Author Topic: mala/avga auto rotate games?  (Read 7047 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 29, 2007, 10:36:26 am »
Is it mala or the AVGA that rotates the game based on if it is horizontal or vertical?
Anyway to assign all vertical games to use one joystick and all horizontal games to use another joystick at once, or do I have to do it for each game?
I b**ch. People listen!!
loadman
  • Moderator
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
Re: mala/avga auto rotate games?
« Reply #1 on: March 29, 2007, 11:53:24 am »
I think to do what you wish you need to create two game lists 'Horizontal' and 'Vertical' (you can use filters in malagamelist.ese to get you started) and set it up something like attached pic. Have a play and have fun  ;D
squirrellydw
« Reply #2 on: March 29, 2007, 02:17:59 pm »
I will give this a shot but why do you have two SET 2 Horizontal gamelists?
squirrellydw
« Reply #3 on: March 29, 2007, 09:19:22 pm »
Does it put the games in the list automatically or do I have to add them?
loadman
  • Moderator
    • MaLa
« Reply #4 on: March 29, 2007, 10:19:49 pm »
You have to make you own lists but as i said "you can use filters in malagamelist.exe to get you started"  ;)
I just whipped up that screenshot....  ;D  Set-it up how you want
You really need to have a Play with MaLa's options in these areas on your cab and see what you like.
[EDIT] Another screen to play with is attached:
« Last Edit: March 30, 2007, 03:44:37 am by loadman »
squirrellydw
« Reply #5 on: March 30, 2007, 12:21:13 pm »
OK  I got that working but I have two problems.
1. The vertical games show up upside down how can I have it FLIP the list automatically?
Figured number one out
2. When I am in the horizontal view and select a game it switches to the vertical view first, any idea? Figured this one out finally.
« Last Edit: March 30, 2007, 10:34:13 pm by squirrellydw »
loadman
  • Moderator
    • MaLa
« Reply #6 on: March 31, 2007, 03:07:18 am »
Do share how   ;)
There is no subsitute for just playing with it... MaLa is fairly intuative
You can teach me now   :applaud:
On my 'To Do list' is compile info like this to MaLa Wiki..
« Last Edit: March 31, 2007, 06:23:15 am by loadman »
squirrellydw
« Reply #7 on: March 31, 2007, 10:20:22 am »
The main problem was I didn't read.  I was trying to use both of your examples above.  Then I realized you can only use one.  As for the vertical games showing up upside down, I had it set on the wrong side of the monitor which I didn't realize how that worked at first.  Don't remember how I got two fixed but I did.  I think it had something to do with switching horizontal and vertical games.
squirrellydw
« Reply #8 on: March 31, 2007, 11:19:36 am »
Is there away I can have Mala cycle through the different game list and emulators?  As in I get to the end of the lists and starts back at the beginning so I don't have to go backwards.
loadman
  • Moderator
    • MaLa
« Reply #9 on: March 31, 2007, 04:21:07 pm »
Yep..It can do both  ;)
I'm at work, But I think its' in the GUI tab.  (I will come back and edit this post later)
squirrellydw
« Reply #10 on: March 31, 2007, 06:03:25 pm »
yup found it, wrap lists and emulators.
Thanks again
loadman
  • Moderator
    • MaLa
« Reply #11 on: March 31, 2007, 07:43:19 pm »
Thanks again
squirrellydw
« Reply #12 on: June 10, 2007, 07:39:54 pm »
 :dunno  figured it out
« Last Edit: June 10, 2007, 08:15:07 pm by squirrellydw »
