Author Topic: Mala Background Music, Stop/Play Button???  (Read 6450 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: May 04, 2007, 09:35:10 am »
I am using Mala with Background music playing on startup.  I want to assign a button to stop the music without having to rightclick and go into the options.  Does anyone know how to assign a play and stop button?
loadman
  • Moderator
    • MaLa
Re: Mala Background Music, Stop/Play Button???
« Reply #1 on: May 04, 2007, 05:56:03 pm »
You can via a Plug-in if you want  ;)
http://wiki.arcadecontrols.com/wiki/Mala_Plugins
     SendMessage(FindWindow(nil,'MaLa'), MALAMSG_STOPBGMUSIC, 0, 0);
     SendMessage(FindWindow(nil,'MaLa'), MALAMSG_STARTBGMUSIC, 0, 0);
« Last Edit: May 04, 2007, 06:35:40 pm by loadman »
Chunce DeLeone
« Reply #2 on: May 07, 2007, 02:52:26 pm »
Thanks Loadman, I will have to try that.....I can't believe it is not a part of the program already
loadman
  • Moderator
    • MaLa
« Reply #3 on: May 07, 2007, 09:42:36 pm »
The only other thing is in options-gui-gamestart you can have the music stop while playing games
Chunce DeLeone
« Reply #4 on: May 08, 2007, 10:25:35 am »
Yeah I have that option,  what I'm looking for is a toggle for the music when I am going through the game lists, sometimes I like to listen to the mp3's sometimes I dont
theendisnye
  • Last login:June 24, 2007, 02:34:05 am
« Reply #5 on: May 14, 2007, 04:17:50 pm »
IIRC you can turn the music on/off from the menu under the sound option. Steve
loadman
  • Moderator
    • MaLa
« Reply #6 on: May 14, 2007, 07:10:25 pm »
I think you will find he wants to assign a button to it raher than go through options  ;)
You can set 'Next Song' but not Stop or play without using a Plug-in
« Last Edit: May 14, 2007, 07:11:59 pm by loadman »
