Author Topic: The hunt for a 2x4 sheet of 5/8th plywood  (Read 5241 times)
  • Last login:October 17, 2025, 10:29:23 am
« on: July 19, 2006, 04:05:37 pm »
ok! So, at the last minute I decided I would add plexiplass to my 3/4" CP. I hee'd and haw'd about it for a while and decided I should remake my CP out of 5/8ths so the plexi could line up with the T-molding.
I went to 2 home depots and 2 lowes. A full sheet cost $15. I didn't want to buy more wood than I needed. But hell, with the price of gas, I'm actually losing money now.
It appears they don't cut the 5/8ths into a 2x4 sheet. It's full sheets or nothing. Anyone else have fun looking for 5/8ths?
I had an amusing conversation with a home depot guy:
me "Hey, do you work in lumber"
HDG "Yeah"
me "I'm looking at these 2x4 sheets of plywood" and I point to the wood
me "Do you have this in 5/8ths?"
HDG "No, 3/4" is as big as we go"
me "Well 5/8 is smaller than 3/4"
HDG "Yeah"
silence
me "Ok, thanks!"
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
Re: The hunt for a 2x4 sheet of 5/8th plywood
« Reply #1 on: July 19, 2006, 04:24:12 pm »
just went today to redo my control panel.
lowes sells 5/8 particle board underlayment in pieces. I just bought 2 pieces of 2x6 5/8 for $2.50 each for my cp. but if you are dead set on plywood I dont know...sorry. I had already started to reply before I saw you were looking for plywood so this post may not help you at all.
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
« Reply #2 on: July 19, 2006, 04:31:04 pm »
I would practice routing plywood before committing your CP to it.  It can chip which would cause problems with your t-molding.  If you can do it without chipping, then good for you.
I would suggest any 5/8" wood will work.  Lowes and Home Depot will have 2x4 pieces of pine or oak etc.  On my first one, I went with pine.  My 3rd one is 1/2" mdf.
If you want to know how I knew that plywood would chip when routed, guess what I used on my 2nd cp.....  :banghead:
Good luck.
« Reply #3 on: July 19, 2006, 04:49:16 pm »
Will particle board be strong enough?
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #4 on: July 19, 2006, 07:26:48 pm »
Why not have them cut a full sheet of 5/8" into 2' sections?  You'll have 3 spares if you screw up (2 if they do a crappy cutting job).
You could also just cut the t-molding groove so that it lines up with the plexi, and then take a router or utility knife and shave the bottom, since that'll be the place that the t-molding won't be stared at so intensely.
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
« Reply #5 on: July 20, 2006, 10:44:12 am »
Yes I know exactly what you mean stupid hardware store emplyees I had it even worse being 20 I get no respect in those kinda places.
« Reply #6 on: July 20, 2006, 11:56:50 am »
well.... in hindsight that makes the most sense. Especially since it cost me probably $20 in gas driving to different stores. I'll probably just grab a full sheet of 5/8ths. I can use the left over for the next project for the internal shelves and what not.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #7 on: July 26, 2006, 05:40:58 pm »
You car rout a 1/8" rabbet off the bottom side of your 3/4" cp and use 3/4" t-molding. Drew sorta said this above...
Knevil does this on his cabinets regularly. I have used this trick as well.
Also, it is a requirement of the woodworkers code to purchase full sheet stock. You will even find yourself looking for plans to build a rolling cart to store all your drops. I eventually rented a storage for my scraps.
Of course, I may just have an OCD problem :(
NightGod
« Reply #8 on: July 27, 2006, 12:40:05 am »
Just curious...how much scrap can you have that you need a storage space? Wouldn't you just use up scrap from a previous project at the start of the next? Seems like you should only ever have about one or two decent sized scrap pieces of any particular wood type...
DrewKaree
  • HAH! Nice one!
« Reply #9 on: July 27, 2006, 01:12:13 am »
You'd think so, wouldn't you?
Go ahead, get started with some woodworking projects.  You'll learn soon enough :laugh2:
That one was almost as good as the "Why would you need more than one router?" question :laugh2:
nostrebor
  • SHOCKING!!
« Reply #10 on: July 27, 2006, 10:07:19 am »
It's kinda like the arcade cabinet deal. You can't just have one. Pretty soon the word gets out and folks are like "hey I got this pile of rough sawn cherry sittin here. Your into woodworking... want it?" And the guys at work know I build stuff so they load MDO scraps into my truck without asking me. Next thing you know, you got a crapload of misc material sittin in the space where your wife parks her car. It's not pretty when that happens... trust me.
NightGod
« Reply #11 on: July 27, 2006, 11:37:51 am »
Ahh, gotcha-that actually makes alot of sense.
Now, about this multiple router deal....
nostrebor
  • SHOCKING!!
« Reply #12 on: July 27, 2006, 02:09:31 pm »
Any man with less than 3 routers is not really a man at all. I have 4 just to be safe ;D
Actually it works like this:
1. buy a cheapy router with 1/4" collet. After getting to step 4 at least you know that this one can have a 1/8"
    RO bit left in it, so not all is lost.
2. Hate the router so research some and buy a Bosch plunge.
3. get a Ryobi set for Christmas. OK cause now I can mount the router permanently in my router table.
4. Some loser posts a smokin Amazon deal on a PC router on a WW forum. Impulse hits...
BLAM! 4 routers.
