Author Topic: Yet another Wiring Question... (3-sided cocktail help!)  (Read 2483 times)
  • Last login:May 16, 2026, 10:04:31 am
« on: May 23, 2006, 02:07:38 pm »
Ok, I was finally able to get some time this past weekend to start wiring my cab after 2 months of inactivity.  I amn building a cocktail cabinet with the long 3rd CP for horizontal games... anyway, to my surprise I wired up the P1 controls to my iPac, plugged it into my computer and it worked!  Here's my question:
Is there a way to wire the long CP so that it will be "off" while using the other CPs?  if I am playing a 2 player game of Ms. Pac-man with my wife using the screen flipping configuration and my daughter comes up to the long CP (that's not being used) and starts pressing buttons she's going to ruin the game...
« Last Edit: June 10, 2006, 02:21:29 pm by javeryh »
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
Re: Yet another Wiring Question...
« Reply #1 on: May 23, 2006, 02:14:47 pm »
You could just use a switch. If you don't have to many inputs, you could use a 25 pin parallel port switch. It should work fine. If you need more inputs 36 pin scsi switches are readily available from ebay.
Quote from: saint
saint is all powerful.
Apparently he is.
« Reply #2 on: June 10, 2006, 02:20:52 pm »
I wouldn't know how to wire something like that I don't think... is there an easier solution?  I'm envisioning some sort of Y-connector where each CPs wires go in and only one set of wires comes out - depending on which position the switch is in determines which CP is active - or am I way off?
Any help from people that have built 3-sided cocktails is most welcome!  Thanks!!
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
Re: Yet another Wiring Question... (3-sided cocktail help!)
« Reply #3 on: June 10, 2006, 03:41:18 pm »
It's easier than you'd think, 25 ins and 25 outs. 1 switch.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
« Reply #4 on: June 10, 2006, 05:10:49 pm »
Shouldn't it be 50 in and 25 out or am I just not getting this?
loadman
  • Last login:May 12, 2026, 04:25:06 am
    • MaLa
« Reply #5 on: June 10, 2006, 11:40:46 pm »
All switches use the same 'Ground' wire from the I-pac right?
Put a switch on that.
 Run the ground from the I-pac to the switch. Then another two wire from the switch, one feeds the CP for Horizontal games and the the other feeds the CP's for the vertical ones
Or is that idea to simple?   :P
« Reply #6 on: June 11, 2006, 12:34:19 am »
Holy crap so all I have to do is run a switch between the grounds?  So if one ground is broken the entire set of controls on that CP won't work?  I daisy chained all the grounds together (one loop per controls) so I only have 4 ground wires running to the ipac...
loadman
    • MaLa
« Reply #7 on: June 11, 2006, 12:38:48 am »
Yep  ;D . Put a switch on the wire running back to the I-pac. You should be able to wire it so one 2 way switch will do the job. I one position the vertical CP grounds are connected and the other the horizontal.
What are waiting for?  Enjoy   :cheers:
« Last Edit: June 11, 2006, 12:41:15 am by loadman »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: June 11, 2006, 07:41:21 pm »
I have a 3-sider and have been meaning to add a switch for the common grounds (as suggested here by loadman) for about a year ... never seem to get around to it.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
loadman
    • MaLa
« Reply #9 on: October 18, 2007, 09:13:09 pm »
Any Update?
