Author Topic: Control Panel Database: Post a picture of your Control Panel!  (Read 944624 times)
bfauska
Re: Control Panel Database: Post a picture of your Control Panel!
« Reply #920 on: February 16, 2015, 07:24:53 pm »
My first control panel build.   I love the way it turned out!
That looks pretty great with the white on black. Is that a stencil or full overlay?
DocHolliday
  • Last login:March 28, 2017, 11:59:12 am
« Reply #921 on: February 17, 2015, 02:55:06 am »
Thanks man, it's a full vinyl wrap overlay with clear laminate to protect it.   had that made at a local shop from the design I put together from images online that I liked.
subassy
  • Newbie
  • Last login:May 01, 2015, 11:04:02 am
« Reply #922 on: March 13, 2015, 07:14:58 pm »
First time poster, long time lurker. A very epic 9 year thread by the way. Very educational.
I wanted to ask about the number of buttons: you drilled for 8 player buttons but covered over the holes so there's only 6. I've been wondering about 6 vs 8 player buttons. How many games really going to use the 8 player buttons? Is that mostly for console games? Did you drill the extra holes for future expansion? Just curious.
I'm working on creating my own control panel. Very slow going. Almost losing patients (although I've never done anything remotely similar to this and it's only been 2 1/2 months).
DocHolliday
« Reply #923 on: March 18, 2015, 12:29:12 pm »
As I mentioned in a previous post, I bought the wood panel itself online, so it was already pre-drilled with 8.   Yes, if you want to use it for the console type games where you would need the L1,L2,R1,R2, you would need the 8 buttons.  I use a regular controller for those games, so I only needed 6.
FinnJävel
  • Last login:May 11, 2020, 11:58:44 am
  • A disgrunteled cabbie.
« Reply #924 on: April 07, 2015, 07:37:25 am »
My BB
edekoning
  • Last login:Yesterday at 04:55:29 pm
edekoning
medtech1
  • Last login:July 10, 2015, 04:27:30 pm
« Reply #927 on: April 15, 2015, 07:01:38 pm »
edekoning :  I can tell you take pride in the neatness of your work. The tyraps on the wires, the terminal blocks.. all look great... well done.
woosdom
  • Last login:June 13, 2025, 06:14:45 pm
« Reply #928 on: May 14, 2015, 09:15:31 am »
First for me. gotta start somewhere   ;D
woosdom
« Reply #929 on: May 14, 2015, 09:17:28 am »
have to replace the screen I used. not good enough viewing angle. and not as bright as I thought.  :banghead:
dylaninwv
  • Last login:October 09, 2019, 07:05:47 pm
« Reply #930 on: May 14, 2015, 11:58:12 am »
My turn for gratuitous CP pics....
Mine is coming along. Cab is a space-themed one - bezel is going to end up being the old archway from Space Port - since Space Port is where I shoveled my quarters out by the pound...
Still have to put the T-moulding on, and wire the two mouse buttons, but almost done. The post to the right of the mouse buttons is a USB volume control - just have to add the knob. eventiually I plan to add an extension to the bottom front to hold a flightstick, to resemble the center placement of a flightstick from a cockpit - but that's down the line.
rabidpuppy
  • Last login:July 21, 2015, 06:30:56 am
« Reply #931 on: June 14, 2015, 05:08:15 am »
Super-Pro™ Leaf Switch 8-way Arcade Joystick
Versa-Ball 2™ Multi-Compatible Ball-Top Joystick Shafts
CLASSX™ Colors - BLUE - Leaf Switch Compatible Button  - Switch Type: True-Leaf Pro™
Micro-Leaf™ Arcade Pushbutton Switches
(P3 & P4 are Zippyys but using universal mounting plates)
7" Doublesight USB monitor
iPac4
More pics here but nothing groundbreaking in this build. https://flic.kr/s/aHskdxuYPW
[url=https://flic.kr/p/umeBpM]
« Last Edit: June 14, 2015, 05:17:29 am by rabidpuppy »
Vidiot
  • John 3:16
« Reply #932 on: June 19, 2015, 12:58:05 pm »
Happ Perfect 360 Joysticks
Ultimarc GoldLeaf pushbuttons
Ultimarc 3" UTrak Trackball
SlikStik Tornado Spinner
IPac2
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« Reply #933 on: June 20, 2015, 01:37:05 pm »
MCP Control Panel
Four Ultrastik 360s
UTrak trackball with LEDs
TurboTwist spinner
UltraLux RGB Buttons
Buttons for flippers and plunger as well.
copyimitation
  • Last login:November 06, 2019, 12:03:56 pm
  • Looking for Ring of Destrucion II
2 Player - 6 Button - Control Panel Template
« Reply #934 on: June 24, 2015, 04:41:57 pm »
Here is my setup. I used a template i found online for Visio, and edited it to my liking. I took this to Staples and had them print me out a blueprint for about $4.
« Last Edit: June 26, 2015, 11:08:49 pm by copyimitation »
copyimitation
« Reply #935 on: June 26, 2015, 07:10:34 pm »
How do you go about installing cpo art that has designs around the buttons and joystick like you have? I am making my cpo design and i have art around mine as well but was wondering how to line it up with my control panel. Any help?
IPac2
« Last Edit: June 26, 2015, 11:09:32 pm by copyimitation »
Vidiot
  • John 3:16
« Reply #936 on: June 26, 2015, 08:50:03 pm »
I use Paint shop pro to make my art. I just designed everything as actual size then I would print a low quality greyscale version at actual size to see how everything lines up. You might have to print on a couple pages and stitch it together with tape. Button holes are 1 1/8" in size. You will probably have to play around quite a bit until you have something you like.
Took me forever to get it the way I wanted it.
EMDB
  • Project RetroCade
« Reply #937 on: June 27, 2015, 03:06:13 am »
You should first design and print the CPO and use a copy as a template to drill the holes for the buttons and joysticks...
gingerone
  • Last login:November 02, 2015, 06:44:21 am
« Reply #938 on: August 01, 2015, 02:24:05 pm »
Here's a photo of my recent attempt, be nice :)
Sent from my HTC One_M8 using Tapatalk
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
« Reply #939 on: August 06, 2015, 05:40:49 pm »
Here's mine.  Doesn't work yet, but it's pretty much built except for the t-molding.
ladysephiroth
  • Last login:September 26, 2016, 05:40:24 pm
« Reply #940 on: August 15, 2015, 08:47:10 pm »
megamoze: that looks like what I'm trying to accomplish, layout wise -- any chance you have dimensions or blueprints I could play with? I like how neat the layout looks, and how you economize on buttons!  <3
megamoze
« Reply #941 on: August 17, 2015, 07:42:52 pm »
I'll have to track it down, but I basically copied the design of the Tankstick and made my own modifications.  I added the spinner, took away buttons 7 & 8, and moved the player start buttons over to the right side.  I also moved the coin buttons to the front of the base instead of the sides.  If you google the Tankstick, you can find a basic layout of the design.  I printed that to full size and went from there.
pcm2a
  • Last login:January 03, 2019, 09:15:57 pm
« Reply #942 on: August 20, 2015, 05:23:10 pm »
Wanted to get my control panel in here since I just completed it last weekend. Was a Tekken 4 but I cut some extra holes, breaking the plexiglass in the process and had to cut that new as well. Went with the 7th button for games like MK3 (Run button) and Tekken Tag (Tag button).
SpaceHedgehog
  • Almost done ...
« Reply #943 on: August 26, 2015, 05:11:48 pm »
Vewlix panel (with a little poetic aluminium license):
Click a pic for a video tour
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« Reply #944 on: August 30, 2015, 03:51:11 pm »
Here is mine ... nothing ground-breaking here. Single player U360 with 4-way restriction.
P1 is mapped as "Start" and P1+P2 are "Exit"
Works great...
Ian
  • Last login:September 26, 2021, 01:50:35 am
Re: Project X Arcade Control Panel
« Reply #945 on: December 08, 2015, 06:47:49 pm »
Here's are some control panel pics from my recently completed "Project X Arcade"  (http://sachi.sytes.net/techblog/?p=124)
This panel is damn pretty...  :applaud:
Goldenjelly
  • Last login:December 29, 2015, 06:22:17 am
  • My bro helps me poo
« Reply #946 on: December 28, 2015, 03:31:45 pm »
Cabinet was originally a sega fighting vipers cab
xybot
  • Last login:August 10, 2025, 03:11:18 pm
« Reply #947 on: December 31, 2015, 01:43:48 pm »
Here's mine! It's housed in an unusual Xybots cabinet. I had to bore holes through the metal control panel to add more buttons, which was quite tricky. I was able to acquire an extra control panel so I still have the original in case I want to revert the game back some day since the machine still has the original, working boards inside.  :cheers:
I did something unusual here that I've never seen done before. I added toggles where two of the original fire buttons were to determine which buttons belong to which player / joystick. If you examine my photo, you'll see that both toggles are switched left. So any button player one uses will work! I did this because it felt awkward playing on the left side of the machine with the buttons on the left, looking at the screen at an angle. I made this a long time ago so can't recall why I didn't put them on the right, but I think it had to do with both fitting them into the small panel and symmetrically integrating them into the existing design. Anyway, this allows a single player to be totally centered in the middle of the machine using the left joystick and right button banks. For games that require two players, I just toggle the right switch right.
There's an iPac mounted beneath the middle of the panel. I'm using Ultimarc Mag-Stik Plus 4-8 way switchable from the top of the panel joysticks. I have the coin door buttons lit up with USB LED lights powered by the computer and rigged with switches to add coins. I designed the instructional graphic in middle to show how to control the GameEx software that I'm using (this is covering the original Xybots instructions). Though not really part of the control panel, I'm also using a mini keyboard remote to handle anything that the control panel can't.
rhzucal
  • Last login:April 07, 2017, 09:57:42 am
« Reply #948 on: January 15, 2016, 09:03:11 am »
This is my first ever run at making a MAME system and control panel. I didn't take into account the depth that is need for the wiring but overall it worked out. The design is all the games I loved as a kid. I think it turned out pretty cool.
ChanceKJ
« Reply #949 on: January 15, 2016, 05:34:58 pm »
« Last Edit: March 19, 2021, 03:16:56 am by ChanceKJ »
ARTIFACT
« Reply #950 on: January 24, 2016, 03:04:32 pm »
Some AMAZING control panels here!!!!
Not sure if I ever posted the control panel from my ARTIFACT Game Museum cab... Here we go!
Thanks to all in the community who helped me back in the day in 2007 when I was planning and building it.
I miss it..... Maybe I should build another project.......
Ian
« Reply #951 on: February 14, 2016, 11:46:22 am »
8-bit zombie is done, it's final resting place is my basement and due to low light these are the best pictures I could come up with. Enjoy!
Scassidy24
  • Last login:October 12, 2023, 11:56:34 am
  • I love my Nostalgia Machine
    • forum.arcadecontrols.com/index.php/topic,150379.0.html
« Reply #952 on: February 28, 2016, 10:02:59 pm »
These pics of a cabinet I built to stay inspired while working on the software side of things.  This is my first prototype cabinet which really helped me put into perspective how large im willing to go with the control panel space.
On order right now is a trackball and 2 spinners I will either make a second control panel for swap out or turn this existing panel into a flippable box with the trackball and spinner setup on the reverse side.
vicviper573
  • Last login:May 10, 2016, 02:42:09 pm
  • Designing controls for upcoming arcade games!
« Reply #953 on: March 12, 2016, 08:14:48 pm »
Nothing too special about my panel or its layout, but it has a little history.  It was forged in the fires of 675 Sycamore Drive, in the metal shop of Atari Games in 1996.  It served as a prototype layout for the Showcase 33 / Deluxe cabinet version of Primal Rage II, and would have seen full production had the game not been cancelled.  It has since been my personal control panel and served me well for nearly 20 years, and will continue to do so.  :)
DarkDraco
  • Last login:June 30, 2016, 03:42:53 pm
« Reply #954 on: June 29, 2016, 07:16:52 pm »
woosdom
« Reply #955 on: September 16, 2016, 03:14:41 pm »
my first attempt at a two player panel
Scassidy24
« Reply #956 on: September 25, 2016, 11:39:52 pm »
My completed flippable panel is a drawer that can be flipped over for trackball or spinners instead of fight sticks
crumptinite
  • Last login:September 06, 2017, 01:35:19 pm
« Reply #957 on: September 26, 2016, 03:12:33 pm »
Casey120
  • Last login:March 03, 2017, 04:56:01 pm
« Reply #958 on: October 18, 2016, 02:33:20 pm »
Bought this about 6 years ago, lighted buttons and trackball .
Never really used it though .
Retrogamer_68
  • Last login:December 05, 2016, 05:04:43 pm
« Reply #959 on: October 29, 2016, 05:10:07 pm »
Here are a few pics of my plexi tabletop controller.
