Main > Everything Else
Does this constitute a computer?
subzero23:
--- Quote from: paigeoliver on November 23, 2004, 01:28:50 am ---Why in the heck are you buying CD burners and fancy mice and keyboards and huge hard drives for a machine that is going to sit inside a cabinet?
subzero23:
well nevermind that harddrive I'll just go with this one
Samsung 160GB 7200RPM Hard Drive, Model SP1614N, OEM Drive Only
(limit 20 per customer)
- Specifications -
Capacity: 160GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE Ultra ATA133
Features: Fluid Dynamic Bearing Spindle Motor Technology
Manufacturer Warranty: 3 years
Remark: OEM Drive Only
Model#: SP1614N
Item#: N82E16822152014
subzero23:
Before I downgrade my list to 256mb of ram instead of 512mb of ram I need to know for sure that with windows XP running I'd have no problem running basically all 2D games?
Snarbald:
Don't get a pcchips motherboard, it'll give you nothing but grief.
What brand of powersupply does that case come with? If its a deer or something, see if you can order the case with out the supply for less so you can get one that doesn't suck.
subzero23:
Ok I updated a few things. I think it's the same case/power supply. I went back to it because it's cheap and there are a TON of good reviews for both it and the PSU that comes with it.
List with specs:
Case:
APEX Beige Mid-Tower Super Case with 350W Power Supply, Model "7C574-115"
Specifications:
Case Type: Mid-Tower
Color: Beige
Material: Steel
Drive Bays: 5.25'' x4,3.5''(External) x2, 3.5''(Internal) x2
Expansion Slots: 7 Full Size
Front Ports: USB2.0 x2
Power Supply: 350W
Cooling System: N/A
Motherboard Compatibility: ATX
Dimensions: 18.75''x7.25''x16''
Speeze 80mm DC Case fan, Model "FD08025S1M4" x 4
Specification:
Compatibility: Case, Power Supply
Dimensions: 80 x 80 x 25 mm
Bearing Type: Sleeve
Nominal Speed(RPM): 2500+/-10%
Max Air FlowCFM): 31.73
Max Pressure: Not Specified
Heat Sink Material: N/A
Rated Voltage: 12V DC
Connector: 3+4 Pin
Noise(dBA): 28.0
Special Features: ISO9002 Certified
Memory/Media:
Model#SP1614N Item #N82E16822152014Specifications:
Capacity: 160GB
Buffer: 8MB
Kingmax 184 Pin 512MB DDR PC-3200 - OEM
Model#MPXC22D-38 Item #N82E16820156006Specifications:
Manufacturer: Kingmax
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime
SONY Black 16X DVD-ROM Drive, Model DDU1613/B2s, OEM
Specifications:
Read Speed: 40X CD-ROM, 16X DVD-ROM
Interface: E-IDE/ATAPI
Buffer: 512KB
Access Time: 80-220ms DVD, 165ms CD
Data Transfer Rate: 1,800~3,600 kB/s (CD), 8,788~21,632 kB/s Single Layer, 5,586~13,520 kB/s Dual Layer
Features: Compatible with all CD formats
Packaging: OEM Pack Drive only (see pictures for details)
Brains:
AMD Mobile Athlon XP 2600+, 266 MHz FSB, 512K L2 Cache Processor,45 Watt - OEM
Model#AXMG2600FQQ4C Item #N82E16819103436Specifications:
Model: AMD Mobile Athlon XP
Core: Barton
Operating Frequency: 2GHz
FSB: 266MHz
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.45V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM(Processor Only)
-ASRock "K7S41GX" SiS741GX Chipset Motherboard for AMD Socket A CPU -RETAIL
Specifications:
Supported CPU: Socket A for AMD Athlon Duron/XP Processors
Chipset: SiS 741GX + SiS 963L
FSB: 333/266/200MHz
RAM: 2x DIMM for up to 2GB DDR333
IDE: 2x UltraDMA 133 up to 4 Devices
Slots: 1x AGP 8X, 2x PCI, 1x AMR
Ports: 2xPS/2,1xLPT,4xUSB2.0,1xLAN,1xVGA,1xGame Port,Audio Ports
Onboard Audio: 5.1 Channels AC97 audio codec
Onboard Video: Integrated with Real 256E 3D Graphics controller, support 64MB Max shared memory
Onboard LAN: 10/100Mbps Fast Ethernet
Modem: Modem Riser Card
Form Factor: microATX
Sound and Video cards:
Creative Labs Sound Blaster Live! 7.1 24-bit PCI Sound Card, Model 70SB041000000 -Retail
Model#70SB041000000 Item #N82E16829102176
Specifications:
Channels: 7.1
Max Sampling Rate:24/96kHz
Hardware Decode: Dolby Digital
Digital Audio: 24-bit
PC Interface: PCI
Connectors:Line level out (Front / Side / Rear / Center / Subwoofer) or Headphone out Line In / Microphone In / *Digital I/O Aux Audio in
Package Contents: See pics
Special Features: EAX 3.0, Plug and Play, DirectSound
