Main > Monitor/Video Forum
arcadevga and resolutions
DYNAGOD:
i specify it in my front end.
i use Emuloader and you can create a custom CFG file by checkin or unchecking the desired boxes.
KevSteele:
I've found Steve's ArcadeVGA M.A.M.E. Resolution Tool much better at picking the proper resolution than the AVRES tool on the Ultimarc site. It's easier to use, as well (although it needs a shorter name! ;))
http://mamewah.mameworld.net/downloads.html
Kevin
pacman:
One of you can kindly tell me why this Mame Resolution tool do not launch properly on my XP with AVGA 9200 ? I receive alway this bloody 'Run Time error 13 - Type Mismatch'!! Mamewah system file package is installed so I do not know what a hell is going on!! >:( >:(
KevSteele:
--- Quote from: pacman on March 21, 2005, 05:30:31 am ---One of you can kindly tell me why this Mame Resolution tool do not launch properly on my XP with AVGA 9200 ? I receive alway this bloody 'Run Time error 13 - Type Mismatch'!! Mamewah system file package is installed so I do not know what a hell is going on!! >:( >:(
I used to get that problem occasionally with MAMEWAH - I seem to recall that deleting/replacing the .ini file (or doing a clean reinstall) sometimes worked. I can't be more specific right now, as my MAME cab is out of commission until my monitor is back up and running... :'(
Kevin
pacman:
Hi KevSteele,
Which ini are you talking about ? Mamewah, Mame or any other ? :P
