Author Topic: SK Jukebox 4.0.0 Released  (Read 14579 times)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« on: January 02, 2007, 12:59:57 pm »
Thanks to Salmonking for this wonderful X-mas present. Supports video and other updates as well.
http://www.skjukebox.com/index.php?ind=downloads&op=entry_view&iden=5
BobA
  • What Me Worry?
Re: SK Jukebox 4.0.0 Released
« Reply #1 on: January 03, 2007, 05:47:25 pm »
Thanks for the new release.    It went in smoothly and everything is running well.  Will check out the new enhancements.
BobA
  • What Me Worry?
« Reply #2 on: March 07, 2007, 11:37:47 pm »
I just noticed that 4.0.1 is available on the SKjuke site.
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: April 04, 2007, 02:34:46 am »
Any plans on adding vertical monitor support?  My jukeox is an old Atari cocktail cabinet and the monitor is in a vertical orientation.  I currently use WinCab...but i'd love to use SKJ.
BobA
  • What Me Worry?
« Reply #4 on: April 04, 2007, 04:04:23 pm »
I rotated my desktop with the ATI utility and ran SKjuke.   It looks like the only thing that would need work is the album graphics.   If you squashed them to the right ratio for vertical display they would probably look ok.  The buttons and all the text looks good when rotated.
I am running XP home sp2 with an ATI 9550.  The cpu is an AMD64 3400+.
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #5 on: April 10, 2007, 05:48:59 pm »
 :cheers: will this work with a touch screen monitor?
Freeplay
  • Last login:May 02, 2015, 06:04:19 pm
  • I'll be crosses !
« Reply #6 on: April 13, 2007, 08:30:45 pm »
Yep..you bet.. its awesome with a touch screen.
SK.. I'm nearly finished my new dual screen jukebox....
Any luck with getting the screen saver / now playing image to come up on the second screen yet?
PS love your work
"The Best Thing About Getting Old"
You can afford bigger and better toys
BobA
  • What Me Worry?
« Reply #7 on: April 13, 2007, 10:32:47 pm »
Works fine on my 15 inch touch screen but wish I had a 17 inch.  Sometimes I hit the wrong song.  Other than my fat fingers the software works great.
Freeplay
  • I'll be crosses !
« Reply #8 on: April 14, 2007, 05:13:44 am »
BobA.. mine used to do that... then I just made the font bigger.... now all is fine.
Marky_1979
    • Personal Webspace
« Reply #9 on: April 16, 2007, 02:32:54 pm »
Can you guys recommend a good touch scrteen monitor and possibly show some pics of your current set ups?
BobA
  • What Me Worry?
« Reply #10 on: April 17, 2007, 11:20:42 pm »
I made it a bit bigger but maybe I will have to try some other sizes.
BobA
  • What Me Worry?
« Reply #11 on: April 17, 2007, 11:33:15 pm »
I like any elo touchscreen lcd monitor.  The CRT touchscreens may be cheaper but they kill you on shipping.   Anything from 12 to 18 inches is good.  The bigger the better.   Prices range from 100 dollars to 500 or 600 dollars depending mainly on size and if it is new or used.  Elo also makes touchscreens for many other manufacturers such as NEC and Planar.  If the seller tells you to use ELO drivers it was probably made for another company by ELO.
This is my current jukebox.    The monitor needs to be painted black.  Link
« Last Edit: April 17, 2007, 11:36:44 pm by BobA »
