Author Topic: cocktail table question  (Read 4410 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: December 17, 2005, 12:15:39 pm »
Hi, I am a Nobie.
I b**ch. People listen!!
whammoed
  • Last login:May 22, 2026, 03:03:47 pm
  • Crack don't smoke itself
    • NiceMite
Re: cocktail table question
« Reply #1 on: December 17, 2005, 12:42:41 pm »
No need for avga card or breakout cable with that monitor.  It is vga (640x480) which any video card can output.  Of course you would be limited to that mode.  I used a similar monitor for my first cocktail and I liked it, however you won't be able to run games in their native resolution.
squirrellydw
« Reply #2 on: December 17, 2005, 02:38:27 pm »
OK, any monitors you recommend in the price that will play classics's like Mrs pac man and donkey kong in there native resolution?  Has to fit a cocktail table.
whammoed
    • NiceMite
« Reply #3 on: December 17, 2005, 08:21:02 pm »
A regular old cga monitor will actually be a lot cheaper:
http://www.betson.com/products/IMP-44-4019-02
paired with the avga it will run the classics in their native res.
you will need a breakout cable.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #4 on: December 17, 2005, 08:25:12 pm »
This is a Betson Imperial CGA monitor for $189.00
You would need the ArcadeVGA card and video amplifier from Ultimarc to make it work easily.
squirrellydw
« Reply #5 on: December 17, 2005, 09:36:26 pm »
this is the video amp correct?
http://www.ultimarc.com/vidamp.html
Has anyone used one of these kits or any other kits you recommend.
« Last Edit: December 17, 2005, 09:39:56 pm by squirrellydw »
markrvp
  • NFL Expert
« Reply #6 on: December 17, 2005, 10:02:38 pm »
Those kits are top-notch.  However, you wouldn't be cutting the wood if you got one, they come already cut and ready to assemble.
And you have the correct link for the video amp I mentioned earlier.
  • Last login:Yesterday at 01:34:36 pm
« Reply #7 on: December 17, 2005, 10:02:41 pm »
I'm using a modified arcade depot kit.
squirrellydw
« Reply #8 on: December 17, 2005, 10:16:29 pm »
yeah, I meant I could make one if I didn't buy a kit.
I also am thinking of getting a third control panel.
The CP on both ends,  would there be enough room to mount a joystick, trackball and like 4 buttons?  I would like to be able to play Mrs pac man, donkey kong and marble madness in there full res?
thanks
« Reply #9 on: December 17, 2005, 10:26:00 pm »
squirrellydw
« Reply #10 on: December 17, 2005, 11:05:36 pm »
ok, could I put a trackball ball at one end and the joystick at the other and just configure MAME.  I guess I could make a custome CP at one end also right?
« Reply #11 on: December 18, 2005, 12:47:26 pm »
The way the kits are built, I don't think a custom CP would work on the ends because of the size of the cutout on the side panel.  I'm sure you could call or email arcadedepot and they would do whatever you wanted if you gave them the dimensions though.  They are very responsive over there.
squirrellydw
« Reply #12 on: December 18, 2005, 05:15:28 pm »
why does the cut out matter?  Can't I just make the CP longer?
whammoed
    • NiceMite
« Reply #13 on: December 18, 2005, 05:18:10 pm »
I have one last kit for sale that is a little larger than the traditional size.  You can fit quite a few more controls on it.  I can cut the top for a 19" monitor or as large as a 27".  Here is the link:
http://forum.arcadecontrols.com/index.php?topic=43319.0
« Reply #14 on: December 18, 2005, 07:12:05 pm »
squirrellydw
« Reply #15 on: December 18, 2005, 09:39:01 pm »
couldn't I attach them to the front and not the cut out?  I don't see why this wouldn't work unless I am missing something.  I did email them to see if they could do something similar.  There MAME cabnit looks like that.
« Reply #16 on: December 18, 2005, 10:25:24 pm »
squirrellydw
« Reply #17 on: December 18, 2005, 10:36:03 pm »
I will take your word for it but I still don't quite understand why it wouldn't work.  oh well
« Reply #18 on: December 19, 2005, 10:09:27 am »
Here's a crappy top-down view.
« Last Edit: December 19, 2005, 10:11:23 am by javeryh »
squirrellydw
« Reply #19 on: December 19, 2005, 10:16:16 am »
I understand how it attaches but I don't understand why I cound't modify it myself and make a whole new CP.  No biggy, I will go to plan B.
Thanks for the help, this is a great forum
« Reply #20 on: December 19, 2005, 10:49:09 am »
squirrellydw
« Reply #21 on: December 19, 2005, 11:25:31 am »
they just wrote back to me and said that as long as I use a 2.25 trackball, a T-stick and four buttons that it would fit.
