Main > Software Forum
MameWAH Run Time error '75'
Tiger-Heli:
--- Quote from: greywolf22 on June 27, 2004, 04:41:54 pm ---Thanks Fox, I'm thinking of upgrading to W2K today to see how it runs overall.
Keep in mind that AFAIK, dual Mice and dual trackballs are supported only under Win98 or WinXP, not Win2K, if that matters to you.
greywolf22:
Thanks Tiger-Heli, for the time being that won't be an issue, however in the hopefully not to distant future it probably will be. I'm still wavering between working around the WIN98 limitation, or going with WIN2000 for the time being. Eventually I'll probably end up breaking down and purchasing another copy of XP... ::)
quarterstringer:
When I tried using the Mamewah settings I had on my XP computer for another computer with 98SE I got the runtime 75 errors. So I played around with the settings and got it to work with.
List Generation - 3
Send ROM Path - True
Send ROM Extension - False
Use Long File Names - False
Show DOS Box - 0
Maybe that will help.
greywolf22:
Hey Quarterstringer,
That sounds good I'll give it a shot...unfortunately I'm not overly familiar with what the settings that are being changed does. Anything with the changes to the settings that are going to be noticeable or I should be aware of? I'll give it a shot tomorrow (if I can get out of work at a reasonable time). Thanks for all the tips everyone :)
quarterstringer:
I'm not sure what the different settings mean either, I was just happy that I got MameWah to work. I'm not even sure if it will work for you. If it doesn't, just try out the different combinations for the Send ROM Path, Extensions, and Long File Names.
T T T
T T F
T F T
T F F
F T T
F T F
F F T
F F F
That's all I did, until I finally got it to work. Good luck.
