Author Topic: Newbie needs help  (Read 6041 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
Re: Newbie needs help
« Reply #40 on: January 18, 2005, 10:27:46 am »
The switch itself is straight with a slight bend the switch when in the place it supposed to be on rays diagram doesnt seem to be near where the coin comes out do i need to bend the wire?
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« Reply #41 on: January 18, 2005, 12:11:38 pm »
Wasn't sure if you got the PM...but yes, bend the wire, it needs to go through the slot across the chute, the coin will strike the wire pushing it down and activating the switch, the coin will continue pass the wire; into the coin box, the wire should spring back into place
Marky_1979
    • Personal Webspace
« Reply #42 on: January 19, 2005, 04:37:40 am »
Hi all i cheated last night couldnt work it out so used some sticky back tape got it in place works a treat thanks all for your help  :)
