Main > Everything Else
Car stereo trick
ChadTower:
--- Quote from: SOAPboy on April 04, 2005, 09:30:52 am ---how about reading it again..
How about a little humility and considering the fact that my post wasn't directed solely at you, Mr It's All About Me. Thanks.
Shape D.:
--- Quote from: paigeoliver on April 03, 2005, 07:53:14 am ---
Is it possible to use a relay on the ACC line out of a car stereo to disable the starter if the radio isn't turned on?
sounds like a good idea, until someone steals your radio.
ChadTower:
--- Quote from: Shape D. on April 04, 2005, 12:19:43 pm ---sounds like a good idea, until someone steals your radio.
danny_galaga:
i doubt anyone would steal a removable stereo, after that was the whole idea of them in the first place wasnt it? to make them useless to steal?
i had a think back to when we installed the kill switch in the cigarette lighter. it was an older car with points, so the switch was shorting the points out when the lighter was depressed. what i never found out though was what happened if the thief spent more than a few minutes at it? because then i reckon the lighter would pop out once it was hot enough (like it normally does) and in so doing allow the car to start...
danny_galaga:
--- Quote from: ChadTower on April 03, 2005, 05:15:38 pm ---Adjust the carburetor so it only starts with a random amount of pumping of the gas pedal.
