Main > Software Forum
MameWAH Run Time error '75'
Minwah:
--- Quote from: AGGIEZ on June 24, 2004, 11:13:37 am ---Thanks for the help MINWAH. I've got it working fine now but I think I've decided to go ahead and upgrade to XP. I don't like the feeling of having to run batch files behind the scenes to fix bugs. Thanks for the time...
Oh cool, well MW does run a lot better on XP...
greywolf22:
Minwah,
Sorry to catch this thread so late, but you mentioned that the Run time error 75 is a 98 issue...so does that mean if I upgrade to Windows2000 it should resolve it as well? How does Mamewah run in Windows2000 (comparable to 98 or XP)...just trying to avoid buying another copy of XP ;) Granted I can do the .bat file as well, which I probably will if you don't recommend Win2000. THanks for the great front end and all the support and answers you provide :)
Minwah:
--- Quote from: greywolf22 on June 26, 2004, 03:15:22 pm ---Minwah,
AFAIK The issue should not happen on Win2k...I would recommend XP over 2k, almost purely because I *know* it runs well under XP - in theory it should run just as well under 2k, but I haven't tried it.
If you already have Win2k, then give it a try :)
FoX:
I use win2k and I've had no problems with mamewah
greywolf22:
Thanks Fox, I'm thinking of upgrading to W2K today to see how it runs overall.
