Author Topic: Howard's Castro Wrapper for Vpinball with MALA  (Read 7425 times)
CyrusMzRG
  • Last login:July 14, 2019, 07:01:50 pm
« on: September 13, 2006, 12:43:25 pm »
Hi folks, anyone uses thr Howard's Castro Wrapper for Vpinball with MALA. I need it for useing the ESC key for exit Vpinball. If anybody can help me with this or has another solution, please let me know
Thank you
unclet
Re: Howard's Castro Wrapper for Vpinball with MALA
« Reply #1 on: September 13, 2006, 03:07:40 pm »
I do not use his wrapper.  Instead by keyboard encoder can map all the keypresses required to quit Visual Pinball to the ESC key.
CyrusMzRG
« Reply #2 on: September 13, 2006, 05:12:48 pm »
how can I do that??
CyrusMzRG
« Reply #3 on: September 14, 2006, 08:08:50 pm »
sorry, I am a little bit newbe in this. Could you explain to me what is a Keyboard encoder??
Unclet, excelent mala manual, I followed it for configure several things, but the Vpinball is the last one I need to finish
fatfingers
  • Got UltraStiks?™
« Reply #4 on: September 14, 2006, 08:38:46 pm »
Check this page out
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
CyrusMzRG
« Reply #5 on: September 15, 2006, 05:07:23 am »
Thank you fatfingers, but last night finally I slove the problem only with software.
thanks a lot
Cyrus
unclet
« Reply #6 on: September 15, 2006, 07:07:27 am »
Sorry .... I just found this thread again .... glad you got everything working.
You probably should mention exactly how you solved your problem so others might benefit when the problem happens again in the future.
Are you still using Howard's wrapper?  Are you using a keyboard encoder?  How did you solve the problem using software?
« Last Edit: September 15, 2006, 07:09:22 am by unclet »
CyrusMzRG
« Reply #7 on: September 15, 2006, 10:08:22 am »
Hi Unclet, of course, I'll tell you what I did.
I used a program which closes any emulator where is installed, ( Snes, NEs, Genesis, Vpinball) with the key you want ( I use ESC button) it doesn't need any hardware, no keyboard encoder,... only this little program.
Yoy can find it HERE http://clusters.cjb.net/closemul/ it is very easy to config and it works perfectly.
I hope you like it.
Cyrus
unclet
« Reply #8 on: September 15, 2006, 10:10:14 am »
Thanks ... stuff like this can be very helpful to alot of people .....
