Author Topic: Crackington Centipede Restoration Project  (Read 35517 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re: Crackington Centipede Restoration Project
« Reply #40 on: July 21, 2005, 05:13:36 pm »
just learned that the Euro monitor bezel that i have is different to the US version. It has red bugs and mushroom, the US version has Green ones.
rchadd
  • Made in Cornwall
« Reply #41 on: August 08, 2005, 07:09:46 pm »
nearly completed fitting everything inside - just a little more tidying is required
rchadd
  • Made in Cornwall
« Reply #42 on: August 08, 2005, 07:13:52 pm »
couldnt resist a test
theres something strange going on with the sync - tried adjusting the pots on the remote board of the hantarex monitor but could not get the monitor to sync. scrolling of the screen was uncontrollable.
any ideas what could be wrong?
rchadd
  • Made in Cornwall
« Reply #43 on: August 16, 2005, 05:54:08 pm »
fixed the display simply by switching the monitor form negative to positive sync. there is a toggle switch on the chassis pcb :)
set dips switches so game in free play mode.
test played and number of minor issues appear:
1. loose ground connection in the control panel wiring - sometimes buttons suddenly stop working. wriggling the molex connectors can get it working again.
2. constant beeping when coin door harness connected. need to double check wiring hack/soldering. disconnected coindoor temporarily - not a problem as in freeplay mode.
3. vertical movement of the trackball is reversed - simply resolved by crossing over yellow/green wires on the trackball harness wiring.
4. volume pot does not seem to make any affect on the volume
« Last Edit: August 16, 2005, 06:02:04 pm by rchadd »
rchadd
  • Made in Cornwall
« Reply #44 on: August 16, 2005, 06:01:07 pm »
need to check my wiring harness hack for the coindoor - it causes constant beeping when connected!
rchadd
  • Made in Cornwall
« Reply #45 on: November 07, 2005, 05:34:24 pm »
i think i can now consider the project as finished!
looking pretty good i think
only outstanding issue is the monitor degaussing is not working. identified that the fuse has blown. hopefully after i replace it it will automatically degauss on startup.
« Last Edit: November 07, 2005, 05:36:58 pm by rchadd »
rchadd
  • Made in Cornwall
« Reply #46 on: November 07, 2005, 05:38:26 pm »
close ups
rchadd
  • Made in Cornwall
« Reply #47 on: November 07, 2005, 05:39:59 pm »
tidied up internals
rchadd
  • Made in Cornwall
« Reply #48 on: November 23, 2005, 07:30:16 pm »
fixed the degaussing issue.
project officially completed!
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #49 on: November 24, 2005, 06:16:59 pm »
GREAT Restoration, really clean.
I have been dying to restore a Centipede, I need to keep my eyes open for one.
Bones
  • [Moderator]
« Reply #50 on: November 24, 2005, 07:00:59 pm »
Just awesome. You gotta be proud of this.
So what's next? :)
