May 22, 2026, 12:17:00 pm
You need to use a Wrapper with project64.Or use AtomicFE as Front End, there is an option to allow to exit all application using escape (even if you can not in standard).
Hey youki, I was wondering... since you can catch the ESC keypress when an emulator has focus, can you also configure your FE to catch save/load keypresses?It would be amazing if I could configure AtomicFE to use 's' for save and 'l' for load (for example), and then configure AtomicFE with which buttons each of my emulators use for save/load. Then, AtomicFE could "translate" the AtomicFE "save" or "load" keybinding into the one used by the current emulator.That would be sweet.
