Main > Software Forum
MameWAH Run Time error '75'
Pages: << < (2/4) > >>
Minwah:
--- Quote from: AGGIEZ on June 23, 2004, 06:25:57 pm ---Well, I uninstalled/reinstalled and it still isn't working. I tried the batch file, but considering I'm not a computer programmer, I'm not sure if I'm writing it correctly. DAMN! This is the last piece of the puzzle too! Maybe I should just go with Emulaxian or some other frontend. These errors are pissing me off...
As I said, unistalling / re-installing won't do anything.  Delete the \MAMEWAH\Files folder, and do the batch file thing, it's not difficult, you could copy/paste my post if your mame folder is the same...
In fairness it is about time I sorted the Win98 bug(s) out...it is a ---smurfette--- that I cannot replicate the problems tho  :(
AGGIEZ:
--- Quote from: Minwah on June 23, 2004, 07:00:24 pm ---
In fairness it is about time I sorted the Win98 bug(s) out...it is a <auto-censored> that I cannot replicate the problems tho  :(
I've tried that. This is exactly what I did:
[*]Deleted C:\Program Files\MAMEWAH\Files
[*]Ran .bat file exactly like above
[*]Entered MAMEWAH to find that all games had been deleted and that I needed to re-setup everything including the emulator settings
[*]Exited MW after games had been refreshed
[*]C:\Program Files\MAMEWAH\Files is back!
[/list]
From this point, I can play games from MAMEWAH but if I shutdown or restart it does the same crap again. Is there a PERMANENT fix or is this something that would have to be done every time. If so, this definitely isn't going to work for me. LMK
Minwah:
--- Quote from: AGGIEZ on June 23, 2004, 08:10:11 pm ---I've tried that. This is exactly what I did:
[/list]
OK you did right, but you need to run the batch file every time you start your PC - no big deal as you can just put it in your startup...The PERMANENT fix is to get XP - this is actually a Win98 bug not a MAMEWAH one (although it is possible to program around...)
Tiger-Heli:
--- Quote from: Minwah on June 21, 2004, 05:45:16 am ---Make a batch file which does something like (substitute your mame path etc.):
c:
cd\mame
mame > temp
exit
Then run the batch file *before* MAMEWAH for the first time after boot-up.
A batch file is just a text file with .bat as an extension rather than .txt.
And you should *never* have to uninstall/re-install MAMEWAH...it won't make any difference.  Deleting the \mamewah\files folder will remove any files causing problems.
Minwah -
I don't use MAMEWah, but I get the same type on error (actually RunTime Error 70: Permission Denied) when I try to use Johnny5 in Win98.
Do you think a similar idea would work for this?
Also, I understand some DOS (cd is change directory), but what does
mame > temp
actually do?
For details of my problems, see:
http://fe.donkeyfly.com/yabbse/index.php?board=10;action=display;threadid=118
and
http://fe.donkeyfly.com/yabbse/index.php?board=10;action=display;threadid=92
AGGIEZ:
Thanks for the help MINWAH. I've got it working fine now but I think I've decided to go ahead and upgrade to XP. I don't like the feeling of having to run batch files behind the scenes to fix bugs. Thanks for the time...
Go to full version
