Software Support > DOS/WinCab
Credit Signal
<< < (4/4)
Chris:
WinCab cannot read the parallel port directly.  jp's message looks correct, though: by using ppjoy to read the parallel port as a joystick, you should be able to use his mapping to read it.
The missing bit of information here is how you're interfacing the coin mech to the parallel port.  Is there a special interface you're using for this?  It seems like an unusual solution...
--Chris
gabypotter:
--- Quote from: Chris on February 27, 2006, 09:34:26 am ---WinCab cannot read the parallel port directly.  jp's message looks correct, though: by using ppjoy to read the parallel port as a joystick, you should be able to use his mapping to read it.
--Chris
thaks, i will try it!
yes im using a LPT interface i have made
heres a webpage (spanish) it works for the buttons, and it works
for the coin mech too
http://www.marcianitos.org/tutoriales/IC018.htm
gabypotter:
oh my god, forget everything i was saying
i finally can give credits by hachink a keyboard
the problem is over, it was a little swith i had
to move, the one that says n.o. n.c normally
open, or normally close, but its all fixed!!!
thanks to you!!!
im very happy, thank you very much for
all your help!!!
again, sorry for my english!!!
gabypotter:
its me again
heres another question!
if i want to play a song for .20 cents
how can i program credits
by inserting 2 coins of 10 cents
i mean, i want the credits appears
after i insert the second coin
is this posible?
arthas:
see this page,
http://combuxtion.com/?p=16
Navigation
[0] Message Index
[*] Previous page
Go to full version
