
d:
cd Emulators\mess
pause
exit
output
Code: [Select]
D:\Emulators\mame>if "D:\Emulators\other_roms\nes" == "d:\D:\Emulators\other_roms\nes\" goto mess
D:\Emulators\mame>mame.exe rom_name._(USA)
Unknown system rom_name._(USA)'
"rom_name._(USA)" approximately matches the follow
supported games (best match first):
ac1shid           Super Hi De Hi (Ace) (ACESYS1) (set 1)
ac1shida          Super Hi De Hi (Ace) (ACESYS1) (set 2)
ad5sslam          Super Slam (Bellfruit) (Adder 5) (set 1)
ad5sslama         Super Slam (Bellfruit) (Adder 5) (set 2)
ad5sslamb         Super Slam (Bellfruit) (Adder 5) (set 3)
ad5sslamc         Super Slam (Bellfruit) (Adder 5) (set 4)
ad5sslamd         Super Slam (Bellfruit) (Adder 5) (set 5)
ad5sslame         Super Slam (Bellfruit) (Adder 5) (set 6)
ad5sslamf         Super Slam (Bellfruit) (Adder 5) (set 7)
arac6000          Super Six Plus II English Mark Darts
as_sld            Super Little Devil (Astra, V700)
as_slda           Super Little Devil (Astra, V600)
as_sldb           Super Little Devil (Astra, V500)
as_sldc           Super Little Devil (Astra, V400)
as_sldd           Super Little Devil (Astra, V200)
as_slde           Super Little Devil (Astra, V101)
D:\Emulators\mame>pause
Press any key to continue . . .
« Last Edit: March 16, 2015, 12:44:59 pm by Blueic5 »
BorgDog
« Reply #330 on: March 16, 2015, 12:41:50 pm »
it's trying to run mame?  The only way I see that happening is if the "if "%2" == "d:\Emulators\other_roms\nes\" goto mess" line is not triggering the goto.  Do you need the \ on the end of the path? and I assume that matches what you are capturing in your test.txt.
My Projects:
Blueic5
« Reply #331 on: March 16, 2015, 12:46:11 pm »
I remove the text file output as it seemed to show things correctly, anyway ive updated my post above for troubleshooting
BorgDog
« Reply #332 on: March 16, 2015, 01:13:56 pm »
take the \ off the end of your if statement as obviously those two are not equal
My Projects:
Blueic5
« Reply #333 on: March 16, 2015, 01:41:53 pm »
Cheers I'll try that tomorrow and let you know...
Just a note
I had a lot of issues with the spaces in the rom name and gave up wouldn't work for me with or without ".   Also there seemed to be a rom name length limit when executing the script.
BorgDog
« Reply #334 on: March 16, 2015, 10:40:00 pm »
I just looked at it again and you have "d:\D:\" in there too, not sure where that is coming from, but it could be an issue as well.
My Projects:
Blueic5
« Reply #335 on: March 17, 2015, 10:12:46 am »
I think that was me typing it in, but it did solve the issue which was I needed a uppercase D: rather than the lower case and I also got rid of that "\" .  Thanks for your help and blimey its very picky and case sensitive .
BorgDog
« Reply #336 on: March 17, 2015, 11:02:11 am »
Glad to hear you got it working.  :applaud:
My Projects:
Pedro felinni
  • Last login:August 20, 2019, 04:11:35 am
« Reply #337 on: September 04, 2016, 05:46:32 am »
I do not know how to run the Final Burn Alpha on the same list with Mame.
Can someone help me?  :cry:
C:\Users\felinni\Desktop\MaLa174\others\fba\fba.exe
C:\Users\felinni\Desktop\MaLa174\mame125\mame125.exe
