Author Topic: How do I cut a panel so it is "square"?  (Read 8565 times)
  • Online Online
  • Last login:Today at 01:49:32 pm
« on: January 11, 2005, 10:14:19 am »
I know this sounds like a stupid question but I want everything to line up perfectly when I assemble the pieces of plywood for my cab.  I am using a router and a pattern cutting bit with a straight edge to make all of my cuts.  I do not have a table saw.  Does a T-square or triangle do a sufficient enough job to ensure that the angle is really 90 degrees?  Is there some sort of woodworking trick that I'm not aware of?  Thanks!
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re: How do I cut a panel so it is "square"?
« Reply #1 on: January 11, 2005, 10:22:20 am »
When cutting out the larger pieces of a cab, I would use a framing square, but for the smaller pieces, a speed square or combination square would work fine.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #2 on: January 11, 2005, 02:01:38 pm »
T-squares are usually pretty accurate assuming if hasn't been abused. I'm assuming you are using a fresh 4x8 sheet of plywood/MDF. The corners/sides on those are usually extremely square, but, check them out with your T-square before you begin (I have gotten some where the angle was not perfect, rarely though).
Try to plan your cuts so you're using these as much of the corners/sides as possible. Mark a line where you want to cut on the panel and use your T-square (clamp it to the panel) as a guide fior your router. If you end up straying from the line (for whatever reason) stray outside the line. That way you can sand down to the line if you make any mistakes. Take is slow and easy and make sure someone is there to help support the larger pieces. Other than that, any mistakes can usually be corrected with Bondo/Wood Filler.
« Last Edit: January 11, 2005, 02:27:20 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
gobuchul74
  • Last login:November 03, 2012, 02:34:06 am
  • I want you to build my arcade controls!
« Reply #3 on: January 11, 2005, 02:17:10 pm »
A trick that someone showed me was the 3-4-5 rule.
After you lay out the lines you'll cut for a corner.
On one side measure 3 inches from the corner and mark it.
On the other side measure 4 inches from the corner and mark it.
Now the diagonal measurement from those marks should be 5 inches.  If it's not, your corner isn't square.
It's a good way to double check before your cuts.
"We're going to take things away from you on behalf of the common good." - Sen. Hillary Clinton
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
« Reply #4 on: January 11, 2005, 04:41:48 pm »
If the piece you are cutting is a rectangle, both it's diagonals should be equal.
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
danny_galaga
  • Last login:Today at 06:26:14 am
    • dans cocktail lounge
« Reply #5 on: January 12, 2005, 03:11:25 am »
Bones
  • [Moderator]
« Reply #6 on: January 12, 2005, 04:48:57 am »
LOL.
What then hell is a 5/64th anyway??? Much easier to measure 2mm. Stupid imperial standard.
More impressive when measuring the old fella in metric also;
"Hey there baby, I got a hundred and something millimeters and it's all for you....
