Main > Monitor/Video Forum
arcadevga and resolutions
KevSteele:
--- Quote from: pacman on March 21, 2005, 08:32:13 am ---Hi KevSteele,
Which ini are you talking about ? Mamewah, Mame or any other ? :P
When it happened to me in MAMEWAH, it was the MAMEWAH.ini file (older version of MAMEWAH). I suspect your problems with the MAME Resolution tool may be similar, but I can't confirm right now that the Resolution tool uses an INI file. I'd check and see if it does, and try deleting it and/or doing a clean reinstall (delete the current directory and reinstall).
Kevin
pacman:
Correct me if I am wrong but for teh last updated version of Mamewah (1.61) there is nothing to install...This is weird as I remember that previous versions need installing before.. ??? ::)
KevSteele:
--- Quote from: pacman on March 21, 2005, 09:35:46 am ---Correct me if I am wrong but for teh last updated version of Mamewah (1.61) there is nothing to install...This is weird as I remember that previous versions need installing before.. ??? ::)
Yeah, you just unzip to a folder. But you don't need to do anything with MAMEWAH to fix the MAME Resolution tool - I'm just posting about my MAMEwah experiences since I got the same error with MAMEwah and fixed it by replacing the .ini file with a "clean" copy.)
Kevin
pacman:
Ok I will give it a try and see...
Finger crossed.... :P
